Question about Panasonic AG-185 Camcorder
USB 2.0 vs. Filrewire - video to PC
I have a camcorder (Panasonic PV-GS15). The handbook says that you need a firewire connection to transfer video to the PC. My question is if you could use a USB 2.0 connection also, since the camcorder is suppose to be compadable with such a connection and USB 2.0 is faster than firewire? Should the USB connection not be as good as the Firewire? Thanks
  • Anonymous Mar 31, 2014
    I can't connect the firewire to my imac as the imac firewire is a firewire 800 port. Is there a convertor cable that I need?
    Master:
  • 473 Answers
Hi I have figured it out. Even if the USB 2.0 is faster than the firewire the camcorder itself do not transfer at the optimal speed when connecting with the USB (even id the USB can transfer faster). So the only fast transfer option is the firewire
Posted on Sep 06, 2005
    Problem Solver:
  • 6 Answers
Addendum -
If your USB connection works well for you, go for it. Although USB2 has a faster transport (480mbps) over Firewire (400mbps), you get better sustained transfer rates over Firewire. this is because Firewire devices have their own controller built onboard to handle transfers, where USB requires your CPU to handle transfers. This makes USB transfers susceptible to dropped frames when the random virus scan (or something else) kicks off. It's also the reason why you can connect cameras to other cameras or decks (without a computer) using Firewire, but can't do that with USB; you MUST use a computer as a go-between with USB.
I like USB, which is fine for direct transfers, but Firewire will give you cleaner results when editing directly on a device or multitasking with editing packages.
Posted on Oct 19, 2009
    Master:
  • 473 Answers
My JVC GR-DV500 transfers with both USB 2 and Firewire, but USB support only works with their supplied application. Which is fine by me. For other DV editors, my bet is you have to go firewire to use their DVCAM capture.
SOURCE:
Hi .. i have PV-GS15 camera and i want to copy the video to my computer how can i do it .. and i don't have software of panasonic PV-GS15
The camera connects to a computer through firewire, which is a port similar to USB. You can try transferring pictures to a computer that does have firewire, which is most macs and some desktop PCs, or you can purchase a USB to firewire converter.
Jul 03, 2011 | Dell Computers & Internet
Panasonic PV-DV953D video transfer to PC
Did you put the camcorder in the VCR mode and make sure it is turned on, so you can transfer the video?
Jul 30, 2008 | Panasonic PV-DV953 Mini DV Digital...
Panasonic pv-gs15
You need 3 cables Yellow, (Video) + Red & White, (Audio L&R Stereo) Or Mini-DIN, for SVHS Video cable, this is ONLY for Video, Audio, is still Red & White. Or Component, where you have 3 Video Sockets, cables, Green, Red, Blue, All video, all color to color, both ends, and again Red & White for Audio. Sometimes there is FireWire, or HDMI you need a cable and the PC MUST also be equipped, You need software and drivers for FireWire, of HDMI..
Mar 26, 2010 | Panasonic Palmcorder PV-GS15 Mini DV...
How to download video from panasonic nv-gs15 to Computer
first of all you should have your cd driver came with camcorder and as far as i know your driver isnt compatible with vista so better try to use windows xp. install the driver, plug your camcorder using your usb. upload your videos from your camcorder to your pc using ULEAD MOVIE MAKER. edit it and save it with any various types of videos. finish!
CHARCOIS
Aug 24, 2008 | Panasonic Palmcorder PV-GS14 Mini DV...
PANASONIC PV-GS50 Transfer to PC
i want transfer my video in
May 16, 2008 | Panasonic Palmcorder PV-GS50 Mini DV...
My Panasonic Palmcorder PV-GS19 does not connect to my pc
if you want to transfer the video to the computer, I use a firewire cable that I had to buy separately, make sure ur computer has a firewire port. The usb cable is only good for downloading pictures.
Dec 17, 2007 | Panasonic Palmcorder PV-GS9 Mini DV...
Panasonic Palmcorder PV-GS85 Problem: Capture video with Windows Moview maker via USB
I believe you have to use a Firewire (IEEE 1394) cable to transfer the video. From what I have read, the USB connection is only if you want to use the camcorder as a "live" camera.
Dec 09, 2007 | Panasonic Palmcorder PV-GS70 Mini DV...
I connected with USB and used MS Movie Maker. The sw that came with the camera only transferred still pictures.
Oct 02, 2007 | Panasonic NV-GS15 Mini DV Digital...
DV Studio 3.1E-SE Download Request
1. The software is not required - if you have Windows Movie Maker that will work just as well.
2. It does require the DV (firewire) connection. USB connection creates a master-slave interface for "copy and pasting" or transferring low-frame video content (web-cam) or significantly compressed video w/ special drivers. This camcorder records digitally and requires a digital to digital peer-to-peer interface which the firewire connection allows for.
3. For those looking for Vista USB drivers - there are none from the manufacturer. Vista and XP have adequate native drivers for plug and play - camcorder should work just by plugging it in. If it's not recognizing, it could be a number of things:
-bent or broken USB pins
-inactive USB controller
-erroneous system drivers for USB
-camcorder is not plugged into AC power or is not on
-hotsync manager software from cellphones and PDA interference.
Aug 26, 2007 | Panasonic Palmcorder PV-GS15 Mini DV...
Panasonic AG-185 Camcorder Logo
633 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
