Question about Casio Cassiopeia E-105 Pocket PC
E-105G System error?
I recently got a Cassiopeia e-105G. I tried to install Quake1, therefore creating a few new folders and copying large amounts of data from my PC to the Casio. I waited quite some time for one of the file-copying processes, until the screen of the casio froze. i reset it. still didnt work. i did the other reset, and the last reset possibility. The only thing that appeared was the start-up screen... the weird red picture of a city, but WIn CE wont boot. Wot shall i do!?!?! cheers, I'd be v.happy if someone could help me, Gordon
    Master:
  • 551 Answers
Apparently the device worked before you attempted to install Quake1. So component wise all should be well. One more thing you can try is to remove both batteries & leave it for a while. Install the main battery & then the Backup battery. Before starting make sure the main battery is fully charged. Now try to start the device & hopefully it should boot normally. If it freezes at the starting screen, very definitely something is not making proper contact inside the device & perhaps you should check out the connections within the device following the disassembly instructions at the pocketpcpassion site.
Posted on Sep 06, 2005
    Master:
  • 551 Answers
I am assuming that the device did connect to your PC & could be sunchronised prior to your attempted Quake installation. I am also assuming that the device is now fully functional in the like new (out of the box) state. Before you can restore the device to pre Quate state you have to resolve the hardware issue & have communication established between the device & ActiveSynch. Have you checked the PC connection settings on the Cassiopeia ? It might have defaulted to IrDa instead of serial. With the charger connected to the cradle & the device in the cradle, does the green charging light turn on ? Some of the chargers are wobbly & you might have to jiggle the devi ce to make proper connection. Green light is one indication of proper contact. When activeSynch tries to look for the device do both the serial ports show up in the available ports ? Are you by chance sharing the physical com port with some other device ? If you continue to have problems with the device do contact me directly with your os, hardware & software details. Reply With Quote
    Master:
  • 551 Answers
Your only recourse would be a hard reset. If you wish to go back to the same stage before installation of Quake you will have to delete the partnership in ActiveSynch WITHOUT deleting the Synch folder. Next place the hard reset device on to the cradle. Active synch will find the device. Create partnership using the same identity parameters as you had before hard reset. Setup the synch option to manual. Click on the tools - add remove programs. Highlight Quake if it is on the list & click remove. You can then add rest of the software on the list. Once installed you can go back to the main screen & click on the synch icon. I am not a gamer but you might try installing quake on a cf card in stead of the main memory. It might solve your problem of excessinve storage space/ ram requirement.
Can't copy large files onto my external harddrive
What format is the external drive ?
you might need to split the file with rar
I recently downloaded win 8 5gb had it split with rar into 2 files downloaded with IDM trial
The FAT32 format does not support single files larger than 5GB, so if you have a file larger than 5GB you cannot put it on your FAT32 thumb drive. Most thumb drives and other portable media devices use FAT32 format, so this setback makes large files less portable, and that just won't do. Get around this problem by compressing the of the file or by splitting the file up into multiple pieces.
Create a folder for your RAR file and insert a copy of the original file into this folder. RARing a file separates it into multiple pieces, so creating a file specifically for your RAR file will keep the files together allowing you to move one folder to your FAT32 device instead of having to locate and move multiple files. Right click the large file that you want to put on a FAT32 device. Select "Add to archive" from the menu that appears to the side. Select "RAR" from the "Archive Format" located to the left of the menu. Click the arrow next to "Split by volume, bytes," and select "CD 700: 700mb." This will create a new file for every 700mbs, meaning your your one large file will be separated into many 700mb files that can be put back together as a single file later. Click "OK." Put the folder, containing your newly separated files, onto your FAT32 device after WinRAR has finished separating the file. b> Zip File b> Right click the large file you want to put on a FAT32 device. Select "Add to archive" from the menu that appears to the side of the file. Click "OK" on the next menu. This menu allows you to customize the compression settings. The only option you need to change is the "RAR" selection to "ZIP" in the "Archive Format." The rest of the default settings will work fine, so there's no need to change anything else. The zipped file will appear in the same folder as the original. Delete the copy of the original large file from the folder and put your newly compressed file on your FAT32 device after the file has completely compressed. The time it takes for the file to finish compressing depends on the of the file. Hope this helps. http://www.all-freeware.com/getfreeware.html?pid=109090&mirror=1
b>
Jan 08, 2013 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Error 1317.Setup cannot create the folder__C:\ProgramData\Microsoft\Windows\Start Menu. Verify that the path exists in your system and that you have sufficient permissions to update it._
Follow the path in the error message above by going to start, then computer , then C: then find the folder named "ProgramData" and in that folder find another folder named "Microsoft" and in that folder find one called "Windows" and in that folder find one called "Start Menu" . You will be missing one of these folders most likely the Start Menu folder when you find the one you do not have , create a new folder with the name of the missing folder in the correct folder that it is listed in in the error message. Now try to install the program agian. If that dosent work than you may have some how deleated some folders. If you cannot install then you need to insert you operating system install disk and choose reapire or you could also try a system restore to a time when your computer was working correctly. Then try to install office agian. Also office has a installation troubleshooter that may be able to fix it for you I would try that before a system restore or repair.
Dec 19, 2012 | Microsoft Office Professional 2007 Full...
Trying to finish installing genuine windows 7 professional software that I downloaded tonight but my hard drive seems to be full (due to all the recent upgrades of Windows, Carbonite restore. I just...
Windows.old is a folder created when you install a new Windows when you haven't formatted the hard drive clean. Once you got all your wanted files of Windows.old folder you can delete as Windows do not use files out of there anymore.
Mar 06, 2011 | Computers & Internet
I am receiving error code 0643 when I try to install Roxio Creator 2010 Pro and then program uninstalls.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -> Run. Type "msconfig" (without quotes) then click OK.
    • Select the Startup tab.
    • Click the Disable All button.
    • Click the Apply button, then click the OK button.
    • Click the Restart button.
    To reverse this at the end of installation, go back into MSCONFIG and select Enable All and restart (that can be done once installation is complete).
  2. If you are installing from a physical disc, please try to copy the content of the disc to a folder on your hard drive then install from the hard drive. To do this:
    • Create a new folder on your Desktop.
    • Go to Start -> My Computer, then right-click on the Creator installer disc and select Explore.
    • Select ALL of the files in the installer window and copy to the folder you just created.
    • To install from the folder, double click the setup.exe file.
  3. If you are installing from downloaded files, please follow the steps below to delete the temporary files then try to reinstall again.
    • Go to Start -> Run. Type "%temp%" (without quotes) then click OK. The Temp folder will show up.
    • Go to Edit -> Select All.
    • Go to File -> Delete.
    • Reinstall your software.
Jun 11, 2010 | Roxio Easy Media Creator 10 Suite
Simple, step-by-step instructions on how to fix Error 1311 in Windows XP -- this error popped up when trying to repair/fix original installation of Microsoft Office 2003 -- not very computer savvy, but can...
Hello
Thank you for using
FixYa for your problem
To resolve this problem, copy the contents of the Office CD to a folder on your hard disk, and then run Office Setup from this folder. To do this, follow these steps:
  1. On your desktop, double-click My Computer.
  2. Double-click the local on which you want to create a new folder.
  3. On the File menu, point to New, and then click Folder.
  4. Type a name for the new folder, and then press ENTER. For example, type OfficeXPCD.
  5. Insert the Office CD into your CD-ROM or DVD-ROM drive. Hold down SHIFT as you insert the CD to prevent Setup from starting automatically.
  6. In My Computer, right-click the CD-ROM or DVD-ROM drive, and then click Explore.
  7. On the Edit menu, click Select All.
  8. On the Edit menu, click Copy.
  9. Right-click the folder that you created in step 3, and then click Paste.
  10. When all the files have been copied to the new folder, quit all other programs that are running, and then double-click Setup.exe in the folder that you created in step 3 to start Windows Installer and Office Setup.
  11. Follow the on-screen instructions to complete the Office installation.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 19, 2009 | Microsoft Windows XP Home Edition
When i install fifa 10 or fifa 08 my pc show a problem that, it cannot read the group1.cab file. and then show the error code is 2350
that is basically a disc error. it means that the file named in the error message (.cab) file is not recognized or simply the system cannot copy and extract files from it to complete the installation.
resolution:
Create a folder in your local disk and name it Disk-1 then copy all the files of your cd-installer to that folder. do the same for DIsk 2 and so on. When during copying of files to your local disk produces error like "cannot read from device", it means that the source cd is defective with scratches and you need to buy a new installer. when no errors are detected, then open and run the setup.exe file in Disk-1.
Oct 15, 2009 | Computers & Internet
Unable to scan from Epson TX110 but can print
Having exactly the same problem with an Epson SX515W. Did you solve it?
Sep 28, 2009 | Epson Stylus NX400 InkJet Printer
Mac OSX 10.4.11 Error when installing the Epson NX400
If you're running the install program from the install disk CD, it may be attempting to create a work folder on the CD instead of your hard drive. I would drag a copy of the install program onto your hard drive first and then launch the copy on your hard drive.
Let me know if that solves your install woes...
best of luck on this.
K
Jul 24, 2009 | Epson Stylus NX400 InkJet Printer
HTC G1 - Can't transfer from computer to micro SDHC card
Did you make sure to "mount" the device to your PC so it would see it as a drvie?
Feb 22, 2009 | HTC G1
Outlook express
dear fando,
This is usually down to a corrupt or over-full email inbox. Outlook Express is not very good at holding large amounts of emails especially if they have large attachments. I had a user this morning with a 2.5 GB inbox.
Backup/rename Inbox (C:\Documents and Settings\(User)\Local Settings\Application Data\Identities\{GIU}\Microsoft\Outlook Express\inbox.dbx -> inboxbak.dbx).
Close Outlook Express.
Open Outlook Express.
Outlook Express will have created a whole new Inbox.
Your email should now work.
Best wishes.
Jan 04, 2008 | Audio Players & Recorders
Casio Cassiopeia E-105 Pocket PC Logo
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
