i have a problem where the 'ok' button will not work. All other buttons are ok. Therefore the camera cannot be used to select any menu feature.. I am a tech. but in 2-way radio and GPS repair. I suspected a dry joint but this is not the case. The up, down, right, left button all have continuity to the same point but the 'ok' button is out of this loop.The button itself seems ok as there is continuity when pressed.Ideally i would like a circuit diagram but olympus will not provide me one unless i am a dealer and have quoted me $260 to fix, with a complete PCB replacement.Do you guys have any idea on where the problem may lie. If it is in the micro well i guess its all over but any assistance would be greatly appreciated.
The camera is in good cond. and only used a handful of times over 2 or so years.
Thanks in advance.
Brett
Instructions
Turn on the camera and rotate the shooting dial to one of the shooting
modes, such as auto.
Press the "F-Mode" button to adjust frequent settings like ISO
and picture quality.
Use the up and down arrow buttons to navigate between settings. Press
the right arrow button to present the available options.
Use the up and down arrows again to adjust the settings option. Press
the "Menu/OK" button to apply the change.
Exit the menu by pressing the F-Mode button again. Press the Menu/OK
button while in shooting mode to adjust less frequent options, such as white
balance and the auto-focus mode.
Use the up and down arrow buttons to navigate between settings, similar
to the F-Mode menu. Press the right arrow button to present the available
options.
Welcome to FixYa,
Hi I have here the steps on how you can update the date and time of your digital camera. You can chaged it if its your first time to set the date and then you also have here the steps if you want to changed it anytime you want.
Setting the date & time, first time
The Date and Time have been reset message appears the first time you turn on
the camera or if the batteries are removed for an extended time.
1 SET DATE & TIME is highlighted. Press the OK button.
(Select Cancel to set the date and time at a later time.)
2 Go to step 4 below, Setting the date & time, anytime.
1 Turn on the camera. Press the Menu button.
2 Press to highlight Setup Menu , then press the OK button.
3 Press to highlight Date & Time , then press the OK button.
4 Press to adjust the date and time. Press to advance to the next
setting.
5 When finished, press the OK button.
6 Press the Menu button to exit the menu.
Reminders:Depending on your computer operating system, Kodak EasyShare software may let your computer update the camera clock when you connect the camera.
I hope this steps will let you to resolved your issue.
Feel free to reply on this e-mail if this steps will work or won't work.
Thank you for using FixYa.
I have exact problem...please help.
I have the exact problem...please help.
