Question about Sharp Office Equipment & Supplies
Getting error code:U6-02 ON SHARP AR45 - Sharp Office Equipment & Supplies
What does error code dc on sharp 3100n mean?
image cartridge cyan need to be replaced
Jul 04, 2014 | SHARP MX-3100N
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
I am getting error code F9. what does this mean?
f9 codes usually relate around the printer boards or firmware errors you could try uipdating the firmware of the sharp site or look at the printer board connections.. try unplugging machine from wall and then take the back panel off check the conections of the boards and reboot.
Jul 28, 2009 | Sharp AR-207 Copier
Sharp AR-287 HR-00 error code
I'm sorry for not getting back to you sooner - I lost track of this question. If you still need this info here it is :
H3-00 indicates a temperature problem in the fuser unit. not reaching a certain temperature within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Mar 30, 2009 | Sharp AR 163 Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Jan 15, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-287 error code HR-00
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Dec 24, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
Im getting an f2 error code in my copy machine sharp 2020
SHARP 2020 F2-31 ID sensor error SHARP 2020 F2-32 ID pattern reading error SHARP 2020 F2-33 Grid voltage error SHARP 2020 F2-35 Grid voltage error
probably need a part
Oct 15, 2008 | Copystar (023-JF503) Fax
Sharp FO5700
I have never seen this error code on a sharp FO 5700 are you sure that is the right model # or error code. I even did a search in the FO5700 service manual(no luck). I believe I have seen this code before on a sharp copier.
Sep 05, 2008 | Sharp FO 5700 Plain Paper Laser Fax
655 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
