Question about Rowenta Steam Generator DG050 Iron
Rowenta steam generator
I have an older Rowenta steam generator iron -- about 5 years old -- and I can't screw the cap off anymore.  When I press down while turning, it never releases and won't unscrew, even when it's cold (it's been unplugged for about a month, so it's pretty cold). Is there any way to fix this?
  • tfrances Aug 27, 2008
    Thanks!  I only use tap water because the instructions state explicitly to do that.  I'm in Atlanta and don't think we have particularly hard water.  I'll try the CLR -- it can't hurt!
    Thanks again!
    Novelist:
  • 158 Answers
Maybe the cap is coated with mineral deposits. Do you use ONLY DISTILLED WATER in the iron? If not, minerals from the water could be the cause. Try pouring some CLR or a similar product over the cap and see if that frees it up . If it does, pour some CLR into the iron's tank, and set it to the highest temperature setting. Run the iron over an old towel to help clean the steam vents. Then fill the tank with DISTILLED WATER and do the same proceedure two more times using DISTILLED WATER ONLY to flush out any remining CLR.
Posted on Aug 27, 2008
Steam comes out the filler cap on the water base on my Rowenta DG5030
WIre brush the caps screw threads and replace the O Ring ASAP.
DOn't use the iron until you get a new O ring and they need to be the orange/red rubber ones they are able to withstand the hot steam black o rings at home depot won't last.
Jul 24, 2014 | Rowenta Pressure Iron and Steamer DG5030
I am having issues with my steam generator iron. I used it today and after heating up steam was pouring out from the screw on cap. Put on new green rubber ring and I can iron with steam until I sit on base...
I think lime and calcification are the culprit. Use some "CLR" at Home depot, can decalcify the build up on your irons pressure cap.
I have the Rowenta Steam Station. Love it!
Cheers,
Embroidery Services
San Diego, CA
Oct 25, 2017 | Rowenta DG5030 Iron
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
Rowenta steam generator iron will not shut off the steam (continues to steam until resivior is empty)
see the pictorial, and proceed according
clean the mechanismo +passages+examine steam component for loose, worn, or broken and replace. God bless you
Sep 06, 2012 | Rowenta Steam Generator DG050 Iron
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
No steam. I pressed the steam button on the underside of iron handle and no staem.
There 's a leaked capacitor in the circuit board. You just have to replace it and it works again.
Please visit the following page for detailed instructions:
http://thechipfreak.blogspot.com
Jan 15, 2010 | Rowenta DG5030 Iron
Won't steam
I know it's a silly question but are you pressing the trigger in the handle? If you are then the solenoid valve may have failed
Nov 20, 2009 | Rowenta Steam Generator DG050 Iron
Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Sep 09, 2008 | Rowenta Steam Generator DG050 Iron
Steam escaping around the cap
If new parts are needed, and I am in California, I use the website below for DG-980 parts:
California Electric Service
(925) 827-1011
1170-G Burnett Avenue
Concord, CA 94520
http://www.californiaelectricservice.com/
Hope this helps, good luck and keep in touch.
Jun 28, 2008 | Rowenta DG-980 Iron
No steam coming out and water tank not pumping water into generator to make steam
The Rowenta DG-980 Iron/Steam Generator works great from our experience (it is a consumer grade unit with commercial grade technology) and over 90% of the user reviews I have seen are happy with it, unfortunately it is a discontinued model & the newer replacement is not as good. Service seems to be rather thin, as is the case with most corporate entities; I was on the phone for 30 minutes before I was able to locate service center in Concord, CA (I am in SoCal), and is the only one in the state that does repairs on them, and I am going to check them out...stay tuned.
Dec 18, 2007 | Rowenta DG-980 Iron
Rowenta Steam Generator DG050 Iron Logo
629 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
