Question about Goodman Heating & Cooling
I have a Goodman0503 Gas Furnace. The blower motor is dead. I need to replace it. I wonder if there is instruction for how to change the motor. Thanks.
If you gotta ask that question, call a service man to make sure it the fan motor and not the curcuit board! You can make sure it the motor by removing the black wire and white wire and hook up power to them to see if the motor runsto be sure! Thank you very much!
Posted on Aug 27, 2008
"On" position blower shuts off when gas turns on, replaced control board, no change.
Really need more info but with what you have stated: many furnace blowers are set up to simply run the blower after a set time.
Yours is not doing that and is in a very unsafe condition. Only thing keeping your furnace from burning until it glows red hot is the over temp safety.
With the info provided I would suggest you replace the furnace control board and the abused safety. Verify blower operation before you call it fixed.
Sep 12, 2017 | Heating & Cooling
Furnace wont work
Have to know the model and serial of the furnace.
locate code list usually inside or on the back of a door.
Operation sequence= call for heat--inducer blower motor--makes pressure switch--signals board to bring on hsi--after a set time gas valve opens and you have ignition--main blower motor comes on after a set time
Feb 14, 2014 | Coleman 7990-319p Evcon Gas Furnace...
Need to wire furnace blower
Gas valve should only have a couple of wires...24 Volt & common. the blower will use one speed on a gas furnace & a common. If you have AC or a fan switch on your thermostat, then the high speed will also be connected on the blower.
Dec 16, 2013 | Ruud Rheem Furnace Blower Motor...
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
I have a Johnson aire ease ultra 90 gas furnance. I also have a outdoor wood furnance that has its own thermostat. On the original thermostat I turn the blower in the on position. I then set the outdoor...
I would first eliminate one furnace from the equation, the exterior wood furnace... turn its tstat down. Will the gas furnace then operate normally? Can you run the blower manually, as in summer mode? Make sure your filters are clean also... that can sometimes overload the blower.
Apr 12, 2017 | Heating & Cooling
Furnace blower won't turn on... Forced air gas furnace was working fine for three weeks. Now: Turn themostat up Gas comes on, pilot light obviously working Box heats up for about 90 seconds Humidifier...
If it indeed started that one time for a short period then cut out, the first place that I would start would be the capacitor located in the blower compartment. The capacitor gives the motor the need kick to start, and often times stays in the circuit to help the motor run more effeciently. This could very well be the problem.
If you have the option to run the fan from the thermostat, turn the fan to the "on" position and see if it starts. If it does, then it is not the capacitor.
Hope this helps
PS Your are correct about the "sensor" turning the furnace off, it is called a high limit switch and is there for safety. It is an automatic reset device, and will reconnect power once it has cool suffeciently.
Nov 10, 2010 | Dayton Gas Furnace Heater
1994 Carrier 58 PAV
sounds like the relay for the unit may be bad, usually if a blower motor goes it stops or has a very loud humm and only goes slow
Aug 03, 2009 | Heating & Cooling
How to install a new blower motor in a Goodman gas
remove the blower unit it slides out on some gas furnaces you may have a control bord in the way if you dont have a goodman motor you will need a belly band to clamp to new motor to provide the mounting arms also after loosening the shaft set screw spray w wd40 turn on side and shake motor should fall out if gas furn 115v motor hope this helps
Jun 09, 2009 | Heating & Cooling
My blower motor will not stop running,and my ignitor doesn't light.
I am assuming you are talking about a Natural Gas or LP furnace. The blower motor is powered by a separate 120 volt circuit, so flipping the 240 volt breaker for the furnace will not shut it off. There should be a regular light switch at the furnace that will turn off the blower for servicing the unit. When you take the cover off the unit, there should be instructions on how to re-set the igniter. If it won't re-set, try shutting off the gas for a few minutes, then turn it back on and then reset. If none of this works, and you can't find the owners manual, call a service technician.
Feb 22, 2009 | Electric Circuit Breaker Kit for Furnace
Heating & Cooling Logo
57 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
