That means it is time to change the water filter in your Refrigerator. Thank you for your inquiry on our Whirlpool appliances. Usually means replace filter. This means you have to replace your filter.Jun 14, 2018
Check and replace the damaged component/s at its main board.Contact any service technician.If you wish to get some details; check the site linked here.Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
It means the its faulty and it has an intelligent fault detector that helps the equioment to protect on its own, a technician will help you diagnose the fault, check amp module(output ic/transistors)
Try running a solution of 1 part white vinegar to 2 parts water,turn on & let run through if this dosn't work take the mop head off ( unplugged of course) & poke a needle or paper clip through the hole replace head & try vinegar solution agian. It worked for mine you need to clean out lime scale.
Please contact Intova directly at (808) 837-0074 or e-mail [email protected] and we will gladly help to address the problem with your H2O Man MP3 player.
The flashing red light means the batteries are low. The green light goes off when it's finished charging, or when there's not enough battery left to charge it.
