Question about Lexmark X4270 All-In-One InkJet Printer
Paper jams in Lexmark X4270
There is no paper inside the machine. The paper simply curls to the right when I try to print. The paper never gets through and I'm really ticked about this! If there are dislodged parts, I have no idea where to check for them because it did print the first page before it jammed!
  • lolstairs1 Dec 03, 2008
    Me too, I have a very important project due soon and I can't get it to print
  • Anonymous Jan 14, 2009
    ya, its not user servicable at all. you can't even get to that part of the fax/printer. Its time to get a new one.
Mine is doing the exact same thing and I need to know how to fix it, I am expecting some very important paperwork and I need the fax machine working!
Posted on Aug 27, 2008
X4270 paper feed jam
You may have remnants of torn paper left in the feed rollers or beyond -from a prior jam. Other causes include:
  • Overheating
  • Wrong Paper Type
  • Printing Labels
  • Cracked or Dirty Rollers
  • Use of Wrong Tray
  • Incorrect Loading of Paper
  • Paper Overload
Nov 21, 2013 | Lexmark X4270 All-in-One Multifunction...
Paper jam
it is needing a hard reset sir.
nothing big
Apr 21, 2008 | Lexmark X4270 All-In-One InkJet Printer
My pinter is an X4270. It prints well, but will not feed the paper to fax, scan or copy. I keep getting a clear paper jam reading, but there is no paper jam.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 07, 2011 | Lexmark X4270 All-In-One InkJet Printer
Paper jams in the feeder on the left side , tried to opentop cover does not allow me to open back. how do I GET THE ROLLER from curling the paper?
One reason for paper jams is due to some obstructions in the paper path. Remove the sheets of paper from the feeder. Grab a flashlight and look into the paper feeder. Clear the feeder from any foreign objects or debris that could cause "curling" of the paper. If feeder is clear, open the printer cover and ensure the paper path is clear in the cartridge area.
Unplug and replug the printer into the power source to reset it. When the printer turns on, try to print again. If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Jul 28, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Paper curl
When a paper jam occurs, the printer will stop printing and the Continue (1) and Paper Jam (2) lights on the operator panel will come on. See the illustration below.
pattlnk_1052005_1635-enus20238_oppaneljamlights_e230_en_us.gif When you experience a paper jam, it is recommended that you check and clear the entire paper path. To clear a paper jam, do the following:
  1. If you are feeding paper from a paper tray, first remove the tray. Look for and remove any jammed or damaged paper you find.
  2. Open the front cover and remove the print cartridge assembly.
    IMPORTANT!
    Do not leave the print cartridge assembly exposed to direct light, especially sunlight, for an extended period of time. Extended exposure to light will damage the green photoconductor roller and cause print quality problems.
  3. Remove any paper you find jammed in the area behind the print cartridge assembly.
  4. Also lift the flap at the front of the printer and remove any paper you find jammed beneath the flap.
  5. Open the rear exit door/cover of the printer and remove any jammed paper you find there.
  6. Once you have confirmed that the entire paper path is clear, reinstall the print cartridge assembly. Close all the printer covers/doors. Reinstall any paper trays you removed.
  7. Press the Continue button to resume printing. NOTE: The printer should reprint the page(s) that caused the paper jam.
  8. If the paper continues to jam, press the Continue button twice quickly while the Continue and Paper Jam lights are on. This will cause the operator panel to display the secondary error paper jam light sequence. The secondary error code will tell you where the printer thinks the problem has arisen. For more information, see the 'Secondary Error Codes' section on page 69 of the User's Guide.
Sep 04, 2008 | Lexmark E232 Laser Printer
Lexmark x4270 paper jam
Have you looked inside the roller assembly. More often then not a small piece of paper will get stuck deep inside the roller assembly. This will lead to paper jam errors. Inspect more closely. You will probably find some tiny tidbit somewhere.
Dec 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
X4270 lexmark printer hook up
I have a lexmark X4270, I'm having a problem with the fax machine, the display keeps displaying "clear paper Jam", however there is no paper jam. I'm also not being able to recieve or send any faxes. I'm low on ink, would this prevent sending faxes? Any suggestions?
Nov 06, 2007 | Lexmark X4270 All-In-One InkJet Printer
Help
check inside around the rollers as it sounds as if there is paper caught in the mechanism causing it to jam.
Jul 30, 2007 | Lexmark X4270 All-In-One InkJet Printer
Paper pull only fron the right side
You may have a jam insude the unit. Open it up as if you are replacing cartridge, check everywhere for a tiny paper jam, with a torch, near roller, carriage etc. good luck xxx lilacgerry
Dec 30, 2006 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
