Fuvirus!!!!!
help me
provide me with the simplest solution pls.
Since FUvirus is visible in the processes tab of the Task Manager, this can be deleted or disabled manually.
First of, open the Task Manager by right-clicking the TaskBar, click "Processes" tab on the task manager and locate "FUvirus.exe" from the processes lists. Make sure that "Show all Processes from all users" is selected. Once FUvirus.exe is located, right-click and then "End Process Tree" and close the Task Manager.
Now delete the FUvirus from the Registry, follow the instructions:
Open the Windows Registry Editor by clicking on the Windows "Start" button and selecting "Run." Type "regedit" into the box and click "OK." Once the Registry Editor is open, search for the registry key "HKEY_LOCAL_MACHINE\Software\FUvirus.exe." Right-click this registry key and select "Delete".
You also need to search the similar file on your computer, this generally happens, this virus replicates and creates several similar files with the similar name randomnly. Search for "FUvirus.exe" and delete whatever you find with that name. Once you are done, restart your computer and check whether it's gone or not. I would also recommend you to run full virus scan, there are several free antivirus which could easily detect and repair FUvirus like, Avira free, Avg free, Avast free, etc... you can download them from their respective websites.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Note: Don't ever install Multiple Antivirus on a system, this may cause system instability or even system failure.
