Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Ok i have the password
Ok I have the pasword and the wpa, but how can you know what your local ip or whatever is?
I\'m using this program called **** streamer for my psp.
    Sergeant:
    Champion:
  • 236 Answers
Press the "start" and "R" keys.
type cmd in the box and click OK.
type ipconfig /all
look for wireless adaptor (if using wireless) or network adaptor (without wireless if not using wireless),
the local IP should be there.
Posted on Aug 27, 2008
I SIGNED UP but have been unable to watch anything. Called comcast .my blue ray is not connecting to internet. I haVE wireless THAT'S NOT PROBLEM. Called Netflix 2x's still haven&#
It seems the problem is your Blu-Ray player can't connect to your wireless network. Based on what you said (and based on what the problem usually is), I'm guessing that you don't have the WPA (or WEP) key to your network. If you don't know it, you can log in to your router and look on the "security" or "wireless security" tab. It might be called "WEP key" or "WPA passkey" or "network password" or whatever. That is probably the code that the Blu-Ray player is looking for.
I could get more specific if you posted the make and model of your Blu-Ray player and router (or access point). If you also post the operating system (Windows XP or 7 or MacOS X or whatever) of a computer that is able to connect wirelessly, I can tell you how to get the WPA key off that computer.
Feb 02, 2015 | Dynex Televison & Video
It wont set up to wifi on my DS I don't know what to do?
First of all, turn on your DSi. Then navigate to the wrench which is "System Settings."
Select "Internet" and then select "Connection Settings."
Search for the connection your best choice and will display all possible networks in the area. You do this by selecting "search for an access point." You may choose from wireless networks that are unsecured and do not require a password, or networks that are secure with WEP and do require a password.
If you have WPA secured connection simply select "change security settings" to enter a WPA key.
You should be connected.
BE AWARE, some secure connections are not allowed. You can change these on your routers local ip to either WEP or WPA.
Jun 13, 2011 | Nintendo DSi XL Burgundy
Hi am having prob on setting my WI-FI i forgot the WI-FI/WPA Key
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
May 05, 2011 | Computers & Internet
I can not obtain an ip address it keeps saying that my wpa key is wrong. How can i sort it ?
Hi there. The WPA password is the one used for your router's protection. If the PS3 says that it the key entered is wrong, this definitely means that you have input the wrong WPA password and maybe tried to put another password.
The best thing to for this is to simply reset your password of your router and make sure to know exactly how you spelled it then simply input the new password into the PS3.
Please rate and comment, thank you.
Apr 15, 2011 | Sony Playstation 3 (PS3) Console
How to set a pasword on my d link router
log into the router by opening a web browser and entering the router ip, likely something like 192.168.1.1. Then navigate to the wireless section, change encryption from none to wpa, then add a password.
Feb 05, 2011 | D-Link Xtreme N DIR-655 Wireless Router
Lost web key for wireless internet
Most routers have a method to easily change the wireless password. You need to login into the router change the wireless encryption method. For example if you are using WPA then change it to WEP. Once thats done save the changes and the router will reboot. Now just switch back to the older encryption method and set a new key. Note that you should use the local ip to login into the router. If you don't know the local IP open command prompt. Start->Run-> Type in cmd and hit enter. Then type in ip config and hit enter. You should see an ip like 192.168.x.x. That is your local ip. Type it into the browser and hit enter. You will be prompted for router/modem admin username and password. Provide them and you can click on wireless-> security to change the password settings.
You can simply reset the router and re-configure it with a new key.
May 20, 2010 | Computers & Internet
Someone is acsessin my router and useing my internet without my permission i need to change the password but i cant
Reset both password (1) pasword for access router via GUI (2)Wi fi security password WEP or WPA or WAP
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Then click on administration and change password .
Then Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Apr 17, 2010 | Belkin Computers & Internet
Passwoed
Lol whi-fi? You need to read up on WEP (Wired Equivalence Protection) WPA (Wi-Fi Protected Access) and WPA2 to learn about it. Then you need to login to your router usually using 192.168.0.1 or whatever I.P. (Internet Protocol) Address your router has. Use your default password (provided with your manual) and set a different password after inside. Read your manual to understand where to set your WEP or WPA Passwords. Keep in mind WEP despite the name is not Equivalent to Wired Connections. WEP can be cracked withing 1-2 minutes. WPA and WPA2 can be cracked as well if it is using a PSK Handshake. Do a little homework and read your owners manual. Understand the risk.
Nov 17, 2009 | Computers & Internet
Our router is locked and dont know the password to unlock
Default admin username - admin
Default admin password - admin. Hope this works.
Oct 19, 2009 | Linksys Wireless-G WRT54G Router
I WANT OT PUT PASWORD TO MY WIRELESS BROADBAND ROUTER SO ONE CAN ONLY OPEN OUR COMPUTER AND SELECTED PEOPLE CAN ONLY USE THE WIRELESS CONNECTION.HOW CAN THIS BE?
Log into your router by opening your web browser software, for example Internet Explorer. Type in the address field the ip address of your router. The ip address depends on the manufacturer, but it should look something like this - 192.168.1.1 . A window should appear asking you for your user name and password. If the router is set to default settings, the user name should be ADMIN and the password should be ADMIN. Hit enter. This should bring you to your routers configuration window. lynksisssid_thumb.jpgSSID screen.Go to your wireless tab / basic wireless settings. Enter a SSID (wireless network name). The SSID may be on a sticker on the router or you could make one up. Choose a wireless channel. Disable your SSID wireless broadcast. Save or apply changes.
linksyswep_thumb.jpgWEP / WPA screen.Go to your wireless tab / wireless security. Choose enable. Choose either WEP or WPA encryption, the latter is a more secure choice. Choose 64 or 128 bit encryption, again the latter is a more secure choice. Enter a passphrase and write it down so you can enter it when it is called for when installing the wireless software on your wireless computer. A hexadecimal WEP/WPA key should be generated. Save or apply changes.cheers
Dec 03, 2008 | Edimax 4 Port Wireless AP Broadband Router...
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
20 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
