Question about GE Advantium 120 Convection/Microwave Oven
Cleaning advantium microwave
How do I clean the interior of the advantium microwave combo? the turntable, glass plate and the walls seem to have burnt on food. Steaming and cleaning with all putpose cleaners does not help. Can I use oven cleaner?
  • 1 more comment
  • Anonymous Dec 21, 2008
    How do you take the top front vent off to get to the filter
  • Anonymous Dec 24, 2008
    Simply baked french fries in it. I have barely used the speedcook/bake function (only 3 other times) since I installed the unit in October, and I have stains in the rear interior of the microwave. GE sent me Ceramabryte, which has not worked. There are certain things like french fries that you can't cover. How do you keep this microwave clean?
  • Anonymous May 01, 2009
    I have tried to clean the back of the oven with soap and water (even let it sit for 30 minutes) and it's not working. Does anyone know if oven cleaner will work?
How do I clean the interior walls of the microwave over. Also any ideas about cleaning the glass on an oven.
Posted on Nov 28, 2008
  • GE Master
  • 9,098 Answers
There are many good suggestions for cleaning and deodorizing microwaves here.
Consult your manual before using oven cleaners.
Posted on Sep 01, 2008
    New Friend:
As a profession cleaner ( Cleaning Services Cleaners Ltd. Restoring the Pride in Your Home and Workplace )
I want to give you advice from my personal experience.
Pour one cup vinegar (into a 2-cup measuring cup or bowl) then add one cup of hot water to that.Place measuring cup (or bowl) in the microwave, set your timer for approximately 10 minutes and turn it on.After 5-10 minutes (this will depend on how powerful your microwave is)...CAREFULLY remove the cup with the HOT liquid (use an oven mitt!) and wipe out the inside with a wet rag.But that's not all. After that I give it the "shine treatment" with just a few sprays of some rubbing alcohol and a clean, dry cloth.
Posted on Apr 20, 2015
I need a replacement turntable for my brevile combination microwave model brcm2516 where can I get one
First4Spares Glass Turntable Plate For Breville Microwave Ovens ...
https://www.amazon.com/First4Spares-Glass-Turntable-Breville-Microwave/.../B007B...
Shop First4spares at the Amazon Small Appliance Parts & Accessories store. Free Shipping on eligible ... BREVILLE MICROWAVE TURNTABLE Glass Plate 245mm 9.5". $29.99. Next ... Container for Microwave Oven · Add to Cart · Add to ...
Amazon.com: BREVILLE MICROWAVE TURNTABLE Glass Plate ...
https://www.amazon.com/BREVILLE-MICROWAVE-TURNTABLE-Glass.../B00COP... Quality replacement glass turntable for your Breville microwave. ... Small Appliance Parts & Accessories > Microwave Oven Parts & Accessories > Turntables
Breville Shop ' Partmaster
www.partmaster.co.uk/breville/microwave/catalogue.pl?shop=breville&path... Find your Breville products and repair your appliance yourself for less. ... Connects the microwave motor to the glass turntable Suitable for select microwave ...
Breville Canada
https://breville.ca/ Breville designs and engineers small kitchen countertop appliances to deliver commercial quality performance that look great and are easy to use.
Breville Microwave Parts & Accessories ' eBay
https://www.ebay.co.uk > ... > Breville Microwave Parts & Accessories BREVILLE Microwave Glass Turntable Plate Roller Ring Support Stand 3 Wheel ... Turntable Turn Table
Plate MOTOR for BREVILLE Microwave Oven ...
Breville Parts -Google Search
Jul 03, 2017 | Microwave Ovens
Turntable does not turn
checkunder neath it is belt driven and probably has broken belt
Mar 18, 2015 | GE Advantium 120 Convection/Microwave Oven
Advantium arc
Unfortunately there is nothing you can do but to buy a new microwave oven Once it arcs it causes burns on and in the parts and most times cleaning does nothing
Sorry, good luck
Jan 24, 2014 | GE Advantium 120 Convection/Microwave Oven
I'm experiencing occasional arching from the center of the oven i.e. out of the spindle that rotates the metal rack and glass turntable. I cleaned thoroughly and it seems to have minimized the proble
Its unlikely to be associated with the tuntable motor. Units are tuned to prevent arching. Therefore it appears something may have changed inside the unit. Be sure there are no loose items or bits of foil or other mateallic items inside. Also check metal turntable.
Dec 31, 2011 | GE Advantium 120 Convection/Microwave Oven
We have a GE Spacemaker XL 1800 Microwave. There is dirt and moisture that has collected between the inside and outside glass. How can you clean this?
HELLO.
This is the solution to the cleaning issue.
1. Wipe the microwave inside and out with a soft cloth dampened with a warm, mild detergent solution. Rinse with a soft cloth dampened with plain water. Dry with a soft, dry cloth.
2. Put 2 cups of water into a 4-cup measuring cup. Place the measuring cup in the microwave, then heat on high for 5 minutes to loosen food particles that are stuck to the inside walls. Leave the measuring cup inside the microwave for 1 to 2 minutes, then remove and wipe the interior as in Step 2.
3. Remove the glass turntable and wash it in the sink with mild detergent or in the dishwasher. Handle carefully, as the turntable is breakable.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
PLMVZ169HCA Turntable slips on the glass plate
hmmm? me's thinking about this one!!!!
the glass plate has drive dogs on the bottom of it, that fit into drive dogs on the turn table, if its not meshed up right it just spins freely and normaly throw's the glass plat off??? are the bearing that are under the glass plate turning freely? thats the big ring that the plate rides on near the out side edge of the plate, and can be taken out for cleaning??? it looks like a hoop with 3 or 4 rollers in it??? if you forgot to put this bit back in the right way up after cleaning it thats the problem???
Oct 23, 2009 | Frigidaire PLMV169DC Microwave Oven
Arcing
My Advantium was arching at the turntable. Replaced the turntable roller assembely (that hold the metal or glass plate) and the arching went away.
Nov 16, 2008 | GE Advantium 120 Convection/Microwave Oven
Kenmore Elite 66469 Turntable "Clunking" Sound
Either the coupler or the turntable support is bad.
You can find an exploded view by entering your FULL model number (3 digits, a dot, then 8 digits) here: http://www3.sears.com (the 3 is correct)
Dec 08, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
GE Advantium 120 Convection/Microwave Oven Logo
693 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
