Question about HP DesignJet 1050c InkJet Printer
CHAT RE: according to the specs, the printer does not support RAW data.
  • 10 more comments
  • Randy Villalobos
    Randy Villalobos Aug 27, 2008
    You need to send to it using the following languages:
    HP-GL/2, HP-GL, HP RTL, CALS G4 1055cm
    Plus (36-in): plus Adobe PostScript 3
    If you need more assistance on the types and explanations about these languages, ask me.
  • Randy Villalobos
    yes or a open source program that also supports the printer.
    NOTE: the Printer did not come with this program in the box. You have to buy it separately.
    this is an excerpt from the web site:
    "Can't print HPGL/2 or raster files on HP DJ 100, 110, 120, or 130 ?
    The HP Designjet 100, 110, 120, and 130 don't ship with the ability to process HPGL/2 and raster files. When you try to send these files directly to one of these models, you get errors on the printer. Most of the time, the printer simply ‘reboots'. Now what do you do? You've got all these HPGL/2 files that can't be printed on these devices like the older HP Designjet models."
    So you cant print from windows right out of the box.
    Im searching for open source (it means free) software that supports your printer and the languages.
  • Randy Villalobos
    Ok, I've found a few programs. unfortunately, they are not completely free. Does autocad 2000 offer importing pdf's in the file menu? If so, Just save your pdf and open autocad. go to the import option and go to the pdf that you just saved.
    Im now searching for pdf to CAD converters.
  • Randy Villalobos
    so you say that AutoCAD prints good to the HP.
    Its just the WinPrint that is not able to print to the HP.
    And you have already updated all of the drivers for Windows, as well as for AutoCAD.
    do you have administrative privilages for both the computers and the server?
  • Randy Villalobos
    Your printer has either the HP-GL/2 settings configured wrong or the HP-GL/2 controller (chip) is defective.
    The HP-GL/2 controls the vector graphics (images, attachments, etc).
    On AutoCAD, in the printing settings, check anything that uses or enables HP-GL/2. I know there is a setting in AutoCAD 2007 and 2008 that says "enable support for HP-GL/2". but you have AutoCAD 2000, so it may look similar to this option.
    Also, look for this setting in the actual Printer and the properties page of the printer (where you setup the ports, set is as default, etc.)
    While you are there, list the supported print processors and the default data types.
    The page looks like this:
  • Randy Villalobos
    thank YOU for the opportunity to work on CAD again. Its been a while.
    Will check back later in the after-noon (8/27).
  • James A May 11, 2010
    If this turns out to be the solution for the missing image in AutoCAD, then the remaining missing pdf - jpeg issue will require a RIP, no?
    Sleep on it. I'll try the AutoCAD solution in the morning and let you know.
    Thanks for your patience and help.
    Jim
    Correct. AutoCAD drawings print with great accuracy and speed. Microsoft Project 2000, PowerPoint and Microsoft Word all print as well. Yet any image, either by itself, as a pdf, or embedded in a document or drawing is ignored. By themselves, as a pdf there is no plot whatsoever. When embedded I get everything but the image regardless if it is pdf, jpeg et al.
    I am the administrator for all, there is no server.
    Importing images into AutoCAD is a two file process regardless of file extention. The AutoCAD file .dwg (vector) and the imported image file (whatever) and it's location are to this day maintained seperately, even so, small raster files (maps / scans etc.) would plot on the old HP 750 series machines. My 1050c won't. Incidentally I talked with ZEH last week and they indicated that they had a deal with HP to provide their RasterPlus RIP with the 1050c back in 2000 under an agreement that is still in effect to this day which prevents them from providing replacement copies. Weird, HP doesn't manufacture or provide troubleshooting or Tech assistance to this machine any more, so I guess they want all of us 1050c pilots to buy new, or we're stuck. When I run an AutoCAD plot with an inserted image on my Epson it runs perfectly.
    One hundred thousand thank you's.
    So where we're at is I need the ZEH RasterPlus RIP that HP used to provide with these machines when they were new?
    If the RAW type is not supported, what is?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
True. RAW is not a single format, but a generic term used to describe the raw data captured by camera sensors. Various camera manufacturers use different formats for this data.
You generally don't want to print the raw data anyway. That's because the raw data doesn't incorporate any of the sharpening, contrast adjustments, etc., that are applied to make the JPEG image. Use a photo editing program to make the adjustments, then convert to a format suitable for printing.
Posted on Feb 21, 2010
My pen drive is in RAW file system, I ca'nt open or format it.
Try to get a software called parted magic. its linux based and you should easily format the pen drive.
U can also try HP USB Disk Format Tool.
May 28, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Raw data printed, no formatting
If you create the data file in notepad, you're doing one step too many.
If I print the word HELLO in Notepad or Word, and then send it through the ncielabel drivers, you should get a label with the word Hello.
If I create the datastream with the printer's native language, you'll get all of the raw data because the driver is trying to print exactly what is on your notepad or Word page.
If you want to send raw data to the printer, you do not need to use a driver. Send the data to the IP Address or the Com port in question.
Avery Dennison, the folks that own Monarch/Paxar, have a utility that will allow you to send your notepad file either tcp/ip or through a com port. Go to: http://www.monarch.averydennison.com/support/servdocuments/Software/Toolbox/TBX1D.exe
If you're unable to figure out how to use the Help section to help you send the file through tcp, call 1-800-543-6650, option 7 for their tech support. This number and option is valid as of June, 2010.
Oct 05, 2009 | Paxar Monarch 9855 Printer
Cant Format pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Oct 01, 2009 | Transcend (589307) Media
My canon EOS 40D with 18 - 55 IS , when continuous shooting mode is selected, slows down after taking 6 shots. However as per the spec its capable of taking 75 jpegs or 17 RAW images.Please resolve this...
Slow down after taking 6 RAW files ...
A RAW file is Approx. 12.4MB.
The memory usage is approx. 74,4 MB
The internal memory (Buffer) has a size for up to 75 JPEG compressed images.
Which size has the smallest jpg?
JPEG/Small: Approx. 1.2MB (1,936 x 1,288)
The Buffer is approx. 80 MB.
The data are calculated under Canons laboratory conditions.
The maximum Burst (the 17 shoots) means that the camera is writing to the card and the buffer is full. Than the cam will stopping taking pictures.
Which kind of Card do you use?
Check the spec for the card (write speed) and maybe buy a faster card.
Jun 07, 2009 | Canon EOS 40D Digital Camera
My usb flashdisk become raw data
1). Do not format this hard drive before you've recovered all your stored data back. In your case, the formatting process may erase everything on your drive and make your data gone permanently.
2). Never save anything new on this drive in case that any new file would rewrite your original data.
3). Plunge this drive to your computer and download a RAW drive data recovery freeware to get back all your lost data back:
http://www.freeware-fix.blogspot.com/2013/02/raw-hard-drive-recovery.html
This hard drive has helped many people around me restore their inaccessible data back from a RAW drive or memory card. It can also work perfectly on your drive.
Read more detailed information of this freeware here:
http://blog4mark.blogspot.com/2012/10/help-external-drive-became-raw.html
4). Save and back up all your restored data on another drive in case of data recovery failure.
5). Format this drive to see whether it is fixable.
Dec 16, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Can't print from a Visual Fox Pro application with raw printer processor
The Report sent to printer should be in a recognised fonts and formats. If It work on other applications like word excel then you need to solve this through ur programmer of Visual foxpro reports.
Best Regsrd
Rafique
May 10, 2007 | Samsung ML 2010 Laser Printer
HP DesignJet 1050c InkJet Printer Logo
158 people viewed this question
Ben Johnson
