Question about Dishwashers
The hose to my portable dishwasher keeps popping off
I just got a new(used)portable dishwasher. I have it all loaded up, but the hose keeps popping off EVERY time I turn the water on HEEEEEEEELP MEEEEEEEEEEEEEEEE
  • 10865 Answers
SOURCE: connector keeps popping off
hello. go to this link and learn more about these connectors than anyone on your block
http://www.appliance411.com/faq/unicouple-repair.shtml
Posted on Oct 07, 2009
  • 641 Answers
SOURCE: Dishwasher isn't draining
It could be the pump, but not only. Check first that you don't have any clog in the drain line. If drain line is clean, open machine's rear panel and : - Look if the pump works. If it doesn't work check that pump get power (with multi-meter). In case it get power (and does't work), it should be replaced. - In case the pump works - The machine has a drain valve with an electric solenoid (the drain pipe connected to it). When it get power the valve opens and diverts the water to the drain line. Test that it get power. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck !
Posted on May 29, 2006
ranger25
  • 72 Answers
SOURCE: Portable Dishwasher
You have to have a good seal. Get a hose washer from your local hardware store and replace both of them on the hose if they are like a garden hose. If you still don't get any water to the unit, post again and I'll step you through it.
Posted on Jan 28, 2008
  • 4 Answers
SOURCE: Maytag portable dishwasher is not draining
try to clean the filter by taking off the bottom section of the water jet, it might be clogged, if that does not work, u got the same problem as me, it just wont drain. The pump is probably broken.
Posted on Feb 22, 2009
  • 10865 Answers
SOURCE: Kenmore portable dishwasher not draining
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Posted on May 28, 2009
I have a Kenmore portable dishwasher. The sink connector(not the adapter, but the white connector that has hoses attached) spits water out of the bottom during it's entire cycle. I have used other portable...
I think that the valve assembly in the end of your attachment hose is having problems, check with Kenmore and see if a replacement one is available and if your dishwasher is new enough perhaps it might be under warranty?
May 31, 2014 | Dishwashers
Kitchen faucet quick connect adaptor like portable dishwasher, read on
You can't find a portable dishwasher connector? Try an appliance parts supplier.
May 17, 2014 | Plumb Pak Faucet Adapter
GE portable dishwasher connector hose slips off faucet adapter
Google your dishwasher you will see parts on line There are loads just looked .
Apr 13, 2017 | Dishwashers
An internal 'hose' blows when dishwasher is used.
Hello. go to the site called sears parts direct. put in your model number and u will get an excellent schematic showing you exactly how it goes together. j.
Jul 22, 2010 | Whirlpool Dishwashers
Hose comes off of the faucet
A quick easy fix would be to get a hose clamp and tighten it down on the hose to keep it from popping off
Jan 24, 2010 | Kenmore 17252 Free-standing Dishwasher
Connector keeps popping off
Oct 07, 2009 | Dishwashers
Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Jul 27, 2009 | Haier HDP18PA Stainless Steel...
Kenmore top load portable washer, model 110.42722200
i had same prob. at my daughters house, similar model. first time a hose popped off the top(i removed the lid), later i noticed leaks because my son in law was using oxy clean and it foamed over. my advice is, put machine on its side and look for loose/popped off hoses, dont use too much soap or additives, which will trick the water level sensor or just pour over that little drum
Jul 16, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Snap on fitting no longer stays on faucett
go to www.searspartsdirect.com and you can search by your model number for the dishwasher or any other kenmore part. The schematics magnify as you mouse over them and then you can scroll down to see the matching part number. The part 3378117 is the whole hose assembly including the faucet coupler and the full length of the hoses. Notice that the part number 3378117 has been substituted with W10217197. When I Googled for "W10217197 dishwasher" there were a number of vendors selling that part including ApplianceZone.com selling it for $20 less than Sears and other vendors. Unfortunately the way the faucet coupler is crimped onto the hoses you have to replace the full length of hose [not just the coupler] but I have a problem that requires the whole hose. I've opened the cabinet up - which required a star headed driver - and from there it's just a matter of removing basic connectors inside the box.
May 26, 2008 | Kenmore 17459 Free-standing Dishwasher
Dishwashers Logo
779 people viewed this question
Top Dishwashers Experts
