Question about HP Compaq nx9600 Notebook
My laptop turns itself off right in the middle of using it. I replaced the power supply, it seemed to help at first but now I am in the same place.
    Brigadier General:
  • 5,158 Answers
It is quit possibly thermal shut down... is the bottom of the laptop extremely hot ?
Robert
The solution is to remove as much of the case to give you access to the fan(s) and clean all the dust and dirt out
Posted on Aug 30, 2008
Cf51 wITH MOTHERBOARD dl3up1448aaa. When connected to the power supply smoke was seen coming form the power socket on the laptop. Disassembled the laptop and found just behind the socket on the motherboard...
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Sep 14, 2011 | Panasonic Toughbook CF-51 Notebook
The power button doesnt seem to be working
It sounds like a short in the button itself. If you have a soldering gun, take it apart and resolder the connection. This is typical for Acer laptops.
It's either the button itself or the jack where the power supply plugs in. It's not real difficult.
Jul 15, 2009 | Acer Aspire 5500 5570-2609 Laptop
Possible blown motherboard
you need a fully working battery as while you plug power adapter power light does not come on nor does the laptop itself turn on please check the power supply and its cord . If you have have not grounded the power supply third terminal this is possible that power is coming from body of your laptop.But check DC voltage output of power adapter. It should be approximately18 to 20 volts
Jul 10, 2009 | Panasonic Toughbook 19 Laptop Convertible...
Keeping the power on
I have seen that problem before, but on a desktop. I guess you have tried all the connectors available in your house. Hmmm! It think, not sure, but pretty sure, it is the motherboard the problem.
Nov 16, 2008 | Acer Aspire 3690-2196 Notebook
Dell Power Supply
You can test the power supply using a multimeter. I use a paper clip to get in the middle if my multimeter probe is too large. If there isn't any power but the light on the power brick is on (if there is one) then there is most likely a break in the cable. In any case turn to eBay for a replacement, should be quite easy and inexpensive to find. Or you could pay more and get one from Dell. Companies like APC and Targus make usniversal adapters but they're expensive and not optimal.
Jul 14, 2008 | Dell Computers & Internet
Samsung 40" LCD turns itself off and on
Try to tighten all screw around the power Supply to make a better ground ...
Jun 01, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
My laptop turns on and then it turns right off!!! HELP!
hi there
It seems your laptop computer is not cooled properly which might be beacuse of a broken cpu fan as you mentioned it makes loud noise.
The reason your laptop turns off by itself is because theres a circuitry built on the motherboard which power offs itself if the internal temperature raises, this is a safety feature to prevent your computer getting burnt.
Please avoid using your computer and take it to a shop where you can have it checked for cooling.
hope this answers your question
May 30, 2008 | HP Pavilion dv1000 Notebook
Won't turn on - dead dead dead
I since the problem is a stuffed battery ort else the power pack has ceased to exist. One thing is the way you have explained it seems the Laptop is ok try and find someone with a another powerpack maybe the battery ok it seems to me the pack has poked? Goodluck I wish all the problems seem simple like yours.
Sep 02, 2007 | Toshiba Satellite M45-S169 Notebook
Turns Off by itself
Causes for this problem can be any of the following:
1- CPU gets overheated. solution: clean dust from fan and heatsink assembly and donot forget to replace the heatsink compound, this is very important.
2- Memory problems. solution: use a program called MEMTEST86+ from the site http://www.memtest.org/ . It is a free and great program.
3-Power problem. By time the capacitors of the power supply gets dried. Causing them to not be able to fulfill power demands. solution: try working with power supply without battery. As the power supply has to run computer and charge battery. We reduce the load. If everything is fine. repair power supply by replacing deffective capacitor.
4-Battery problem. Try operation without battery.
5-Dried solders on motherboard or a component problem on the motherboard. Solution: no solution except replacing motherboard.
Eng. A. Jarabaa
Aug 28, 2007 | HP nx9110 Notebook
Printer Problem
power supply is probably faulty on the printer
Jul 11, 2007 | HP DesignJet 10ps InkJet Printer
HP Compaq nx9600 Notebook Logo
117 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
