Question about Samsung HLP4663W 46" Rear Projection HDTV
Samsung Color Wheel
Did you ever find a solution to the color wheel issue on your Samsung? I replaced my color wheel and have some issues with my colors going on. Did you remove the jumper? Did you change any settings? Thanks!
    Scholar:
  • 65 Answers
Here's a good article on the Color Wheel
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
It says if your red and blue colors are reversed removing the jumper should fix the issue.
Posted on Sep 04, 2008
I replaced my Samsung hln567wx color weheel about a year ago due to the tv making an odd sound. Changing the color wheel did fix the sound but after a year has past the picture is replacing all red with...
Tv have colors flashes back and forth some time u get a normal pictures again?Yes,u must take the tv aparts than check the colors wheel again.Check it out it condition only don't touch the colors wheel itself.U have compression air machine blow some light compression air into tv colors wheel it self might have acumalate dust on the wheel,don't solved the problems.Might have to change the colors wheel again.
Aug 27, 2011 | Samsung DLP HL-P5663W 56" TV
Originally got blinking lights to indicate a bad bulb. Had a spare bulb that I installed. Now a very loud noise from color wheel and only a black and white picture.
Bad color wheel is cause of noise and black and white picture in tv, please replace color wheel to solve the issue.
Required color wheel is available in SamsungParts for $120
Thanks.
May 13, 2011 | Samsung HLM507W 50" Rear Projection HDTV
MY SAMSUNG DLP MN HLP6163W PICUTURE HAS FADED
If you have had this unit for awhile it could just be the lamp. If the image does'nt brighten up you may have an issue with the light path. The color wheel produces the color. If there was an issue with the color wheel you would most likely have a black and white image.
Jan 24, 2010 | Samsung HLP6163W 61" Rear Projection...
Samsung DLP Facial Colors off after changing color wheel
Do you mean that red and blue are reversed? If so, you may need to remove a jumper, see end of linked article. Pinkish-yellow or orange sounds like a good description of skin tone, but perhaps too intense. If the color is too intense, can you just lower the color level with the color control? Or can you just change the tint with the tint control? Otherwise, see http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/ including the comments at the end.
Oct 11, 2009 | Samsung HLN4365W 43" Rear Projection...
Adjusting color after color wheel replacement samsung dlp tv
There should be a jumper somewhere around the color wheel. I am having a problem with my color wheel, and after doing a lot of research I found that people that have the same problem as you changed the jumper setting. Try looking it up here on the net. Should solve your problem.
Mar 21, 2009 | Samsung HL-R4667W Rear Projection...
Color Wheel problem
Replacing the color wheel can sometimes switch Red With Blue. If you remove the jumper it could fix the problem.
Here's an article on it's replacement.
Aug 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung dlp color issue
I just had a service tech out and replaced the color wheel. now i have the same issue with the color...the people all look blue. He told me that now the the digital board is bad. It's the board were all of the connections go. I'm not convinced, as I remember reading something about color settings needing to be adjusted after color wheel replacement.
Mar 28, 2008 | Samsung HL-P6163W 61" TV
Color problem
Samsung color wheel fix
Jan 13, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLP4663W 46" Rear Projection HDTV Logo
213 people viewed this question
Henry  Thomas
Henry Thomas
