Question about Kenmore Elite 45986 Front Load Washer
The Start Button on My Kenmore Elite Calypso won't engage
I received an FL error code and then took the bottom and back panels off, to clean the Pump and connect tubes, there was alot of lint in there that seemed to stop the wheel from turning. Now that this is clean, i put everything back together and plugged it in, and now all buttons on the display work, except when i press start, nothing happens. I don't even hear a beep, which i heard (start button worked), right before i cleaned the pump. I think the computer might need to be reset. Do you have any idea how to do this. I keep seeing postings on a diagnostic code, but i can't find the code anywhere. Please help.
Thanks
  • 1 more comment
  • JohnG1623 Aug 27, 2008
    I unplugged the washer, and plugged it back in after 5 hours. All of the buttons work fine. I press one of the wash cycles, it lights up, the dispay shows the time , and all works normally.. Then when i go to press the Start button, It doesn't start; the button doesn't beep, which seems like its not engaging. All other buttons work though. Very strange. Do you think the door sensor isn't working correctly? And is preventing the washer from starting, cause it thinks the door is open? If so, do you know where to look for the door sensor?
  • Toby Norton
    Toby Norton May 11, 2010
    Absolutely a posibility. the first thing I would do is make sure the pump is plugged securley back in. If the control doesn't "sense" the pump, it won't run.
    The door latch mechanisim is to the right side of the door opening. There is a round hole on the top side. This is one of the door "sensors" Often the pin gets broken off, and the machine thinks the door is still open. Underneath that is a square hole. The is where the pin from the door goes in and allows the door to latch. You can use the following directions to take the latch assembly out and test for continuity with a meter.
    You will find a sliver wire around the gray boot (rubber seal) in the front holding it on. Pull it off. The front of the boot will be moveable. Remove the side on the right. As you reach in, you will feel your door latch. There are 3 connectors. Unplug the 3 connectors (don't worry about the order on them, because they are shaped so they can only be plugged in one way to the door latch). Next reach inside and hold the latch assembly from behind while removing the 3 silver #20 torx screws. Lift slightly up on the latch assembly and remove it. Again check continuity across the pins to verify they are ok.
    Another thing to check might be removing the top (3# 20 torxs screws along the back side of the top) Remove these and slide the top towards the rear and lift up. Set the top to the side. Make sure all of your connections going into the CCu (the big white box with all of the wires going to it) are plugged in securely after you have unplugged it. While you are performing this test, keep one hand on the unpainted metal of the washer. (an accidental static discharge can ruin the very expensive CCU)
    Try these and let me know what you find.
  • Toby Norton
    There is not a reset on the computer. While you can put it in a diagnostic mode and check individual portions of the system ( fill, nutate, drain, spin, etc) the only "reset" is removing power to the system for 2 minutes and trying again. If you are now getting nothing at all, I would check all of my connections (electrical and pressure) and also test the continuity on the fuse on your control board in the console (with the unit unplugged of course) If you remove the 1/4 screws from the back of the console, you will see what looks like a standard fuse on your motor control board. Check the continuity with the meter. If it shows open, the procedure is to replace the whole board. This is costly and if it were mine I would solder a new fuse in place. Try these steps and let me know if you're still having trouble.
  • 15,935 Answers
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
Both the coupler and the lid switch have been replaced yet unless you lift and close the lid it won't engage the spin cycle
Search Results
    Why am I getting an FL error code on a Kenmore Calypso ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kenmore Calypso washer model 11022062100 and there is water in ... Why am I getting an FL error code on a Kenmore Calypso washing Machine?
    fl error code on calypso washer-need help!! - Home Forumsths.gardenweb.com > Home Forums > Laundry RoomJul 22, 2006 - An FL error code keeps flashing on my Calypso Washing Machine. I can't do laundry. Could someone please tell me what I need to do to ..."F dl" light come on - Kenmore Elite HE3 Washing Machinehttps://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock Error... The Kenmore Elite HE3 is a washing machine by Kenmore. ... On Amazon I was able to get the CCU (Kenmore CCU Central Control Unit .... and a dose of WD40 on those contacts should keep that from misbehaving in the future as well.Kenmore Elite Calypso FL error code - ApplianceBlog
Jan 27, 2016 | Washing Machines
I have kenmore elite calypso washer. FL shows on the control panel. Some says drain the water manually or check the water pressure. how do I do it?
Probably something in the pump. Remove the base panel take the pump apart get the junk out of it
Older Calypso washers have a pump like this newer ones have a diff type pump that can be taken apart. The FL error : FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for FL to be displayed.
Causes of flood condition. Inlet valves stuck on, Sediment in water level pressure tube. Clogged pump. All of the above. Service manual and more HERE
And HERE
Jul 01, 2011 | Washing Machines
Error code FL and does not drain completly
most probably needs the water pump replaced.  not hard to do if you are a little handy..  there were a lot of problems with this machine regarding the water pumps.
Jul 22, 2010 | Kenmore Washing Machines
Washer won't drain..like filter is clogged
Flood Condition:
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%@#$
Mar 27, 2010 | Kenmore Elite 21082
Kenmore elite washer model 21082000, won't
Flood Condition:
Feb 19, 2010 | Kenmore Elite 21082
How do you reset the overfill switch on the kenmore Elite calypso machine? It shows FL and we cut the power. There is water inside
Flood Condition:
Nov 15, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Calypso SM9710976A has "FL" on front panel. Whats wrong?
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^!!$#
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite calypso model 11022086
FL means flood condiction..clean or replace your pump..
Jan 09, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso 21082
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@
Dec 16, 2007 | Kenmore Elite 21082
Kenmore Elite 45986 Front Load Washer Logo
247 people viewed this question
Fordexpert
Archaeology
Archaeology
reliableservice
