For some reason, the page has grown. When I open it up, I can't see any of the comands at the top (though I can make out the bottoms of the words edit and possibly produce). The right and left side of the page are off the screen too. Is there a way I can shrink the page so that it fits on my screen?
I've tried all the f buttons, and even tried the buttons on the bottom of the screen to shrink the image, all I got was the same thing with a black frame around it.
Welcome to Fixya,
What is the model of your dazzle device? Is taht DVC 100? if ever please check this procedure.
Step 1: Install the Pinnacle Dazzle Video Creator Platinum software and make sure it works with the Dazzle DVC 100. Sometimes this is easy, other times, this is a very difficult task. step 2: Buy 3 RCA type Y cables. One male end, 2 female ends.
Step 3: Plug the male ends of the RCA y-connectors to the Dazzle DVC 100.
Step 4: Plug the Yellow, Red and White RCA connectors from the XBox 360 to the color matched female RCA y-connectors on the Dazzle DVC 100.
Step 5: Plug a second triple RCA connector into the other end of the color matched RCA Y Connectors.
Step 6: Plug the other end of the triple RCA connector into the TV.
Step 7: The tricky part no one ever mentions: On the XBox 360 video cable, there is a switch that switches from HDTV to TV. You must switch this to TV!
If you have lost the product key to your software or device, and you have previously registered the software or device, or have a proof of purchase for the software or device, contact the manufacturer and they will provide you with a new product key.
FixYa and it's experts do NOT provide product keys, serial numbers, illegal software, authorization numbers or codes, warez, hacks or cracks under any circumstances. Any expert that does so will be barred from answering questions. Those asking are subject to their membership being deleted and be barred from the site. Additional misuse of FixYa may subject you to Federal charges. Please note that IP addresses accessing this web site are logged.
use updated version of moviestar.If not work then use it in compactibility mode...
HOW TO USE compactibility in vista?
sol : right click on exe file and go in property then click on compactibility.
i have the same moviestars 70+ plus a yamaha rx-v750 put the crossover on the sub to maximum (left knob) volume (right knob) about 2/3 clockwise. change the crossover on the yamaha to anywhere from 80-120 ( the 120 will put more bass to the sub) if your yamaha has sub level/volume control set it higher, also if it has LFE/sub out set it to sub only.
It doesn't fully work in Vista. You have to set it to run in Windows XP compatibility mode. Right click your desktop icon; select properties; select the compatibility tab.
