Home | Texas Instruments | TI-89 Calculator | Graphing
Texas Instruments TI-89 Calculator
Problem for Texas Instruments TI-89 Calculator
Graphing
By jeans_w on Aug 27, 2008
I need to know each key stroke to put the problem in to figure out how to graph.  graphing totally looses  me.  I just don't have a clue.
Solution #1
posted on Nov 05, 2009
Not Rated)
k24674
Rank: Guru  Office Equipment  Expert
Rating: 87%, 646 votes
It is actually quite simple. The calculator can perform severa types of graphing, but the most common is the drawing of functions defined by a relation of the form y= fonction(x), or y=f(x) for short.
The procedure is described for the TI 89 Titanium. It is valid for the TI 89 except if I enter the color of a key.
1. Before you start, you should set up the calculator to begin a New Problem. The command for that is accessed through the menus.
Press the [HOME] key to go to main calculator folder.
In Home folder, press [2nd][F1] to access [F6][2:NewProb]. Press [ENTER] to execute the command. Screen should display Done.
2. Press yellow [Diamond] key (it is the equivalent of the CTRL key in computers) then [F1] to open the [Y=] editor.
3. Use the keypad to enter your first function on Y1= line. Press [ENTER] when finished with Y1. This will select the curve to be drawn, and a check mark appears to the left of the Y, in Y1=. If there is no check mark, the curve will not be drawn. If that happens, move cursor on Y1= and highlight it and press ENTER.
4. Enter the next function. Press [ENTER] when finished.
Try the functions Y1=3*x+0.5 and Y2=x^2 -1.
5. Press the yellow [Diamond] key to access [GRAPH]. The cartesian screen appears, the calculator starts graphing. While graphs are being drawn, the indicator BUSY is displayed at the bottom of the screen, on the right.
Here is what your screen looks like.
6. If BUSY indicator disappears, graphs are finished. If nothing is displayed on the screen except the axes, the functions may be out of range. In that case you can adjust the window dimensions.
You can change the values of Xmin, Xmax, Ymin, Ymax, or press [F2:Zoom] to use any of the zooming options.
This is the basic procedure to draw y=f(x) graphs.
Hope it helps.
Was this helpful?
Yes
No
Popular Solutions for Texas Instruments TI-89
Questions and Unsolved Problems for Texas Instruments TI-89
Do you recommend Texas Instruments TI-89 Calculator?
Answer
Answer
If I try to make any graph besides a scatter plot, it locks up and it I haven't been able to get it... (More)
Answer
Half of the screen is black and half is well-lit. Editing the contrast results in one side of the... (More)
Answer
answer was tan-1(y)=x+@19 What does @19 mean?
Answer
when i installed the initial batteries, the calculator still had a blank screen. i adjusted the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Texas Instruments TI-89...:
Top Calculator Experts
Rank: Guru Guru
Solutions: 709
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Calculator Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
