Question about Whirlpool Washing Machines
I have a Whirlpool Gold Catalyst washer (model#SM8280928;). Today I put a small load of towels in and used the catalyst mode (for heavy soil). After starting the catalyst part, the machine stopped before any water came into the washer and the electronic panel began flashing F4. Is this an easy fix or do we need a repairman? And if we need a repairman, can you give us a ball part figure of what it should cost? The washer is 8-10 years old and we want to know if we should repair or replace
  • treemader Aug 27, 2008
    I unplugged the machine and then plugged it back in. This seems to be a temporary fix. I will also look into the pressure switch.
  • Whirlpool Master
  • 19,396 Answers
Try first unplugging power cable, see if this clears the error
Posted on Aug 27, 2008
  • Ginko
    Ginko Aug 27, 2008
    F4 is a fault with the pressure switch, check the pressure switch contacts and eventually replace the pressure switch.
    You will need part and service manual , here is the service manual for a similar model you can buy both part and service manual at the following website:
    Repairclinic parts
    or call a technician for repairs
What is the capacity of a front loading whirlpool washer MO#GHW9150PWO
Whirlpool GHW9150PW 27 Inch Duet Front-Load Washer with 3.8 Cu. Ft. Capacity, 8 Wash Cycles & Triple Dispenser.
whirlpool ghw9150pw0 capacity Google Search
Nov 25, 2017 | Whirlpool Washing Machines
Sounds like your gear casing is broken inside, motor is spinning but transmission shaft where agitator sits on, is not spinning.
Apr 15, 2015 | Whirlpool Washing Machines
I have a gold catalyst gsx9885jq0. It has a code reading, F3. It won't do anything.
If I recall correctly, your F3 code has to do with the lid switch. You may need to replace it. Here is a link to the part you need.
Nov 21, 2010 | Whirlpool GSX9885J Top Load Washer
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
May 22, 2010 | Kenmore Washing Machines
Heavy towels don't come clean & smell of mildew - all whites and colours are gray after bleach has been used.
Did you add detergent to the dispenser?
For best results, add detergent to the detergent
compartment. Do not add detergent to the washer drum.
 Did you sort properly?
Sort lint givers (towels, chenille) from lint takers (corduroy,
synthetics). Dye transfer can occur when mixing whites and
colors in a load. Sort dark clothes from whites and lights.
 Did you overload the washer?
Do not overload the washer. The washer can be fully loaded,
but not tightly packed. The wash load must be balanced. Lint
can be trapped in the load if overloaded.
 Check the following:
Was paper or tissue left in pockets?
 Did you use enough HE detergent?
Follow manufacturer’s recommendations for the type of load
you are washing. For best performance, use only High
Efficiency detergent. Use enough HE detergent to remove soil
and hold it in suspension.
 Do you have hard water?
Use more detergent for washing heavy soils in cold or hard
 Is your water colder than 60°F (15.6°C)?
Wash water colder than 60°F (15.6°C) may not completely
dissolve the detergent. Use hot or warm washes if safe for the
fabric load. Make sure your hot water system is adequate to
provide a hot water wash.
 Have you run the Clean Washer Cycle lately?
To freshen your washer and to avoid odors, see “Cleaning
Your Washer.”
 Are you using HE detergent?
Use of non-HE detergent can cause a film residue which can
result in odor.
 Did you leave the door open after use?
This washer has a tight seal to avoid water leaks. To avoid
odors leave the door open to allow the washer to dry
between uses.
(see page 20 for washer cleaning instructions)
Oct 10, 2009 | Whirlpool Duet Sport HT WFW8400TE Washer
Washer will not spin/drain properly.
a large load will sometimes get out of the top of the tub and cause the lid switch mounts to break and then the unit wont spin or drain. just look under the top and if you see the lid switch just hanging or not in the right place then replace the lid switch.
Dec 07, 2008 | Whirlpool GSC9455 Top Load Washer
Agitator will not circulate the water during wash cycle
i bet you just need the agit-dogs but send me the complete model number from under the lid and i will see about helping you / larryyb
Nov 28, 2008 | Whirlpool GSC9455 Top Load Washer
Whirlpool gold catalyst washer front panel and pump
two screws in the back of the unit on the corners of the control unit unscrew them and lift up and back on the control under the control there are two gold colored clips that have to be pried up from the front to release the cabinet from the base I had to take the whole tub apart the problem seems to be caused by over use of fabric softener the shaft from the holding tank that the agitator tank sits on gunks up with softener residue and acts like a brake and won't let the washer spin to get rid of the water it's not that hard to do just remember that when you put the cabinet back on that the front goes under the base and the sides sit on top of the base on two little points
Jul 03, 2008 | Whirlpool Washing Machines
Whirlpool gold catalyst washer error code FF
FF on the catalyst models means the following. Let me know if you need more info or would like a link to where you can obtain a service manual for your washer.
If the transducer signals a high or a low water level for more than 16
seconds the washer will shut off and FF will flash.
• Press the RINSE OPTIONS button and select DRAIN/SPIN to drain
• Check the water level transducer hose and wire connections.
• Also check the pressure dome hose to be sure they are properly
• Check the water level transducer, see TEST #7.
Mar 04, 2008 | Washing Machines
Washing Machines Logo
310 people viewed this question
Dan Webster
Dan Webster
Sal De
