Question about Casio Cassiopeia E-115
HELP: Activesync XP Reboot Problems!
From what was a working XP to Casio E-115 sync installation, I first could not syc, and now on merely launching Activesync 3.5 or 3.6 my Win XP Home computer reboots. I tired numerous un-install re-installs and registery clean outs; safe mode installs etc. Still, on merely launching Activesync 3.5 or 3.6 my Win XP Home computer reboots. Any steps to remedy this? Thank you in advance for your prompt help in this regard. Murray Kerdman
    Master:
  • 551 Answers
Now don't laugh :-) on win 98 windows - I'm told - had a certain limited ability to fix itself. I don't know if xp does or not. Anyway on 98 if you ran into a problem you could let it reboot three or four times without doing anything but booting and shutting down - it at times would correct itself. This was normally on boot problems, but it might do some good - don't know of anything else to suggest. In your case I'd try this then try running active sync two or three times without doing anything else. Anyway that would keep you busy till a good tip comes along :-)
Posted on Sep 06, 2005
How i connect to pc my HTC S 710 Mobile?
If your PC has Windows XP, you should have ActiveSync installed and running, in order to have a WM smartphone synchronized. Otherwise, if it has Vista or 7, WMDC should be used instead.
If you already happen to have the correct sync program on your PC, and yet, are unable to sync your device, firstly, reboot both your PC and device. If you keep unable to sync, try to remove the partnership between your PC and your device on both of them, and try to connect your device again. If the failure persists, try to uninstall and reinstall ActiveSync (or WMDC), reboot your PC and try again.
Hope you are able to sort your problems out.
Cheers! Carlos
Apr 24, 2010 | HTC S710 Smartphone
Nao consigo conecta-lo ao cpu
English:
For Windows XP, the application which synchronizes devices is ActiveSync. On the other hand, for Vista or 7, it is WMDC, instead.
In case you still don't have the correct program installed, please follow this link.
Otherwise, if your environment seems to be correct, and you already have a sync partnership between your smartphone and PC, delete it on both of them, reboot them both and try to synchronize them again.
However, if you keep having problems, try to reinstall ActiveSync or WMDC, and reboot your PC.
Hope you are able to sort your problems out. Cheers!
Português:
Se seu computador é equipado com Windows XP, o ActiveSync deve estar instalado. Por outro lado, se é Vista ou 7, é o WMDC que se ocupa da sincronização.
Se ainda não tem o programa correto instado, poderá baixá-los a partir dest link.
No entanto, se seu ambiente já encontra-se corretamente arranjado, e já há parceria de sincronização estabelecida entre seu smartphone e seu computador, tente removê-la em ambos os equipamentos, reinicie-os, e tente sincronizá-los novamente.
Se o problema continuar, tente remover e reinstalar o ActiveSync ou WMDC, reinice seu PC e tente novamente.
Espero que possa resolver seu problema prontamente.
Um abraço!
Carlos
Apr 20, 2010 | HTC S620 Smartphone
IPAQ 1950 suddenly will not connect to PC to allow sync
Same problem, on four computers with two iPAQ 1950's. I installed ActiveSync 4.5, and all works fine now. This link will get you to AS 4.5:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/activesync-register.mspx
This SHOULD work for all PDAs, but I have only used it for the 1950.
Nov 11, 2008 | HP iPAQ rx1950 Pocket PC
Active Sync Installation not recognizing Outlook on PDA
Remove the Activesync software...reinstall it.
Thats the best and fastest suggestion I can give you.
I have the same problem off and on.
Nov 21, 2007 | HP iPAQ rx5915
ActiveSync Problems
If you tried it on two different desktops and you tried it after a hard reset, I would say that you have narrowed it down to a hardware problem. When you tried it on the two PCs did you use the same cable to connect it? If yes you might want to try a different cable or if possible you can you try a bluetooth sync? If a different cable or bluetooth doesn't work you probably need to have the device repaired.
Sep 11, 2005 | HP iPAQ hw6515 Pocket PC
Need help on connecting E-125
I doubt it... I mean it is unlikely there is any incompatibility there. Go to your device manager and make sure that your USB ports are installed and configured properly for your USB cradel.
Sep 06, 2005 | Casio Cassiopeia E-125 Pocket PC
BE 300 on xp home ed.
http://www.abfnet.com has a bunch of be'ers that can help you - you can also search the forum for ton's of answers. One thing, if you have Microsoft Activesync on your system pc connect won't work unless you shut off the activesyncs access to usb ports. Just a thought.
Sep 06, 2005 | Casio Cassiopeia BE-300 Pocket PC
EM-500 Conection Problem
Upgrade Activesync and the PC's USB driver. Then you should be OK once you upgrade Activesync to V3.6 and then get the latest USB driver for your system. Good luck
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
EM-500 sync problem
There have been issues with the cradle PCB on the EM-500. Casio has redesigned the same added an IC & a few additional componentes. I had similar problems & simply could not connect through the USB port. Worked flawlessly with the accessory serial cable (direct connection - no cradle ). This also was on an XP system. See if you can wangle out a free replacement/fix for yout cradle from Casio.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
Casio E-15 and Linksys WCF11
Well - if your PDA runs CE 2.11, it should install. Try downloading specific CAB file from Linksys's website for the MIPS processor (E-15 uses VR4111). If you have Linksys WCF11 card, go to http://linksys.com/support/support.asp?spid=71 If setup still doesn't work - copy a MIPS CAB file to your Casio via ActiveSync and run it from there. However, even after you install it - you might face problems. I still wasn't able to run my Linksys WCF11 on Casio E-100. Apparently, there is no easy way to specify IP settings (gateway, WINS, DNS) in Windows CE 2.11 for Linksys (unlike PocketPC OS, where we have network settings in control panel). I tried playing with registry - however, it messes up big time.
Sep 05, 2005 | Casio Cassiopeia E-15
Casio Cassiopeia E-115 Logo
80 people viewed this question
Top Casio Computers & Internet Experts
k24674
Sunil Pratap Singh
Sunil Pratap Singh
Joseph Hoffmann
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
