Question about Toshiba Satellite A135-S4527 Notebook
Not receiving power from ac adapter
When laptop turned on, turns off in a few seconds. adapter seems unable to recharge laptop. was told there is no way to recharge battery without it being inside laptop.
Mine had a bad wire in the power supply.
Posted on Aug 27, 2008
Laptop is turning on and off
Remove the AC adapter (Charger)
PROPER method is to disconnect the power cord of the AC adapter, from power; THEN unplug the AC adapter from the laptop.
Same thing in reverse to plug the AC adapter back in.
AC adapter is plugged into laptop, THEN AC adapter is plugged into power.
Unplugging the AC adapter from the laptop, while being plugged into power; can cause a Voltage Spike.
You may get away with it for years, and several laptops; and have no problems.
However it only takes ONCE, to fry out the SMD fuses, Multi-Layer Ceramic Capacitors, and Power MOSFET's, on the laptop motherboard's DC to DC circuit.
Jus sayin'.
Moving on........
AC adapter removed, remove the Battery.
Press the Power On button in, and hold in for a count of 10 seconds.
Let go.
Do this procedure 2 more times.
(Draining residual power)
Reinstall the Battery. Attach the AC adapter, plug AC adapter into power. Let the Battery charge 24 hours.
Then turn the laptop on, and tell me what happened.
Regards,
joecoolvette
Mar 15, 2013 | HP Pavilion Computers & Internet
We noticed today that the battery does not charge, nor will the laptop operate with only the power adapter connected. I've verified that the power brick is putting out the correct voltage. If I...
Check if the AC Adapter brick is getting warm when connected, if not then you need to replace the Adapter.
If AC Adapter brick is getting warm and still its not charging the Battery, please perform the following steps.
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Note: With an extensive use of the notebook, some times notebook would store some static charges which indeed will stop the notebook from powering up or charging the battery.
The procedure to remove this static charges from the notebook is known as power drain.
Performing a power drain procedure will not effect any personal data or delete any pictures from the hard drive on your notebook.
If issue persists, contact Notebook manufacturer for further support.
Oct 15, 2010 | Computers & Internet
It turns on for a few seconds then shuts off
Since you have already replaced the ac adapter. The problem is still there. the most likely cause of the failure is bad motherboard. Remove the battery from the laptop and disconnect the ac adapter . Press the power button for 10 seconds. Reconnect the ac adapter and try powering on the system. If the same doesnot work
Try the steps in the link
http://tinyurl.com/yd842up
Thanks for using Fixya
proton
Mar 15, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Battery empty message when connecting olympus sw 1030 to laptop
Your recharged battery may be weak. May be time to replace.
If the battery power runs out while the camera is connected to a computer or printer, the image data may be lost or damaged. It is recommended that you
use the AC adapter. Do not connect or disconnect the AC adapter while the camera is connected to a computer or printer.Do not remove or load the batteries or connect or disconnect the AC adapter
while the camera is turned on. Doing so could affect the camera’s internal settings or functions.
Sep 02, 2009 | Olympus Stylus 850SW Digital Camera
Unable to type in destination
Just recharge your battery using AC or car adapter.
Jan 23, 2009 | Nextar Q4-04 Car GPS Receiver
Toshiba satelite A100 rejects AC... often.
Just to humor me, are you using any peripherals with your laptop when this happens, such as a wireless mouse, USB connections such as digital cameras? Try to take these away when recharging.
There seems to be 2 issues here.
1) Recharing batteries: To prepare the batteries for long-term use (I do not know how long you've had the batteries...try draining the batteries (both of them), and then recharging it to full 2x before using them without the AC Adapter. This should clear the problem.
2) AC Adapter only works every other day: When you swapped the power pack, was it with a new AC adapter, or another used one? Also, have you tried using a different outlet than the one you normally use? Let me know how this turns out.
Nov 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite a100 wont take on power or boot
the battry is not charging and check the model of the battry whether its the same
Nov 16, 2008 | Computers & Internet
Hi when i turn my ACER 5315 LAPTOP on it runs for 5-10secs before turning off again please help thanks
We can try some work around to narrow down the issue.
I think your notebook might be getting power from the Ac adapter. The remaining power in the battery might be giving power for few seconds and trning OFF again.
To check this, once remove the battery from the notebook and turn on the laptop with only AC adapter.
If there is no power at all, then what I guess is correct. Issue might be with the AC adapter or with the power jack on the motherboard.
If the notebook turns ON even with the Ac adapter and turned off aftetr few seconds without battery, then you have to contact service center as it could be the hardware issue.
Aug 09, 2008 | Acer Computers & Internet
Toshiba Satellite A135-S4527 Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
