Question about Casio Cassiopeia E-115
Do 802.11b CF Cards Work on Casio E-115?
Purchased the Linksys WCF12 CF wireless adaptor for my Casio E-115. Everything appeared to load properly, but when I attempt to access the Configuration Utility the only thing I get is the following message: Cannot find 'PRISMSTA' (or one of its components). Make sure the path and filename are correct and all the required libraries are available. The support from Linksys has been outstanding in trying to remedy this (tongue firmly in cheek!)... But, that is another story. BTW have the latest drivers from Linksys site and ActiveSync v3.6. Has anyone else had this problem? Suggested solution??? Or, is there another brand of 802.11b CF card that DOES WORK! TIA, M
    Master:
  • 551 Answers
Figured the Problem Out... After spending an hour on the phone with Linksys they finally sent me to an upper level TechSupport person. 2 minutes later i had the answer. According to them the WCF12 card will not work with the Casio E-series due to its older OS. If you are running CE with PocketPC 2002 you won't have any problems. But since our PDA's are a little older it won't work. They did tell me that WCF11 card will work just fine with the Casio E-series. Take it for what you want, I personally haven't had any luck when talking to Linksys Tech Support. Reply With Quote
Posted on Sep 06, 2005
    Master:
  • 551 Answers
I have the WCF12 and i got it working on an E-125. You have to run the setup on the CD and then plug in the card after setup completes. If you plug the card in first then do the setup it will give you that PRISMSTA error. To fix that error you must do a hard reset run the setup and then insert the card.
    Master:
  • 551 Answers
My experience with Linksys support has been one of horror. It relates to a different product - 2 port lan printer server. I never got it to work right & it is gathering dust. Perhaps when I have time I will try it out with WinXP with native support if it is built in. Although a manufacturer may claim on his site that a particular device supports WinCE 3.0 on mips cpu you have hake it with a ton of salt. There have been some threads on this boards for the specific device you mention & suggest you contact the concerned persons directly for their opinion & experience. I have found DLink to be far more accurate in its claims than LinkSys.
How can i get Linksys Wireless-G Broadband Router go wireless?
The Linksys Wireless-G is ALREADY wireless. Do you have any computers with 802.11g network cards? Laptops usually have these. Make sure you have properly configured the router, because if it is NOT correctly done then things may not work too well.
Nov 02, 2009 | Linksys Wireless-G Broadband Router
Linksys Wireless g usb adaptor
please make sure that you have downloaded the driver properly.
Feb 11, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Cannot setup WPA2 on WUSB54G & WPC11 adaptors
This is because those wireless adapters that you mentioned do not support for WPA2. Linksys will not release drivers for those adapters that will make it work with WPA2 because they are already discontinued. So the only other option is to stick with WPA or WEP
Jan 19, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Can't install linksys wireless adaptor
please provide the details for the adapter
if the cd is not working properly then u can download the setup fron www.linksys.com
Nov 25, 2008 | Linksys WUSB11 802.11b Wireless Adapter
Wireless network
Do you remember your wireless network name and the wireless security password for your router, check if you are able view the wireless network, try connecting to it..if it asks for passworg type in your password and check if nor revert back..
Jul 17, 2008 | Linksys Wireless-G Broadband Router
I recently purchased 2nd hand a HP ipaq hx2000 pocket PC. It all appears to function ok apart from it will not recognise any compact flash card when I insert it into the slot. I have tried several CF...
Have you tried using an SD card? The hx2000 is supposed to support SD cards and CompactFlash Type II memory cards. If it doesn't respond, it's possible that your second-hand device simply has a faulty card slot.
May 10, 2008 | Computers & Internet
I cannot connect to my new WRT150N router
Lets start with the basics. First do you have a computer with an ethernet port for a wired connection? If so connect it to the router and attempt to access the internet. If this works we have eliminated the ISP connection and need to address the wireless configuration of either the router or the adapter or both. I will need the version number of the router which probably appears on a label on the bottom of the device to get access to the proper users guide. I do not have one of these models specifically however on reading the specs it mentions that it works well with B and G wireless cards -- there is a possibility this device will not work with A band cards -- we will confirm this later. Please provide the model number for wireless adapter so we can research them if needed.
Nov 29, 2007 | Linksys Wireless-N WRT150N Router
Connectivity/activesync and network issues
When using wireless lan with PPC, there are some experience shere with you. 1. You must do an "Reset" after the first time of installing wireless driver into your DELL AXIM. Otherwise, the driver would not work. 2. Microsoft Pocket PC 2002 only can allow one source to access the internet. It can't access internet via the USB and wireless at the same time. Thus, it is more batter way to leave your AXIM alone instead of insert on cradle when you try to access internet via wireless lan. 3. Some of the wireless's CE driver are based on StrongArm, 206MHz, not PXA250, 400MHz. It will got problem when the wireless try to initiate the link between base station and PPC. Try the following step: (i) Make sure you have been install the wireless driver. (ii) Remove your wireless from CF slot. (iii) start->setting->power->processor select "PowerSave" mode and apply it. (iv) Plug wireless into CF slot (v) If you can get an dynamic IP or access internet, you can repet step 3, but select "Auto" mode. Hoping these information can solve your problem.
Sep 19, 2005 | Dell Axim X5 Pocket PC
Confused about the WiFi on X5
It does NOT have integrated WiFi, you will have to buy a compact-flash card, the Linksys WCF12 works perfectly in mine.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Casio Cassiopeia E-115 Logo
187 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
