Question about Dishwashers
Hose keeps popping off the faucet - Dishwashers
  • 135 Answers
You may not have the correct adapter on your faucet...also make sure the lock is tight to the sink....ut a little grease in the fitting to make sure its lubricated properly
Posted on Aug 27, 2008
Very low flow on this single lever kitchen faucet how do I solve this
check the strainer in the tip of faucet the screen my be stopped up if that does not help try removing the water restricting water saver in the screen assembly it can be removed allow more water pressure usually these usually screw off the end of faucet if it is a faucet with built in sprayer remove sprayer faucet head from the hose and remove it from end of hand held unit it will pop out
Sep 30, 2015 | Plumbing
How do you remove the spray head from the supply line on a Grohe Ladylux?
Ok not sure what you are asking , but here it goes. If you are wanting to take off the sprayhead simply pull the sprayer out and unscrew. If you want to remove the spray hose from the bottom of the faucet simply grab the red spring loaded connector near the TOP, and pull down spring to release (kind of works like an air hose quick connect). If you want to remove the arch the hose must be removed from the faucet first, then simply jerk up on the arch to remove. When the arch is removed, there is a specialty tool that came with the faucet (which most plumbers keep) to tighten or loosen the faucet. Hope this helps. Luckydog
Jun 03, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Kohler style k12172 fairfax when i use the side spray there is very little pressure & the hose and sprayer are new and the hose has no bends in it.
you have an other part that went bad. Inside the faucet there ins a part called a devertot that is in the body of the faucet. This little part move the water from the main spout to the hand held sprayer.
You have to remove the handle and the spout. pop it out pop a new one in and you are good to go.
Glad you came to us for help. your rating us help us know how well we have done
Tom
Sep 09, 2011 | Kohler Fort© Single Lever Handle Kitchen...
The hose head keeps falling away from the unit. It should stay pushed in
Has no hose weight or not heavy enough weight on hose under sink. either buy a weight and install on hose about 18" from the bottom of sink. or you can use a 3 ounce fishing sinker with bread tie and tie it around hose aprroximately 18" from bottom of sink. It needs the weight to keep the faucet head in.
Aug 31, 2011 | Grohe Plumbing
How do I remove the spray hose from the brass connector under the sink?
On the side of the brass there should be a clip or a pin that you can pop off... a knife or screw driver will work to snap it out of there... then the hose will just pull down out of the fitting...
heatman101
Sep 03, 2010 | American Standard Kitchen Faucet 6310 020...
Hose comes off of the faucet
A quick easy fix would be to get a hose clamp and tighten it down on the hose to keep it from popping off
Jan 24, 2010 | Kenmore 17252 Free-standing Dishwasher
Good morning my plummer put in my new 980t sd -dst touch 20 faucet....it works so far....however my pull down hose i have to some what push it back up for it to go in......on the video it looks like it...
If you can, look up under sink for hose attached to faucet. There should be a weight on the hose, to assist in retracting it. Usually just a bolted on round lead weight that wraps around the metal sleeve of the hose. Perhaps he forgot it, or it needs to be moved/adjusted by loosening off the bolts that hold it together and sliding it up or down the hose. He may have even routed hose wrong. Have someone pull it out and slide back in while you watch it.
Jan 22, 2010 | Delta 989-SSSD Allora Kitchen Pull Down...
My hose sprayer isn't working well..water barely comes out but comes out okay from faucet
it sounds like it's cloged with sedement or somthing. try disconnecting it and cleaning it
Aug 08, 2009 | Kohler Fairfax Single Control Lavatory...
Popping while removing Hose Adapter
Are you sure the adapters are installed in the correct direction? To release the pressure you could turn the water off, and then turn the washer on. The residual pressure will be released. Then you can turn the washer off and remove the hoses.
May 06, 2009 | Haier HLP21E Top Load Washer
Dishwashers Logo
236 people viewed this question
Top Dishwashers Experts
