Question about Casio Cassiopeia BE-300 Pocket PC
BE300 and PC Connect
I have a Casio BE300. I'm trying to get the PC Connect program to work so I can syncronize with my pc and also download programs and mp3. It worked the first time and I was able to get my contacts and calendar from outlook. Ever since I am told it is not connected. I have gone by the book and disconnected and rebooted. Uninstalled PC Connect and Installed the new version from Casio. My friend had the same problem with his and never pursued it any further. Has anyone else had this problem?
    Master:
  • 551 Answers
If you have active synch installed you can temporarily disable it. Right click on the greyed out icon in the taskbar & select "connection settings" Uncheck the "Allow serial cable...." Click Ok. This will release the serial port for use by PC Connect. See if your com port selection is correct or if another application is taking it over in the background. There is also an issue with the cradle supplied with the BE300. Casio has corrected this problem by replacing the PCB inside the cradle with a revised one. If all else fails contact Casio for free repairs.
Posted on Sep 06, 2005
    Master:
  • 551 Answers
If you have active sync installed it will stop pc sync from operating properly. If you don't have active sync on your system then go to the below forum and do a search for info on syncing. There are issues with pc sync that have been remedied with some updates.
How to connect pc to casio se-c6000 cash register
Question is how to connect PC with Casio SE-C6000 Cash Register. Answer is very easy and simple. This ECR is POS system and has capability of FTP . Download any FTP software from net. Go to ECR program 3 . Press 798 and sub Total Key. enter local network area unique IP address for this ECR starting with 192.168.1.10 as( 192168001010) an example and must be not conflicting and within the range of local area IP Adresses. then press CA/Amt. Key. then 255255255000 for sub mask and press CA/Amt Key again..Then 192168001254 as gate way then press CA/amt Key again and sub Total Key to finalize. Connect PC with network cable in RJ45 slot on ECR. Turn the mode key on Reg Mode for normal operation. Now on FTP software which is already installed on your PC open and put host ID IP address of your ECR. User Name is "SCTHRD" and Password is : "OTTFFSSENT" then Enter . You will see all program of ECR in folders. I hope it will help your need . Ibrahim Azhar
Apr 01, 2012 | Casio Parts Cash Register PC Desktop
Is there any software to connect tk 1550 register to pc for programming and downloading daily journal?
Good luck if you can find any software for downloading the journal. I have tried several packages and none of them worked. Maybe someone else has had success and can tell crzyglue which software they used. You do not need programming software as the machine can be programmed through its own keyboard, but if you want to buy software, the dealers have it available. Look one up in your area.
Feb 07, 2011 | Casio Parts Cash Register PC Desktop
Trying to hook up BE-300 to laptop with vista. Doesn't connect
Casio Be-300 does not work with Vista Period! There are some programs online that will "reprogram" your devise. Try "eXpod".
Nov 02, 2009 | Casio Cassiopeia BE-300 Pocket PC
Can I hook up my Casio keyboard up to my PC (CTK-551)?
if it has a headphone jack on the back of the keyboard then there is a cable that you can buy and put it in the microphone input. Another ideas is to try krystal media it is a free recording program.
Mar 24, 2009 | Casio Portable Keyboard Touch Sensitive...
Be-300
The password is an easy thing to get rid of. The problem is, a full factory restore is required. First do a hard reset and then restore the BE300 to factory defaults. The password will be reset.
Hard Reset: Press and hold the Power Button. At the same time, press the rest button on the left side of the device with the stylus (pen). You will see a blue scroll saying Initializing. Press and hold the OK button. Once the Initializing is done, the BE300 will go into the Safe Mode screen. Press OK and follow the instructions to the Restore Screen. From here, you can perform a Factory Restore but you need the original CD or a download of the Factory Restore BIN file.
For full BE-300 support, go to www.be300.org It's dedicated to the BE300 and everything you will need is there.
May 19, 2008 | Casio Cassiopeia BE-300 Pocket PC
Help!!!
The BE300 uses PC Connect and will not work with Activesync. All the original software and upgrades are available at www.be300.org
Dec 12, 2007 | Casio Cassiopeia BE-300 Pocket PC
Connecting to a Linux machine
Have you ever heard of wine? You can install wine for free and see if the program that allows you to interface the device to a PC will work. There also could be some linux programs that will allow you to connect your pocket PC to your PC.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
Casio pocket pc calendar doesn't show appointments that were syncronized from outlook: If I sync with outlook, the appointments I add on the Casio E-125 show in outlook, but the ones I add in outlook...
The Menu: VIEW - Categories option at the bottom, has all categories checked off. However, the logic dictates that it will only show the categories checked off, and if any appointment (appointments being made in outlook are not categorized) with no category would not show in the pocket pc. The logic written into the software, is, if no categories are checked off, then it will show ALL appointments. It would be nice if there was an option in the category view menu to SHOW ALL, but there isn't. You just have to uncheck all the categories.
Sep 05, 2005 | Casio Cassiopeia E-125 Pocket PC
Casio Cassiopeia BE-300 Pocket PC Logo
124 people viewed this question
Top Casio Computers & Internet Experts
k24674
Sunil Pratap Singh
Sunil Pratap Singh
Joseph Hoffmann
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
