Question about Apex Digital PF3230 32" TV
Apex 32 inch tv Model #PF3230
Our picture is too large for the tv screen. We have directv and cannot see the left side of the guide nor can you view scrolling on the bottom of the screen. I have found the owner's manual and also purchased the service manual. I have tried the service codes I've found on the internet and in the service manual to no avail. (lowering volume to 0 and pressing mute on remote and either menu or video on the tv). Does not work. I also tried the full screen button on the remote. All that does is shrinks the screen but does nothing to change the problem. Can someone please help me? Thanks.
  • lsac13 Aug 27, 2008
    The only way I can reset the tv is by using the service code, and it won't work. My son had the same problem with his Magnavox tv. He found the service code online and fixed his immediately. I cannot get the "S" for service on my tv.
    Master:
  • 521 Answers
Its not the problem of service code not working for the tv.or any reset system is not supporting.its the problem of any faulty --ic-- or capacitor on the main board of the tv.just replacement is needed for that particular --ic-- or capacitor.you can do if you have a technical knowledge of checking the faulty --ic-- or capacitor.but i will suggest you to call a technician at your place to make it proper without any thing wrong happening.as the reparing will be very normal so the cost will also be very normal.rthis are the normal problem occuring due to to the faulty --ic-- or capacitor.so do not worry.your device is perfectly ok and work for sure after reparing.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Sep 03, 2008
  • 2,071 Answers
Do a hard reset. Unplug the TV and leave disconnected for 3 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.Take out all devices connection DirecTV,DVD or whatever devices. After 3 replug again the TV with the DVD only check if the trouble persist..
Hope this may help;
Regards,
VOTIT
    Sergeant:
    Champion:
  • 214 Answers
Reset the settings. refer the user manual
  • 157 Answers
Can you try connecting ur tv through another input ... maybe scarf or s-video or whatever other inputs their is
  • 6,487 Answers
Since there's no way top reset the settings of the television and the option to adjust the display is not working , definitely there's something wrong with one of the components of the tv and the adjustment must be done inside it...but if this tv is still under warranty better take it to servcie center or call Apex for this (800) 880-1227..
Hope that helps......
Posted on Aug 27, 2008
    Brigadier General:
  • 6,966 Answers
Might it be that the settings that has to be changed is the output of your DirectTV receiver to be compatible with the maximum resolution/capability of your Apex Digital PF3230?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • 89 Answers
Try to reset the settings of the tv. check the manual on how to reset it.
  • 1,512 Answers
G'day mate
Sounds like the power supply regulation has gone high volts, and the screen is blooming because of it. I suggest getting a tech to look at it, will probably have the usual issues of capacitors failing in the power supply. Cheers
regards
robotek
Posted on Sep 14, 2008
    Genius:
  • 1,226 Answers
try resetting your TV by unplugging from the wall outlet and then rest it for while and then plug it again and then test.
also clean all the button switch maybe it got sticky.
if this not You have to open the tv and adjust it manually.
melnavz
How do I order a part call flightback # BSC70Y #03508-5042 for a model PF3230 TV Chassis CH-16CD?
Its a flyback. Why would you want to fix it? Other parts may have gone also....buy a new set instead. Avoid this brand.
Mar 29, 2010 | Apex Digital PF3230 32" TV
No Power
There are many fuses within the unit. Is there anything at all that may suggest what happened? Any blinking or noises when you try to turn it on?
Jun 13, 2008 | Apex Digital PF3230 32" TV
Apex tv
should be inside the back cover on the left hand side toward the rear of the television
Feb 18, 2009 | Apex Digital AT3208S 32" TV
Moving Bars On Screen...
There is a large capacitor in the power supply section. it is rated at 820uf @ 200vdc. It is bad. Change it and increase the voltage rating to at least 250vdc. The tv will be fine.
Jun 21, 2008 | Apex Digital PF3230 32" TV
FLYBACK Transformer for APex 32'' Model #PF3230 Flat Part #BSC 70Y
Its not worth the repair if you still want to go ahead i need to know two things:
Are you going to have a qualified electronics technician fit it?
If you are planning to fit it yourself are you a qualified electronics technician?
If you answered no to both of these questions i cannot tell you where to get one or how to fit it due to the massive amounts of danger involved.
Feb 25, 2008 | Apex Digital PF3230 32" TV
Help to find flyback
you can purchase the fly back from systems innovation on half way tree road. they order it for you and it takes two weeks for delivery. cost eighty nine united states dollars and that includes shipping costs.
Jan 10, 2008 | Apex Digital PF3230 32" TV
Help for part number
Flyback Transformer L1479 030530-5282 Apex Tv. Model #PF3230
Nov 17, 2007 | Apex Digital PF3230 32" TV
Apex PF3230 TV with pincushion problem.
too dangerous for a home repair as this requires replacement high voltage components and adjusting the set with the back off while running.
Take to repair store.
Nov 08, 2007 | Apex Digital PF3230 32" TV
Apex 32" TV - Blue Screen & Channels keeping running/changing
blue screen indicares that there is a problem in blue cathode circuit. please check 1 blue video output supply. 2 blue video ckt defective 3 signal from chroma ic to blue cathode missing. 4 loose connector 5 crt base loose. 6 chroma ic defective. I think sound will be ok .
Sep 22, 2007 | Apex Digital PF3230 32" TV
Help
Not a home repair take it to a repair store.
May 24, 2007 | Apex Digital PF3230 32" TV
Apex Digital PF3230 32" TV Logo
1,091 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
