Question about Intel Motherboard
Continious short beeps from a gigabyte MB - Intel Motherboard
  • 88 Answers
Pc beep code 1 long 9 short beeps = bios rom error
Your Motherboard is broken when the pc beep in that try to buy new one
Dec 03, 2013 | Gigabyte Core 2 Quad Intel X48 FSB 1600...
3 log beeps on power on
Gigabyte doesn't list 3 long beeps as an error code, so I'm not sure if you're actually getting 3 short beeps or maybe 1 long and 2 short or... But, for reference, Gigabyte's error code list is as follows (depending on whether you have an AWARD BIOS or an AMI):
(AWARD BIOS)
1 short beep: System normal
2 short beep: CMOS Error
1 long beep and 1 short beep: Memory error
1 long beep and 2 short beep: Graphic card error
1 long beep and 3 short beep: AGP error
1 long beep and 9 short beep: Memory Error
Continuous long beep: Memory not correctly installed
Continuous short beep: Power supply unit failed
(AMI BIOS)
1 short beep: Memory Error
2 short beep: Memory parity check error.
3 short beep: Basic memory 64K address check error
4 short beep: Real Time Clock malfunction .
5 short beep: CPU error
6 short beep: Keyboard error
7 short beep: CPU interruption error
8 short beep: Graphic card error
9 short beep: Memory error
10 short beep: CMOS error
11 short beep: CPU cache memory malfunction
It might not be a lot of help, but it's somewhere to start... and at least this way you'll know what to be listening for.
Nov 30, 2013 | Gigabyte Computers & Internet
Long beep continuous
here is a list of beep code for Award bios chip, which is the one present on you memory card:
repeated beeps - DRAM error
repeated short beeps - Power error
Repeated high & low beeps - Processor is damaged/Overheated
1 short - System boot successfull
2 short - CMOS setting error
1 long 1 short - DRAM or M/B error
1 long 2 short - Monitor or display card error
1 long 3 short - Keyboard error
1 long 9 short - BIOS ROM error
I don't remember the speed of the repeted beeps for the award bios.
But in your case if this is not a DRAM issue, you might try to check if the beeping remain the same once the cmos battery removed (the flat batterie that looks taken out of a watch).
If so this means that it needs to be replaced.
Oct 20, 2013 | MSI PM8M-V Motherboard
GA-MA785GM-US2H
You can find the manual here at Gigabyte. The appendix lists this information about beep codes:
Hope this helps you figure out what to do next. Thanks for using Fixya!
Feb 20, 2010 | Gigabyte GA-MA785GM-US2H Motherboard
No visual and hardware problems
I am not sure on the beeps on what your mean. There is a short beep or a long beep or a series of beeps. Here is a website for you to help you to determine that.
http://www.pantherproducts.co.uk/Articles/Motherboard/BIOSbeep.shtml
Dec 27, 2009 | Gigabyte MB GIGABYTE GA-MA74GM-S2H AMD740G...
NO NTLDR. FOUR LONG BEEPS - ONE SHORT.
Sorry, that indicates a main board failure; you need to replace it.
Oct 10, 2009 | Gigabyte Computers & Internet
Gigabyte GA-945P-S3 short beep codes on cold boot. Tried reseating RAM, didn't help. system runs fine after beeping stops
Using the manual for the Gigabyte GA-945P-S3 MB. Go to page 71 & you'll see bios beep codes for your board: AWARD BIOS Beep Codes 1 short: System boots successfully 2 short: CMOS setting error 1 long 1 short: DRAM or M/B error 1 long 2 short: Monitor or display card error 1 long 3 short: Keyboard error 1 long 9 short: BIOS ROM error Continuous long beeps: DRAM error Continuous short beeps: Power error As you can see there isn't a code for three short beeps. When you boot your system try to pause your boot up screen. See if the bios is reporting the correct total of memory in your system. Bios codes from the link below. http://www.computerhope.com/beep.htm#05 3 beeps for the AMI bios code reports Base 64K RAM failure. You can test your memory. Go to memtest.org Scroll down the site to just under the three screen shots. Download Memtest86+ V2.11 You have a choice in making a bootable floppy disk or a bootable CD-ROM disk. Once completed you boot your system to the testing program. Memtest will check your system memory. This should help. Thanks for using FixYa! Mike
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
Sony vaio athlon 2800+ started beeping,one long beep lights flash
listen carefully to the beeps
One Long Beep, One Short Beep= motherboard problems.
One Long Beep, 2 Short Beep= video problems.
One Long Beep, 3 Short Beep= video problems.
Repeated long beeps = memory failure
continious long and short beeps = Cpu overheating
hope this helps
Jan 24, 2009 | Computers & Internet
Continuous short beeping after RAM upgrade
Try the old ram back in if it works you have the wrong ram
ram comes in many shapes and flavours
ddr ddr2 etc
Aug 15, 2008 | Gigabyte 8IG1000MK Motherboard
No signal on monitor
The beeps you heard, 1 long two short is the bios telling you that there is a problem with your video card. Normally you would remove & reseat it. Not the case with the intergrated video. When you added an AGP card you should have been able to get video. All video is controlled by the intergrated video controller. If your sure the radeon works than all that is left is the mb controller which can't be fixed. There is a slim chance you might get a PCI video card to work. Link to your board:
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1766
Jan 13, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Intel Motherboard Logo
302 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
