Question about Northgate Computers & Internet
My EZX15F flatscreen of my Northgate computer need to be replaced, where can I get another one. The problem is that after shutting down my computer the screen stays black, the green light is flashing
  • 10 Answers
SOURCE: problem
i think its your operating system that has a problem.. try reformating your computer.. hope it can help
Posted on Nov 07, 2007
DickCanFixIt
  • 948 Answers
SOURCE: Screen stays black and have to shut down and restart, this happens 2 to 3 times per week.
With no more information that what you have provided I would start by reseating the memory and video card if you're not using onboard video. Then I would check the hard drive via chkdsk, run it from a command prompt. If the drive seems ok the next thing I would do is reinstall the OS. If it still gives you trouble after that you have a faulty component (memory, processor, power supply, video card, or mother board) and I would start swapping in known good components.
Posted on May 24, 2009
pumpkinman
  • 1147 Answers
SOURCE: A power surge shut down the computer -- green light flashing
Im afraid it has been burnt do to the power surge
Posted on Jun 24, 2009
For those who have this problem:
I just had the SAME problem. In fact, prior to my power outage last night, my comp was shutting down after sleep mode on its own.
It is your POWER SOURCE UNIT. I am not a computer guy, and, until today, had never opened up a computer before. After several posts like this hinted at the power source as the culprit, I took the shell off my computer and figured out what the power source was. (it's the little box in the back of your computer that sends power to the different parts. it has a spot where you plug your power cord into. there is also a fan on it.)
I monkeyed around and figured out how to disconnect it from all of the different spots. I went to Best Buy and bought their cheapest one (which has more voltage than the one my computer came with) and took it home. A little elbow grease and the new one was in. My computer turned back on right away.
Hope this helps!
-KP
Posted on Aug 02, 2009
joecoolvette
  • 5660 Answers
SOURCE: no power flashing green light
You have power to the computer, but not enough.
Bad Power Supply, with weak voltage power rail.
1) ALL the lights use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor uses 51 to 125 Watts.
Depends on what Processor it is.
[If the computer in question is an HP Pavilion A645c, it uses an AMD Athlon 3200+ processor, that fits in a Socket A processor socket. (Socket A is also referred to as Socket 462)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00183033&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&product=425922?=en
The AMD Athlon 3200+ processor can use up to 76.8 Watts.
(2.2GHz, and a 400MHz FSB)
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors#Athlon_XP_.22Barton.22_.28Model_10.2C_130_nm.29
With a bad power supply, you don't have enough power to turn the Processor on.
(Computer dirty inside, as well as the Power Supply, is the leading cause of computer, and also Power Supply failure)
Suggestion is to test the Power Supply, or replace Power Supply with a Known to be good, compatible unit, for a test.
(Compatible being that the power supply,
1) Is the correct shape, and size.
2) Has the same amount of Wattage, or more.
3) Has the correct amount of power cables, and the correct kind )
Testing can be done with an inexpensive multimeter, or an inexpensive power supply tester.
One example of an inexpensive power supply tester,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471
Posted on May 30, 2010
Northgate power button wires
Remove the front panel and remove the switch. It is the same as any computer tower.
Aug 20, 2013 | Computers & Internet
Connecting hp photo smart 7350 printer to northgate computer
You need to install the driver of your printer that works with the operating system of your northgate computer. The driver is in the CD/DVD that came with your printer.
After installing everything, you can add RadarSync to your computer to optimize your computer's driver (eg. keeping them updated to avoid from some problems, and running automatic updates so that you can avoid from the headaches of doing the updates manually).
I hope this helps.
If you need more info, please let me know.
Carlo
Jan 23, 2013 | Northgate Computers & Internet
Hi I might have downloaded something wrong on my PC, or did something wrong to my flatscreen since every time I shut down for my PC and turn it on again it shows Auto Config in red letters. I didn't do...
Boot up your computer and once it is loaded to your windows desktop, using the image below press and hold the #1 key for about 3 seconds and it will auto adjust the monitor for you. I hope this helps.
Jun 24, 2010 | Acer AL707 17" LCD Monitor
I have a northgate stax2517c2 desktop. I crashed ...
yes. it does need the driver. please download the driver for your network card and install it to your computer then test.
May 20, 2010 | Northgate (STAX2517C2) PC Desktop
The mother board on my Northgate computer has gone to a better place. There is something that has gone bad and it never really loads up and gets into windows, it is stuck in some type of loop where it...
This motherboard is a SIS chipset socket 478 motherboard. I dought that this type of motherboards are in production. Chk if there are any refurbished computers stores that might have or chk ebay for Sis 651m chipset mothersboards. it will work with you pc
Mar 28, 2010 | Computers & Internet
I have a northgate WALAMD200A, the power went down and now it refuses to start up, cutting off in a few seconds and restarting. It goes to screen asking if Normal start up or safe start up but my key board...
Unplug it and wait a bit, then retry.
If it fails again:
-an internal fan might be stuck, causing the thing to shut down out of caution
-the BIOS battery might have given up the ghost
-a chipset heatsink might have fallen off and need some care
-the power supply might be toast (swap for a good spare of adequate wattage and retry)
-maybe your videocard just got unseated because of cable buggering, just set it back
Nov 11, 2009 | Northgate (walamd240a) PC Desktop
Monitor doesnt reckinize that the hardrives on
try taking the ram chip out then see if thats the prob by turning on the computer without it if its not, try unhooking the cd drive and then try turning on the computer if thats not it then try unhooking the hard drive and check if thats it one of those should be the problem i had the same prob but i messed with the ram chips and it worked i just took it out started it up and it worked if thats the prob just start it up then shut it down and put the ram chip back in and it should be fine
Jun 10, 2009 | Northgate (STAX2517C2) PC Desktop
Hard Drive Data Recovery
you can download mrecoverxl and try it your data from both the partitions will come in one partition, and your computer will start without instaliing your os too
Nov 07, 2008 | Northgate (STCAX30X) PC Desktop
Computers & Internet Logo
Top Northgate Computers & Internet Experts
Lee Eismann
Abhinandan  Patil
Abhinandan Patil
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
