Question about Ricoh Aficio 180 Laser Printer
My Rico Aficio 200
Ricoh Aficio 200 printer is showing error sc401. any idea what this means
  • Anonymous Mar 14, 2014
    Mp2852sp ricoh error message sc401
    Sniper:
  • 86 Answers
Please open the front door and turn the blue lever in the middle,
remove the Transfer and Separation unit and check if the bushings of the transfer roller are damaged.
If OK, please give some oil on the shaft/bushings of the transfer roller. This unit may be replaced as a whole unit.
If SC401 re-occurs, please check the Photoconductor unit (drum).
Posted on Jan 13, 2009
  • 162 Answers
A transfer roller current leak signal is detected.
· High voltage supply board defective
· Poor connection of the PCU
· Transfer roller damaged
Inspect the contacts of the image unit.
Posted on Sep 14, 2009
Error Code SC 401
1. Check the transfer unit is set correctly.
2. Check the transfer roller is set correctly.
3. Check the high voltage supply board is set correctly.
4. Check the harness of the high voltage supply board.
5. Call a Ricoh Service tech.
Aug 14, 2014 | Ricoh Aficio Mp 3352 B&w Copier
Error code SC401
  • High voltage supply board set incorrectly or defective
  • Transfer roller set incorrectly or damaged
  • Transfer unit set incorrectly
  • Aug 14, 2014 | Ricoh Aficio Mp 3352 B&w Copier
    Ricoh Aficio MP 3352 error code SC401
    Check to see if the transfer roller fell out of its holders. It is the black roller mounted on the right hand door when open.
    Aug 14, 2014 | Ricoh Aficio Office Equipment & Supplies
    What error sc401?
    Transfer roller positive error problem
    Sep 09, 2012 | Ricoh Aficio MP 2000 Black and White...
    Wha tis the error code sc401 in ricoh 2400 plotter
    there could be following three possibilities
    SC401 Transfer Output Abnormal SC401- Transfer Roller Leak Detected SC401- Transfer Roller Leak
    for more detail click http://www.smilecopy.com/download/greske.pdf
    hope it helps
    if so, do rate the solution
    Nov 28, 2010 | Ricoh Office Equipment & Supplies
    My Ricoh 2232c copier has displayed error SC374 can you tell me what this means?
    SC322 Laser synchronization error SC324 LD drive current over SC390 TD sensor error 1 SC374 Development bias leak SC393 TD sensor error 2 SC401 Transfer roller leak error 1
    Jan 14, 2010 | Ricoh Aficio 2232C Color Copier
    Printer shows error CH551
    Is this actually a Ricoh Aficio 1013F, or another model, because "CH551" is not a ricoh service code?Do you mean "SC551"
    If so, this is a fuser "triac" problem (basically a fuse in the heater unit). It can only be reset in service mode after the problem is fixed...and will require a tech.
    May 21, 2009 | Ricoh Aficio 1013F Copier
    PHOTOCONDUCTOR UNIT FOR RICO AFICIO 2015
    I can get you one, but they are expensive.
    Nov 24, 2008 | Ricoh Aficio 2015 Copier
    Ricoh aficio 200
    Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
    jimgoatley@slingshot.co.nz
    Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
    Ricoh Aficio 180 Laser Printer Logo
    934 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    Adorjani Laszlo
    quennie732
    fares
    Level 1 Expert
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
