Question about Casio Cassiopeia E-100 Pocket PC
Casio E-100: Dead or alive?
I am new at this but I could use some help in diagnosing if my old casio has given up the ghost. It was on the cradle and I tried to make an entry when it appeared to be "locked up". I tried to reset it and it gave a low battery prompt. Usually I could go past this screen to my desktop. Now it goes to the Welcome to Windows CE screen where you initially set-up the device. It will not proceed past this screen. I assume that I have lost all information that was entered and now cannot even use the device. ? Can you help? Thanks. Jaguar
    Master:
  • 551 Answers
If you had synched the device you have all your data on the desktop pc so I wouldn't worry too much except for some software which may require you to enter the reg info again. You could try the following. Remove both the batteries. Install the main battery. Install the backup battery preferably a NEW one. Let the device charge to the full - until the green charging light goes out. Switch on the device. It should now behave properly. It would help if you generally avoid using the device when you get low battery warning. Especially the backup battery.
Posted on Sep 06, 2005
Battery doesn't charge
Try other lithium ion batteries and charge .. if everything goes fine the old battery is dead or else problem lies in the cradle
Dec 26, 2007 | Casio Exilim EXZ75 Digital Camera
My universal remote is not working on my TV.
Kind of hard to diagnose the problem with so little information. But, in most cases the battery(s) need to be replaced. Be sure that you face them in the proper position(s) as indicated inside the battery compartment. If the remote is over 5 years old, it probably has given up the ghost.These days, new ones are not expensive. Less than $10.00 at discount stores.
Feb 03, 2011 | Heating & Cooling
Everything works except the microwave function
yes there are fuses inside it,,,but,,,there is also a lot of volts still in it too, "ie, 1000's" and they bite too,
bit like a police stun gun will,,but they may not just stun you,,they could very well kill you,, so be warned!
also the fuses are not the normal sizes you would have at home, and some of them are "slow blow" type and some are "fast blow" type,,, and one is at least 1 to 4 1000 volts type?
and my gess is a fuse has poped becouse the magnatron has given up the ghost and poped its clogs!!! like its dead! and a new magnatron would be dearer than a new microwave to have fitted,,
so,,,get a new unit,,dont tinker with it and stay alive!
Jun 06, 2010 | Frigidaire PLMV169DC Microwave Oven
Don't know how to restore files from backup done with North Ghost
Using Norton Ghost 9.0 is very good program to backup your System & Documents.
You said the PC is dead then you want to restore back your System to a new PC.
All you have to do is that Norton Ghost 9.0 CD is Bootable.
Of course also your external hard drive are plug in it too.
Manually you're going to open that Sv2i file to restore back again your old system but there are some programs that are not going to use. Like for example: System Drivers (Motherboard Driver, LAN, SOUND, etc.) but at least you have the Documents and the rest of the programs run again.
I try it myself this kind of situation, I'm using Windows 2000 with Norton Ghost 9.0 version, and it's 100% works. Good luck!
Hope i might give you some tip & idea.
Tell me more about if you got a problem.
Please rate me.
Thank you.
Sep 04, 2009 | Symantec Norton Ghost 9.0 for PC
Camera won't turn on, won't charge.
I had this problem and read everybody response. Not convinced that my battery was flat I got out a MULTIMETER (Voltage tester) and measured the life of my battery.
Measurements confirmed that it had 3.9V across +/- terminals and 3.75V from T(-ve) to +ve terminals.
Ok odd - so I put the battery back in the camera and gave it another got, making sure I correctly orientated the battery. Press the ON button and low and much to my surprise my camera was alive again! Damn what did I do?
Before this the camera would not power on, and in the cradle it would not charge. However whilst in the cradle pressing the PHOTO cradle button would make images display and would give me access to the Sideshow menu. But that was it.
Now its as good as new. The above could have been coincidence however given the number of people with this issue I thought it at least worthy to report my experience.
Nov 25, 2007 | Casio EXILIM Card EX-S770 Digital Camera
E -100 Help
Casio had a cable that had a serial port on one side and a connector to the E-1XX on the other side. Activesync works through this: I searched on Casio E-100 sync cable serial in Yahoo. It found two hits for a cable under $40. That should allow you to install programs over your serial port. I have persoanlly only used Etronics form the list of two and they did what they said they would do. "Casio Cassiopeia E-Series Serial Cable Mfg Part No: JK580CA UPC Code: 079767693206 Product listed below is: Sort this table by: New from U.S. Distributor Vendor Rating SORT BY: PRICE | VENDOR RATING VENDOR SOURCE IN STOCK SHIPPING COST PRICE VENDOR RATING TheNerds.net DIRECT LINK Direct from Vendor 04/02/04 Yes See Site $31.86 4.5 out of 5 stars Etronics DIRECT LINK Direct from Vendor 04/01/04 Yes $9.14 $38.35 5 out of 5 stars "
Sep 06, 2005 | Casio Cassiopeia E-100 Pocket PC
Casio e-100 questions......help!
Are you trying to install programs that run on your desktop to the pda? If that's the case, you cannot do it. The softwares for pda need to be written and compiled for your particular cpu and os.
Casio Cassiopeia E-100 Pocket PC Logo
91 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Computer Links
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
