Question about NexxTech Computers & Internet
Using nexxtech 2.5
I had a motherboard crash in my notebook. I bought a new notebook computer, loaded Fedora 9 linux (as my previous notebook had), then bought a NexxTech 2.5" PATA hard drive enclosure to connect my old hd to my new computer. I cannot get linux to recognize the drive, however. I cannot figure out what I may have done wrong, oir what software I may be missing. Can anyone give me some guidance?
Old System: Dell Inspiron 5150, with Seagate 2.5" internal hd (one month old)
New system: HP Pavilion dv9910us, with NexxTech2 portable drive enclosure
  • 10 more comments
  • jfalter0 Aug 27, 2008
    Some further info: After plugging in the drive to the USB port, I ran
    cat /var/log/messages | grep sdb
    I had this result:
    Aug 27 08:19:14 localhost kernel: sd 7:0:0:0: [sdb] 312581808 512-byte hardware sectors (160042 MB)
    Aug 27 08:19:14 localhost kernel: sd 7:0:0:0: [sdb] Write Protect is off
    Aug 27 08:19:14 localhost kernel: sd 7:0:0:0: [sdb] Assuming drive cache: write through
    Next I looked at what devices I have attached:
    ls -l /dev/sd*
    brw-rw---- 1 root disk 8, 0 2008-08-26 21:58 /dev/sda
    brw-rw---- 1 root disk 8, 1 2008-08-26 21:58 /dev/sda1
    brw-rw---- 1 root disk 8, 2 2008-08-26 21:58 /dev/sda2
    brw-rw---- 1 root disk 8, 3 2008-08-26 21:58 /dev/sda3
    brw-rw---- 1 root disk 8, 4 2008-08-26 21:58 /dev/sda4
    brw-rw---- 1 root disk 8, 5 2008-08-26 21:58 /dev/sda5
    brw-rw---- 1 root disk 8, 16 2008-08-27 08:22 /dev/sdb
    However, nothing mounts in Nautilus, nor are the individual partitions (I think there are five) of /dev/sdb recognized.
    I would love some help figuring this out. I have backups of my data from about a month ago, but all my recent work is on that hard drive. (I know: backup, backup, backup.)
    Peace!
    Jeff
    It doesn't work with Windows either. I get notification that a USB Mass Storage Device has been found, eventually that a disk drive has been added, but that's it. It doesn't show up in My Computer or anything.
    I realized after my original posting that my old system was password-protected. When I started my system, I had to enter a pasword before I could acces the hard drive or anything else. Could that have prevented me from reading my hard drive on another system?
    I tried reinstalling the OS, but no change. The first time the drive was not connected, the second time it was. I cannot tell any difference.
    I installed the disk in another computer. It wants a password. I tried using the password I used to start the system, but it doesn't work.
    I have connected it as a USB drive, now as an internal hd in a friend's laptop. Connected as an internal hd, the system wants a hdd password.
    The drive has five partitions, I think:
    1: NTFS (Windows XP)
    2: boot partition (/boot)
    3: swap drive
    4: extended partition
    5: ext3 file system (/)
    The drive says I can put a jumper on it as a slave or no jumper as a master. The NexxTech instructions say to set is as a master for the enclosure. I have it set that way in my friend's laptop as well. Should I set it as a slave?
    This doesn't quite describe my situation.
    I know the password I had for the system. I did not have a separate one for the hard drive. However, the system one seemed to lock the hard drive. And I cannot use the system one to unlock it.
    Some clarifications:
    Originally, Fedora was installed an internal Seagate hd. When the computer crashed, I removed that internal 2.5" Seagate hd and installed it in a NexxTech 2.5" hard disk enclosure. Then I connected this combo to a new laptop running Fedora via a USB cable (first connected to two USB ports, then to one). The computer didn't recognize the drive. So I removed it from the enclosure, borrowed a friend's laptop, and installed the Seagate internally in place of my friend's hd. Now the friend's laptop is asking me for a HDD password. The password I used to access the original system, until the time of the crash, is not working to mount this drive.
    Okay, I followed the link to read about the lack of a partition table. Following its suggestion, I entered
    [root]# /sbin/fdisk -l
    Disk /dev/sda: 250.0 GB, 250059350016 bytes
    255 heads, 63 sectors/track, 30401 cylinders
    Units = cylinders of 16065 * 512 = 8225280 bytes
    Disk identifier: 0x13f913f8
    Device Boot Start End Blocks Id System
    /dev/sda1 * 1 6375 51200000 7 HPFS/NTFS
    /dev/sda2 28860 30401 12386115 7 HPFS/NTFS
    /dev/sda3 6376 6400 200812+ 83 Linux
    /dev/sda4 6401 28859 180401917+ 5 Extended
    /dev/sda5 6401 28859 180401886 8e Linux LVM
    Partition table entries are not in disk order
    Disk /dev/dm-0: 182.6 GB, 182603218944 bytes
    255 heads, 63 sectors/track, 22200 cylinders
    Disk identifier: 0x00000000
    Disk /dev/dm-0 doesn't contain a valid partition table
    Disk /dev/dm-1: 2080 MB, 2080374784 bytes
    255 heads, 63 sectors/track, 252 cylinders
    Disk identifier: 0x30307800
    Disk /dev/dm-1 doesn't contain a valid partition table
    Disk /dev/sdb: 120.0 GB, 120034123776 bytes
    255 heads, 63 sectors/track, 14593 cylinders
    Disk identifier: 0x13cdbb3e
    /dev/sdb1 * 1 3824 30716248+ 83 Linux
    /dev/sdb2 3825 14593 86501992+ 83 Linux
    I am not sure what /dev/dm-1 is, but /dev/dm-0 seems to be the drive in question. I then ran fdisk on this drive:
    [root]# /sbin/fdisk /dev/dm-0
    Device contains neither a valid DOS partition table, nor Sun, SGI or OSF disklabel
    Building a new DOS disklabel with disk identifier 0xe73cf5fb.
    Changes will remain in memory only, until you decide to write them.
    After that, of course, the previous content won't be recoverable.
    The number of cylinders for this disk is set to 22200.
    There is nothing wrong with that, but this is larger than 1024,
    and could in certain setups cause problems with:
    1) software that runs at boot time (e.g., old versions of LILO)
    2) booting and partitioning software from other OSs
    (e.g., DOS FDISK, OS/2 FDISK)
    Warning: invalid flag 0x0000 of partition table 4 will be corrected by w(rite)
    Command (m for help): q
    So, it does indeed seem that a partition table is lacking, though I don't think this should be the case, unless it was somehow corrupted when the motherboard crashed. If the partition table was corrupted/destroyed, is there a good way to recover it without losing the data?
    Thanks for the reference on the device names. I knew most of that information, but it was helpful to learn about the /proc/partitions file.
    I tried it in two different systems--internally on one (WinXP), as an external USB on both (WinXP, Fedora). On neither does it work.
    The drive that is now USB (/dev/dm-0) had five partitions before the system crash:
    3: swap drive
    From the fdisk info (I just recently posted it), it seems that the partition table has either been corrupted or destroyed. I am hoping that if so, there is some good way to rebuild the partition table without losing the data.
    Master:
  • 521 Answers
Every thing is proper in your software .and what you connected is also the proper way as to be done.but still i will suggest calling the technician at your place is much better.as this will save your time.and he will be having all the missing software cd which your pc demands.and if something goes wrong the the whole mother board will be corrupted.and will be counted as scrap.because all the minute connections in it are very sensitive.and connecting all your sofware will not be too costly will be just is service charge.and that is exceptable.because he is giving that service.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Aug 27, 2008
    Genius:
  • 2,920 Answers
That hard drive may not be compatible with the new computer..the parameters may be wrong and wont allow it to use or trasnfer data from it onto the new computer.trying to interchange drives depends on compatibility issues and it sounds as though the one you are trying to use is simply not compatible to the new system
    Genius:
  • 1,665 Answers
Linux device naming.
This topic provides information to help you understand naming patterns for devices on Linux.
    Scholar:
  • 163 Answers
Disk /dev/md0 doesn't contain a valid partition table
See link may helps
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Some laptops provide autility to lock a hard disk with a password. These passwords are notthe same as BIOS passwords. Moving a locked hard disk to anothermachine will not unlock it, since the hard disk password is stored inthe hard disk firmware and moves with the hard disk. Also, adding a new(unlocked) hard disk to a locked machine may cause the new hard disk tobecome locked. Also, note that hard disk lock passwords cannot beremoved by reformatting the disk, fdisk or any other software procedure(since the disk will not allow and reads or writes to the disk, itcannot be reformatted.) Usually, the BIOS password and hard disk lockpasswords are set the same by a user and we can recover the BIOSpassword directly from the laptop security chip (after it is removedfrom the system board.) However, it is possible that the BIOS passwordand hard disk lock passwords may be set different. In this case theBIOS password will not unlock the hard disk. You can test to determineif your hard disk is locked by attempting to access it in another laptop.
For more information click this link
http://www.pwcrack.com/harddisk.shtml
thanks
good luck
    Genius:
  • 2,035 Answers
Please set the hard disk jumper to save mode and then connect it the Usb case , then check the status light blinking or constant on the hard disk case...
  • 13,433 Answers
The drive needs to be partitioned and if it already has been, windows doesn't support linux partitions so its not visible in windows until repartitioned
  • Ekse Aug 27, 2008
    Im talking about the usb drive of yours?
    Sergeant:
    Champion:
  • 214 Answers
If it's a usb? you may try with other ports. or may follow other's comments also
    President:
  • 1,952 Answers
Reinstall ur linux os again...i think it may cause due to mistake caused during installation...linux should be always taken care to install in the syste,m...else it wont run pro...else install tat in different drive and see///
  • mohammed marika thambi
    mohammed marika thambi Aug 27, 2008
    I've gotten it to work with FC1 using a similar process to that
    outlined. The important thing is to work out what modules your usb
    drivers need. With FC1 I added
    usbcore
    usb-storage
    usb-hci
    ehci-hcd
    in that order to the front of the linuxrc script in the initrd image.
    Order is important! Doesn't work for instance if you load usbcore up
    last as the others depend on it.
    However with just the usb modules it still failed as it wasn't getting
    enough time to actually find the usb hard drive. So I added the sleep
    function as well and it all worked fine. The fdisk wasn't necessary.
  • 6,487 Answers
Try checking this link for some solution that you can try about this USB detection probem http://forums.fedoraforum.org/showthread.php?t=19896
Hope that helps........
  • Mark Gil
    Mark Gil Aug 27, 2008
    Yes that will prevent you from reading the external drive because , what will happen there your system wont recognize the external hard drive connected to it, try disabling the password then reboot then check if its working now...
  • Mark Gil
    You're saying that the hard drive was recognize on another computer when connected via USB or its not also recognize??because if its not recognize with the other computer there's a problem with the usb cable, enclosure or the hard drive itself...........
  • NexxTech Master
  • 19,396 Answers
Check on bios that pata port is enabled.
See here :
PATA Troubleshooter - Computer Hardware ...
  • Ginko
    Ginko Aug 27, 2008
    If the had drive is an external one, plugged to USB , then this has got nothing to do with the BIOS settings.
    If Fedora is installed on internal Hard Disk, it is supposed to recognise automatically an USB hard drive, and it generally supports all external usb har drives.
    If it does not recognise the hard drive, then downloading TWEAKUI from here.
    Run it and select hard drive, your external hard driveshould be on the list.
    It is a different matter if you are trying to install Fedora on external hard drive and it does not start, there is a different solution for that, see:
    Fedora Core Installation to an External USB Disk Drive
    Master:
  • 763 Answers
Its just maybe that the device is not compatible with linux. try that to windows xp and see what happen.
CHARCOIS
Im trying to install red hat linux enterprise 9 but it give error said no drives found.what can i do?
RH 9 is an old distribution. It simply may not be able to recognize SATA drives.
(Red Hat Linux 9, the final release, hit its official end-of-life on 2004-04-30 - Wikipedia).
If you are looking for a desktop solution, you would be better off looking at any one of these newer (and supported) distributions.
Ubuntu
http://www.ubuntu.com/
Fedora Project
http://fedoraproject.org/
OpenSUSE
http://www.opensuse.org/en/
I'm not endorsing any single one. Each has it's advantages. Plus there are others besides these.
Feb 09, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
How to transfer data from seagate barracuda 7200.7 ST380011A 80 GB hard drive to another hard drive after crash?
You need a usb cable to harddisk. than a computer running linux. connect hd by usb to linux and copy.
Jan 13, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I am having a maxtor One touch 111 external drive which I need to connect to a fedora linux. Do we have a linux driver which can detect the USB drive
If you are just using it as an external drive, Fedora should see the drive automatically, no driver should be necessary. If it can not, there is probably a different issue.
You may need to format the drive if order to mount it.
If it is already formatted as NTFS, it will be read-only to Linux. If formatted at FAT32, Linux should be able to read-write it as well as Windows.
fdisk -l: to get info on all disks (formatted or not) connected to the box. You should be able to figure out which disk is which.
If you will be using this disk exclusively with Linux, you will probably want to consider formatting it with a native Linux file-system.
Nov 30, 2010 | Maxtor OneTouch III 300 GB Hard Drive
I picked up a trojan virus (thinkpoint)... It would not let me boot to windows so I reset 'restore' to eairlier date, booted up as normal went on internet to down load 'spy doctor' while installing 'spy...
during the boot up process for a short time you will see a certain key to enter set up
press that key to enter BIOS scroll to PnP/PCI configurations the default is disabled
select enabled to reset configuration if you have installed a new add on and it has caused a serious conflict that the operating system can not boot
once you have your computer running again you might be able to attack this trojan
hope this helps
Nov 24, 2010 | Dell forLatitude C810 / C840 Notebooks...
I backed up my windows XP drive to an Iomega usb drive. I can read the usb drive on that machine and on a Fedora Linux machine, but, NOT on other Windows machines. It won't display the directories/files,...
This is probably due to user restrictions. linux is having no problem, but only the user in windows that created the files can view them.... unless you can change the sharing properties.
right click on the files/folders properties / sharing / advanced sharing, and enable sharing
Sep 30, 2010 | Iomega (33090) 250 GB Hard Drive
How can i installed driver of sata hdd for linux red hat
if you are installing red hat 8 and higher there is no need to install extra driver because linux is the only operating system which will install everything including drivers, office suite,programming tools etc .... as far as my suggestion dnt install old versions of linux instead install new version ... there are many linux available
ex: fedora core 4,5,6 ,knoppix live cd linux ( which boots linux from cd no need install it) ,ubuntu,red hat,mandrake,suse ....
you can download it from net 4 free as linux is open source 4 all ...
be careful while installing linux especially during partitioning..... if u make a mistake you will lose all datas
Feb 04, 2008 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Linux Not installing and Not detecting Harddisk
what version of linux are you using, suse, mandriva, fedora etc...
and which release is it (eg. suse 10.1... or whatever)
Dec 30, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Hard disk not getting attached with Linux
Hi, I'm not too keen on Linux but I found this website that might help you. http://rajibchy.tripod.com/ Check it out.
May 24, 2007 | Seagate Momentus 4200.2 (ST9808210A) 80 GB...
Computers & Internet Logo
315 people viewed this question
Top NexxTech Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Informat...
Informat...
Steven Wander
Steven Wander
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
