Question about Nikon Cameras
My card has been wiped but the camera keeps insisting it is out of memory. Why? What can I do
    Problem Solver:
  • 7 Answers
I this there should be some problem with the memory card, so try formating the memory card. It should work!
Posted on Aug 27, 2008
Says memory full put a new sd card in says thats full too cant move anything to sd card
If you look carefully, what usually occurs is that it is the internal memory that is getting full. It is very hard to fill an SD card unless you have a LOT of pictures and videos saved. Some apps are written to allow them to be moved to and run from the SD card, others allow their data to be stored there, but unfortunately, most still seem to insist that they run exclusively on internal memory. This prohibits the ability to free up internal memory and eventually results in your having to decide which apps are more important than others. Cleaning up the memory by deleting data caches helps, but until the phone manufacturers either increase internal memory or insist that apps writers take advantage of SD cards when available, this problem will continue to haunt us all.
Mar 13, 2015 | Cameras
Copy from pc to camera
The software that comes with almost every camera, is used to make backups from the pictures on your camera. The backup device is thought to be a computer. So this software only allowed to move the pictures from the camera to the computer. lots of camera users don't even realise the have to install special software, to transfer the pictures from camera to computer.
Keeping all you computers only on one memory card in a camera is very dangerous, because there are lost of possibilities to lose all your pictures. But if you insist to put back pictures on the memory card, you should use a memory card reader connected to the computer. and copy the pictures from the computer to the memory card.
Don't try to copy pictures, made on other camera's, to the memory card that you us in your camera. Not all files are compatible, even not when they have the same name. So it could be, you have pictures from an other camera on your memory card and still you won't be able to view them on your camera display.
Feb 09, 2014 | Olympus Camedia D-580 / C-460 Digital...
Purchased a easyshare C143 when I put in the memory card it keeps insisting I format it. When I indicate OK it produces a red and white line for a few seconds and goes back to the original message format!...
You're right...a Kodak isn't even in the same ballpark as a Canon. Anyway, be sure the slide switch on the side of the card is in the "unlocked" position. Go into the menu and find "format" and launch it from there. Also, be sure the card can be used by the camera. For example, some cameras can only use SD cards and not SDHC cards.
Feb 22, 2011 | Kodak EasyShare C143 Digital Camera
I wiped all photos from card...but when I re-insert the card in camera it says memory card full
You should make it a practice to format (initialize) your card from your camera's menu each time you use it. That will wipe all data and give you a clean start. If you format your card from your camera and it still indicate a full memory card, then the card is likely bad.
Dec 20, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
The dock keeps flashing red while the camera is in the dock
Please note that for the most of the time the Dock will only charge KODAK rechargeble batt. 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 2. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 10, 2010 | Kodak EasyShare CX6445 Digital Camera
The batteries keep going dead even after new ones are put in
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 10, 2010 | Kodak Easyshare C813 Digital Camera
My camera keeps shutting off
Jan 06, 2010 | Kodak EasyShare Z740 Digital Camera
What does format mean on a samsung l301 camera?
Formatting is erasing the memory card and preparing it to take new photos. If you haven't saved the photos to your computer yet, you will need to find a memory card utility that "rescues" data (pictures, in this case) from a card. You can go to your card manufacturers (Kingston, Sandisk, or whatever your brand is) website and find a suggestion for what utility they suggest.
If you had them saved to your computer, no worries, just start taking pictures again!
Sep 29, 2009 | Cameras
Photos do not save after camera is turned off
Check the manual. Most digital cameras give you the option to save to an internal memory or an SD card(or whatever your camera takes). If it doesn't have an internal memory...that may force you to have a memory card in so you can keep the images. Good luck.
Aug 04, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Memory card error
Try using the "format" option in the setup menu. That should wipe any "bad" data off the card. Beware! It will erase anything you already have on the card, so make sure there isn't anything on you need to keep.
Apr 05, 2009 | Pentax Optio 50 Digital Camera
Cameras Logo
26 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
