Question about Hanns.G Corporation HX191DP LCD Monitor
Hanns g 19 inch monitor
My Monitor power led does not come on and there is a slight clicking sound from the speakers. Also you can see a faint flickering on the black screen as if its trying to work. Any ideas on what the problem is and cost of fixing it? Thanks. Graeme H
  • Anonymous Sep 22, 2008
    My led light will flash off and on in time with the clicking sound coming from the monitor. It did this once before but it only seems to happen when i shut the computer down for a significant amount of time. Its worked fine for a couple years now. Think I will stick with another brand after this.
    Scholar:
  • 55 Answers
No direct experience of this specific monitor, but LCD monitors in general seem to be susceptible to power supply failure due to the relatively cheap capacitors they use and the high working temperatures.
Turn it off, leave it for an hour or two, then take off the cover and look for bulged or leaking cap's on the power supply board. If the tops are not flat, they're probably duff, and need replacing with equivalent spec ones. Probably 105'C high temp - I got 105'C 470uF 35V ones for my monitor from Ebay at about a fiver for a pack of ten.
Posted on Sep 08, 2008
Hanns g hx191d no picture. My monitor went black while I was working, the green led is lit, I get a picture for a split second when I first turn on the computer or monitor.
The most common cause of this type of display issues is a failure of the back light power supply. There are parts called capacitors that fail and this causes the power supply to not be able to put out the correct voltages to operate the monitor. You cn repair the monitor easily by replacing the bad capacitors on the power supply board. The old ones need to re desoldered and the new ones soldered back in place. You can get a kit of the proper capacitors to do the repair here:
http://www.ccl-la.com/catalog/product_info.php?products_id=194
Nov 02, 2012 | Hanns.G Corporation HW191D 19" LCD Monitor
Have a hanns 194 d monitor. i can;t get the sound to work. Help!
Are you connecting the audio cable from the PC audio line out jack (green) to monitor audion line jack (green) with stereo mini phone jacks? You should verify the the speakers in the monitor are working by feeding it with the sound from MP3 player to narrow down the problem.
Apr 07, 2010 | Hannspree HC-194D 19" LCD Monitor
Hanns-g 19" HX191d monitor blank screen. Power led is intermittent flashing green. Does not show 'no signal' when powered up alone. Has this monitor died or is there a way to fix it?
This type of issues is caused by parts called capacitors that have failed and are keeping the power supply from starting up correctly. You can rebuild the power supply board by replacing the bad capacitors and this will bring the monitor back to full working order. Here is a link to information showing what parts need to be replaced with pictures and parts list.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_31&products_id=194
I hope this helps you.
BuddyMc
Oct 14, 2009 | Hannspree HANNS.G HX191D 19" LCD Monitor
Hanns-g hc 194d 19 inch monitor
I am already registerd and have my unlock number,but I have forgotten my password so I need new password
Aug 25, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
HANNS-G MONITOR BLACK SCREEN JUST FLICKERS
when u power the computer press F8 key then enter in enable vga mode.
then if u able to enter then chagne screen resolution to 1024*768
Jan 05, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
Faint green discoloured screen then screen is blank
Sounds like one of your florescent tubes have died. THe power circuit is trying to start it but fails then shuts down
Nov 10, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Hanns G 19" LCD monitor Screen Problem
D3mon,
Looking at the photo that you took... You've defintely got a damaged panel. My advised get a new one...saved you the headached and $$$....
Oct 10, 2008 | Hanns.G Corporation HU-196DP LCD Monitor
Hanns.G Corporation HX191DP LCD Monitor Logo
333 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
