Question about Kenmore 63942 Dryer
Kenmore 63942 dryer
Dryer will only run if you keep the start butten held in.
  • jeffetter67 Sep 05, 2008
    Thanks for helping me with my problem.It was the relay.
    Genius:
  • 1,028 Answers
Remove plastic caps on each end of console by pulling forward at top remove screws in each corner pull console forward and roll back..locate small black relay with 2 blue wires and one with large red wires switch them if dryer works change the one that had blue wires originally if still not working may need to replace even heat board where all those wires go back to ..look for possible burnt spot on it
Posted on Aug 28, 2008
The start button on the kenmore 90 series dryer starts the drum but won't keep running
There is a relay which goes bad mounted in the control panel. Some times it is part of the start switch and some a separate unit next to it. Need model to prioperly advise.
Jun 03, 2014 | Kenmore 63942 Dryer
Dryer simply wont start, I press the butten and nothing happens. Does anyone know or think they know what the problem might be?
Well, it's most likely the centrifugal start switch in the motor. If you want more info on how to fix it yourself, please let me know. Otherwise, it'll need a visit by a service tech.
Charlie
Feb 12, 2011 | Kenmore 63942 Dryer
Dryer shuts off when I open door ,but timer keeps running
I had this same problem with my Kenmore dryer. If I left it plugged in and door shut it would eventually turn over and start up again. But now my timer is working properly but my dryer won't heat up and dry the clothes. I need help....
Feb 26, 2010 | Kenmore 63942 Dryer
Kenmore 80 wont start has power when start held
Hi, Sounds like you might have a safty fuse gone bad.
Get me the model# and I can help you further.
Thanks
Vic
May 16, 2009 | Kenmore 63942 Dryer
I have a kenmore dryer model number 110 63942101. When I start the dryer and set the time to 90 or 60 minutes within a few minutes the buzzer is sounding off as if it is finishing and the butten is moving...
This sounds like a bad timer assembly is bad, you can either call a tec, or if you think you can do it, i have posted the schematic below
for your model, part #3 is the timer,you can look at this drawing and see if its close to yours. This the Kenmore parts site. If you shop around,sometimes you can get it cheaper from someone else.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?diagramPageId=00001&documentId=P0203276&modelNumber=11063942101&productCategoryId=0151200&brandId=0582&modelName=&backToLink=Return+to+part+list
Apr 10, 2009 | Kenmore 63942 Dryer
Kenmore dryer 68972890 won't stay running
it sounds like a weak motor.you can also check the start switch if you have a meter,remove both wires and check it on ohms in the off an on position-mike
Mar 11, 2009 | Kenmore 63942 Dryer
Start but will not stay running
Some dryers have a broken belt micro switch mounted where a lever will stop the motor from getting into the run mode. They do this to keep the heater from catching fire. If your dryer is a DOT dryer (dryer of tomorrow) made by maytag for kenmore then it certainly has such a switch. If your dryer is a plain jane whirlpool manufactured one then you needs a motor replacement most likely friend. Sowwy.
Jan 29, 2009 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
61 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
