Question about Casio Cassiopeia E-100 Pocket PC
Has anyone been able to sync an E-100 using the infrared port with a Windows 2000 laptop?
I'm starting to get the typical, eventual problem of the connection port having a break in the solder and thought I could just switch to infrared. HA!
    Master:
  • 551 Answers
Depending on the manaufacturer of the notebook the option may be available either in the bios settings or in the control panel/system. If I remember correctly in Win2k this would be in computer management / device manager. If the IR port is visible in the control panel - which is the default in most of the notebooks I have seen - you will have to disable it for the 9 pin port to be available to external devices.
Posted on Sep 06, 2005
    Master:
  • 551 Answers
You might find it slow but it very definitely works. Make sure that in the windows system setup com1 is assigned to th IR hardware & not the serial port (9 pin) hardware.
My dell D505 turned itself and will not turn back on power light flashes but thats it power supply is fine
  1. Locate Fast IR under Onboard Devices.
NOTE: Ensure that the COM port that you select is different from the COM port assigned to the serial connector.
  1. Press <Enter>.
  2. Use the arrow keys to select the infrared COM port setting.
  3. Press <Enter>.
  4. Follow the instructions on the screen.
After you enable the infrared sensor, you can use it to establish a link to an infrared device. To set up and use an infrared device, see the infrared device documentation and the Windows XP Help and Support Center
http://support.dell.com/support/edocs/systems/latd620/en/UG/setup.htm#wp1112328
Dec 26, 2009 | Dell Latitude D505 Notebook
How to sync Palm T3 to (Dell) 64 bit laptop via Bluetooth
if you are using 64 Bit operating system you may use following procedure
1) Start > Run > msiexec /unregister
2) In regedit, find the following key:
HKEY_LOCAL_MACHINE\
SOFTWARE\Microsoft\Windows\CurrentVersion\Installer
3) Change MsiExecCA64
From this: C:\WINDOWS\system32\msiexec.exe
To this: C:\WINDOWS\SysWOW64\msiexec.exe
(This assumes a default Windows directory.
Change to reflect your configuration if needed.)
4) Restart the Windows Installer service
(Control Panel > Administrative Tools > Services)
5) Install Palm Desktop!
To go back to the previous settings, just reverse the change made in the registry, and stop/start the service again.
You can also set it back to normal by re-registering the installer:
Start > Run > msiexec /register
Jul 11, 2009 | Palm Z22 Handheld
Hy guys...I have reinstaled my windows on my M1530 and I need the driver and program to activate and use my Infrared Port.Please help me with a link or something.E-mail: manu_grim@yahoo.com Thanks...
u just go through google and write there " driver for infrared for ****[ your model number ] for windows or vista u will defenetly get drivers...........
Mar 03, 2009 | Dell XPS M1530 Laptop
My latop battery has fals power reading
You have to do battery training with your new battery. That is, charge it up fully and then let it run on the battery until your laptop dies (0% battery). This will eventually sync it back up.
Jan 01, 2009 | Packard Bell Easy One Silver 2101 Notebook
Can i sync a handspring?
Recent version's of the HOTSYNC app have a provision for IR transfers (older versions may not though). So you should check the HOTSYNC app on the Visor and see if it already has IR transfer abilities. If it does: Use the downarrow to specify the IR transfer on the Visor. Setup HOTSYNC on the computer to accept IR transfers. Line up the ports and tap the HOTSYNC button on the Visor's display. If it doesn't: You may be outta luck. Downloading an updated version of the HOTSYNC app (or some other utility) won't help because you'll need to Sync in order to get the app on the Visor.
Sep 19, 2005 | Toshiba Portege 3110CT (P000278510)...
Will Dell Axim sync with Outlook 2000 on Windows 95?
It should if you have USB on the W95 machine. ActiveSync is compatable with W95. It worked for me with Outlook 98 on a Win95 laptop synching to a PC2000 PDA (Jornada), however I was using a serial cable.
Sep 13, 2005 | Dell Axim X5 Pocket PC
PDA e310, e330 or e740 together with Windows NT 4.0
The Toshiba Pocket PC's e310, e330 and e740 are designed to work together with Microsoft Windows 98, Windows 98SE, Millennium, Windows 2000 and Windows XP. Microsoft Windows NT4.0 is an older operating system, which does not work together with the Toshiba Pocket PC's e310,e330 and e740. Technical background: The Toshiba Pocket PC's have a USB and a Infrared interface to communicate with a Computer. Unfortunately, Microsoft Windows NT4.0 does not support USB nor Infrared. Windows NT supports a serial connection, but the serial interface is not available for the Pocket PC's e310,e330 and e740. Note: There is the possibility to synchronize a PDA over Network or Modem but the ActiveSync Software, which is responsible for the synchronization, will need a "first sync" to establish a "partnership" with the PDA. This "first sync" can only be done via USB.
Sep 07, 2005 | Toshiba e330 Pocket PC
Sep 07, 2005 | Toshiba e310 Pocket PC
Sep 07, 2005 | Toshiba e740 Pocket PC
Cassiopia EM500 sync issue
First of all ensure that the port selected on the EM-500 for PC connection is the same as your actusl connection - i.e. USB or serial. There were some problems with the EM-500 cradle which would not allow communication to be established between the PDA & the PC/Laptop. Contact Casio for rectification. It is done free of charge.
Sep 06, 2005 | Casio Cassiopeia EM-500 Pocket PC
Casio Cassiopeia E-100 Pocket PC Logo
79 people viewed this question
Top Casio Computers & Internet Experts
k24674
jackcity
jackcity
Level 1 Expert
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
