Question about GE JASRM24912 Remote Control
Lost Manual I have a GE remote control, but I lost the manual. I need to know the codes for a RCA tv.
I the codes for jasrm24912 remote control for an orion T,V.
Posted on Aug 31, 2008
Gigatech
  • 259 Answers
SOURCE: TV CODES
MANUALLY ENTERING CODES
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press AUX then the device button you are assigning to AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed, repeat steps with the next code. If none of the codes listed for your device work for your device or your brand is not listed, try the Code Search method described below.
USING CODE SEARCH FUNCTION
If your TV, VCR, DVD, etc. does not respond after you have tried all the codes for your brand or if your brand is not listed, try searching for your codes by following the steps below.
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least 2 seconds between each time you press POWER. Important: You may have to press POWER up to 250 times.
5. When your device turns off press the ENTER/SAVE button. The INDICATOR LIGHT will go off.
Posted on Dec 11, 2007
AvioriX
  • 689 Answers
SOURCE: GE Universal (JASRM24912) Remote Control
Hi
Here is the link for all Codes
http://www.remotecodelist.com/remotes/ge/RM24912_codes.pdf
and the Manual for instructions
http://www.remotecodelist.com/remotes/ge/RM24912_instructions.pdf
Good Luck
Posted on Jan 18, 2008
SOURCE: TV CODES
I HAVE AN UNIVERSAL ZENITH REMOTE AND I NEED REMOTE CODE FOR VYOU 32 IN FLAT SCREEN LCD
Posted on Jun 17, 2008
SOURCE: Lost manual for ge universal remote 24912
i need help wiyh my mx-850
Posted on Jan 14, 2009
  • 1126 Answers
SOURCE: I lost the manual for my remote control, T.V. can
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=ge&dv=universalremote&md=rm24912&kw=&st=&ar=&dt=&so=&pg=1&file=others/ge/rm24912-manual.zip
Try this link...hope it helps. Codes are at the back of user guide.
Posted on Sep 09, 2009
I have an RCA universal remote and I lost the book for it I need to know the codes for a GE tv
You can view ALL the documents (user manual, code list, etc.) here.There are numerous entries for GE appliances.
Good luck! Please rate my reply - thanks.
Jul 04, 2011 | RCA RCR312W Remote Control
Need to program rca univ remote for sanyo tv & i lost the manual
Get your Sanyo TV codes and one by one program the into you RCA universal until you can turn the TV on and off. Find codes at Sanyo.com, the manual, Sat Manual, Vcr Manual etc.
Sep 19, 2009 | RCA Universal Remote Control
RCA remote codes lost
Codes For Model RCR311B
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Codes found here: http://remotefinder.rca.com/default.aspx?site=rca
RCR311B manual (PDF): http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
May 26, 2009 | RCA RCR311B Remote Control
Lost the manual for my rca universal remote
Try these codes for Quasar TVs:
1003, 1054, 1055, 1070, 1109, 1170
Codes can be found here.
The manual for the remote can be found here (as of 06/07/2009):
Basically, try holding the TV button, the on/off button should light up. Then press the digits for the code one at a time. If the code is accepted, the on/off button should go off. Finally let go of the TV button. Now try operating your TV.
Apr 06, 2009 | RCA RCR311S Remote Control
Lost code book
Here's the manual for RCR450 remote =>
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr450-manual.zip&area=other
Apex TV codes are 1236, 1243, 1244.
Daewoo TV codes are 1004, 1005, 1006, 1016, 1017, 1082, 1171, 1190.
Sharp TV codes are 1006, 1012, 1026, 1095, 1111, 1112, 1171, 1173.
Good Luck!
Oct 20, 2008 | RCA RCR450 Remote Control
Programming tv
I have a ge universal remote and a sanyo tv i lost the paper of codes that came with the remote
Aug 20, 2008 | GE JASRM24912 Remote Control
I need codes for philips universal remote control
lost manual tring to hook up dvd/vcr emerson up need code
Apr 24, 2008 | Philips Universal PH301S Remote Control
I need code for RCA TV/VCR Combo
You will have to try each code until you find the correct one for your model, but here are the codes : 102, 117, 194, 342.
Good luck.
Jan 15, 2008 | GE JASRM24912 Remote Control
GE JASRM24912 Remote Control Logo
122 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
