Question about Creative Labs ZEN SLEEK MP3 Player
Creative Zen Sleek Firmware Problem...
I'm trying to reload the firmware for a Creative Zen Sleek, but so far it's been nothing but trouble...
First, the firmware updater wouldn't recognize the Sleek even though it was plugged in (although XP recognized it jus fine and the sync screen would pop up on the Sleek).
I downgraded to Media Player 10 and downloaded a 'fixup' program at a friend's suggestion. Now, whenever I hook up the sleek XP beeps several times as if USB devices are being connected and disconnected, and my mouse stops working. The sync screen on the Sleek no longer appears and XP doesn't even seem to be recognizing it any more.
Help!!
  • Creative Labs Master
  • 1,800 Answers
U r facing a short circuit in the motherboard of ur device!
plz rate this post
if u can solve it in ur own u need to be Chinees - -
Posted on Aug 27, 2008
SOURCE:
My zen is frozen on recovery mode
Ha, I think I know how to fix this. I've brought five units back from the dead this way.
The key to making the computer recognize the player is to uninstall all traces of Windows Media Player version 11 from your computer programs. The creative software and WMP11 are not simultaneously compatible. Use the uninstall function in your compuer's "control panel". Don't worry, it's easy and free to put them back on form the internet. If you don't know how to do this, ask a moderately savvy computer user to show you how. Then restart the computer, attach the Sleek, and reload the firmware from Creative's support site.
Use this link if you have the sleek, not the sleek photo:
http://support.creative.com/Products/ProductDetails.aspx?catID=213&subCatID=214&prodID=14259&prodName=Zen%20Sleek%20Photo&subCatName=ZEN&CatName=MP3+Players
and this one if you have the sleek photo:
Unfortunately your music is gone so I hope yu had back-up files. Good luck.
Sep 13, 2008 | Creative Labs ZEN SLEEK MP3 Player
My Creative ZEN 8 GB has Firmware Problems
Try uninstalling Windows Media Player version 11 from your computer before trying to reload the firmware. It works wonders.
Aug 12, 2008 | Creative Labs ZEN SLEEK MP3 Player
Getting out of recovery mode
The recovery tool mentioned above is not designed for the sleek photo. You need to download the firmware for the sleek photo from creative's site. Now we need to get your player recognized to get the firmware loaded. If you have Windows Media Player 11, it needs to be removed. Also remove WMP runtime. After that, restart the pc and your player should be recognized. You can then double click on the firmware program to run it. It might say something like, this firmaware is already installed...do you want to reload it? Click yes to reload.
I had the same problem with my sleek photo. Once I got rid of WMP and the runtime everything worked like a charm.
Jul 02, 2008 | Creative Labs ZEN SLEEK MP3 Player
Creative zen sleek photo not recognized by win xp
I got my Creative Zen Sleek Photo from a friend and everything I did wouldn't let Windows recognize it, but then I got it to work almost magically.
1. Make sure you have the proper drivers installed for it that come with the CD. If you don't have the CD, you can download the ISO here.
http://wp.randyr.net/windows-xp/creative-zen-sleek-photo.html
2. Reboot. When it comes back up, plug the cable into your computer, then into your Sleek. The software should sync up. For some reason, my Zen wasn't being recognized from the usb port on my computer tower, but I plugged it into my monitor's USB port and then it worked. Try that, if none of that works, then it may be a problem with your computer not knowing which driver to assign to your Zen, and if so, try the steps below.
1. Plug your Sleek to your computer.
2. Open up Windows' Device manager (right-click on "My Computer" and select "Properties". Go to the "Hardware" tab, then click "Device Manager").
3. Locate the entry for "Creative Zen Sleek" in your device list. It should appear either under "Sound, video, and game controllers" or under "USB Devices". Once you locate the entry, uninstall it.
4. Unplug your Sleek and wait a few seconds.
5. Plug your Sleek back in and allow the "new Hardware Wizard" to identify and install the drivers for it.
Mar 01, 2008 | Creative Labs ZEN SLEEK MP3 Player
Firmware problem
You can't reinstall the firmware on these units if your computer has Windows Media Player version 11 on it. Try uninstalling WMP11, reloading the firmware off creative's site, then after the player is working again, you can reinstall WMP11 from the internet. I don't know if it will work for you but I have brought back many dead sleek photo units this way. The problem is not with the players themselves, it's a software interface problem that makes the creative software and the WMP11 software incompatible.
Jan 14, 2008 | Creative Labs Zen Sleek Photo MP3 Player
Zen frozen on one screen even after I've restarted it.
hard drive sounds bad. has it been dropped?
try to do a cleanup
  1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
2. Connect the power supply to the player.
3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
underneath your player, beside the data/power connector. Keep on holding the
Play/Pause button while you release the Reset button. The Rescue Mode screen will
then appear.
4. After the recovery mode has started, release the Play/Pause button
It will display the following options.
Clean Up Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 04, 2007 | Creative Labs ZEN SLEEK MP3 Player
Zen Sleek not recognized by firmware: not connected msg
try the information here remove MS Media player 11 http://193.95.171.84/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=366,E=0000000000255567421,K=6463,Sxi=6,Case=obj(16737),Kb=ww_english_add,VARSET=ws:http://uk.europe.creative.com/
Aug 21, 2007 | Creative Labs ZEN SLEEK MP3 Player
try the Reload Firmware option from the Recovery Mode menu? It makes a huge difference!
Seeing as how you can access Recovery Mode, can perform its disk operations, and seeing as how your computer does recognize it, it seems there's a good chance it's simply firmware corruption causing your problem.
Feb 27, 2007 | Creative Labs ZEN SLEEK MP3 Player
Can't reinstall Firmware
It only sees the player if you are using Windows Media Player 10! Try a fresh computer. Get it to see the Zen Sleek by updating the driver. Load Media Player 10 (Not 11) and try the update firmware program again. Best of luck
Feb 13, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN SLEEK MP3 Player Logo
170 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
