Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice maker not working in frig
The ice maker is working but when I try to put my cup in the outside holder and press the ice lever.........no ice falls out. Now I see the number 3 flashing like where it would flash if you need a new filter. What is this number 3 that looks like the shape of a pad lock with a flashing red light? Please help. :)
Does the flapper open?
Look from underneath, hit the dispencer lever w/o a cup there blocking your view, does the flapper open up? If not, you may have the same problem as we do.
The problem seems to be a failing linear actuator.
I'm unable to locate a replacement part, hopefully someone can help us.
Linear Actuator info:
Thermotion
115 volt
Posted on Sep 01, 2008
Water will not dispense.
have you try replacing the water filter if that does not help check your water solenoid valve.
Feb 22, 2015 | Maytag (MFI2568AEW) Bottom Freezer French...
Ice make has stopped making ice
Try filling the icemaker with a cup of water where the ice is made. Make sure the shut off arm is up. wait like a day. if it does make ice then you water valve needs to be replaced. if it doesnt replace the ice maker. also dont forget to check the tube behind the ice maker. it feed the icemaker with water. if that freezes up then water cant make it to the ice, thus ice maker and valve are fine. get behind the frig at the upper top right behind where the ice maker is but outside back. there is a tube that can be pulled out that is the feeder tube make sure no ice, do this ok?
Mar 27, 2010 | Refrigerators
Hooked up water to frig and got water in door but no water to icemaker. Any ideas?
Make sure the lever is down on the ice maker . Also , can pour about 2/3 cup of water into ice maker , so it will freeze and start the cycle . Otherwise , wait , and when the ice maker gets cold enough , it will cycle on its on to start the ice making procedure . If you get water to the door , then it's connected properly , and water will go to the ice maker , if the water valve and ice maker are in working order .
Sep 09, 2009 | Kenmore Refrigerators
Kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Apr 08, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
Coffee grinds on K cup holder
try removing the K-cup holder and inspecting the bottom hole opening. This is where the bottom of the K-cup holder would go through. Sometimes grounds can rest on that edge and fall into the coffee. I hope I could help!
Feb 15, 2009 | Keurig Special Edition B60 Coffee Maker
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Water dispenser will not work when lever is pressed. we had an intermittent problem with it before it stopped working altogather.I was going to look at it but was afraid to pop off the trim on the outside...
This could be a bad water valve in the frig. This frig has a double water valves. One for the ice maker and one for the water dispenser. It should be in the lower back. Where the water line goes in. You can check this valve easily. Find the double water valve on the frig. Turn off water supply to frig first. Swap the plastic water lines going from the water valve into the frig. Turn water supply on. Then see if the water dispenser works. Sometimes you will have to operate the water dispenser for a little while to get the air out of the line. If it works now then the problem is in the water valve solenoid and needs to be replaced.
Nov 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Maytag side by side MSD2735GR
well sometimes it clogs up , when i open the frig door sometimes the ice falls out since the actual cup in inside of frig is full of the crushed ice.
Sep 11, 2007 | Maytag MSD2756G Side by Side Refrigerator
Frigidaire FRS26R4A Side by Side Refrigerator Logo
95 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
