Question about Philips GOGEAR SA6045 MP3 Player
Philips GOGear when i turn on my GoGear , in the screen it only says initializing and it turns off! how do i fix it??? what's the problem?
  • 1 more comment
  • Anonymous Sep 06, 2008
    media converter for mp3 philips software needed for sa3125\97
  • panchal239 Sep 08, 2008
    i have also same problem, when i switch on the philips go gear ipod it turns off automatically. whats wrong please help me
  • jliz473 Sep 21, 2008
    my device is stuck on that initializing message and then turns off and every time I turn it on it does the same thing, I have tried to repair it with the device manager but it continues doing the same thing.
    New Friend:
Hello i have a philips go gear sa5245 once i accidently deleted a key file.so from then when i turn on my player it shows up a welcome screen saying "philips" and then it shows up "gogear" and then freezes there.i tried ur above method but my player is not detecting in pc for a repair........pls help
Posted on Apr 21, 2013
  • 8,596 Answers
You might have accidentally deleted key system files, but this is worth a shot:
Recovery Mode for Philips' GoGear
Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Posted on Sep 04, 2008
I turn my mps player on and it turns off after what seems a lock pic comes on
Posted on Sep 24, 2008
4 Suggested Answers
  • 5 Answers
SOURCE: Philips GoGear just says "initializing"..
cd de intalacion
Posted on Nov 13, 2008
shadow83
  • 496 Answers
SOURCE: philips gogear mp3 stuck on gogear screen
try putting it into recovery mode by holding the volume up while plugging it into the pc this might at least get the pc to see it also try it with a diffrent cable
Posted on Sep 30, 2009
SOURCE: whenever I turn on my Philips GoGear SA5125 - it
when an Mp3 goes off like that, is means that the Mp3 is corrupted with virus from an application you installed or a data inside the Mp3 player and and has caused it to have memory loss.
To restore the memory of the Mp3 back to normal, you need to flash the Mp3. Flashing restores back memories that where lost.
After flashing it, it will start working properly again.
Take care.
Posted on Apr 13, 2010
I ran the battery on my MP3 player completely down and it shut off. I charged it and now all the songs are gone... is there a way to recover the lost songs?
Try this:
1)Perform a system reset, which won't erase your files, to attempt to correct playback. Locate a thin object, such as pen tip or unfolded paper clip and insert it into the small reset hole on the bottom of your GoGear. Hold the thin object in place until you see the unit shut down completely. Your system has been reset. Power the device back on to see if the corrupted files have been corrected. If the reset failed to correct the issue, perform a file recovery on your GoGear.
2)Initiate a file recovery by first connecting your GoGear to your computer. From your computer's "Start" menu, choose "Programs," "Philips Digital Audio Player," "Area Device Manager" and "Philips Device Manager." The Philips Device Manager software will be activated. Inspect your GoGear to confirm that it is turned off. Plug the small end of the supplied USB cord into the bottom of your GoGear while holding down the "Volume Up." Insert the larger end into a free USB port on your computer. Hold the key as the "Philips Device Manager" reads your GoGear and activates recovery mode. Click "Repair" and follow the onscreen prompts as given by the "Philips Device Manager" to complete the process of memory recovery. Disconnect your GoGear from your computer properly after the process is complete and restart your MP3 player.
3)Reload and replace the files onto your GoGear by first connecting your GoGear to your computer. Plug the supplied USB cord's small end into the bottom of your GoGear and the large end into your comptuer's USB port. Initiate Windows Media Player by clicking on its icon if it doesn't start upon connection with your GoGear. In the left pane of the WMP, click "Philips GoGear Aria." Click the arrow on the top left edge of the WMP window, followed by "Music." Highlight all files, and click "Delete." Click the "Sync" tab on WMP, and drag and drop the music files you would like to replace and reload into the "Sync List" panel. Click "Start Sync." The files will be freshly loaded onto your GoGear.
4)Properly disconnect your GoGear from your computer to avoid memory corruption by first closing all applications in use by the GoGear (WMP). Click the USB device icon in your system's tray (located on the bottom right corner of your screen). Follow the prompts in order to safely remove your GoGear from your computer. When your computer tells you it's safe to remove your GoGear, unplug the USB cord from your GoGear.
Hope this helps!
Apr 08, 2011 | Philips GoGear ViBE Digital Media Player
My phillips gogear started acting weird last night when the screen turned whit, i literally cant see anything on the screen now and am NOT willing to pay to fix it, any suggestions?
Hi, there!
Your philips gogear screen is bad get it replaced and things will be normal .
there is nothing wrong with the machine other than this lcd .
Good luck .
Nov 30, 2009 | Philips GOGEAR SA6045 MP3 Player
My 16 gb gogear froze
1 On your computer, select Start >
Programs > Philips Digital Audio Player
> Aria Device Manager > Philips Device
Manager to launch the Philips Device
Manager.
2 Turn off GoGear Aria before you
continue.
3 Press and hold the volume button
while you connect GoGear Aria to your
computer.
4 Keep holding the key until the Philips
Device Manager acknowledges GoGear
Aria and enters the recovery mode.
5 On the computer, click the Repair
button and follow the instructions of the
Philips Device Manager to complete the
recovery process.
6 When the recovery is completed,
disconnect GoGear Aria from your
computer.
7 Restart GoGear Aria.
The full manual is found here: http://www.p4c.philips.com/files/s/sa1ara16k_17/sa1ara16k_17_dfu_aen.pdf
Oct 29, 2009 | Audio Players & Recorders
I turn on my Philips MP3 player GoGear goes and turns itself off!
Install philips device manager that comes in the cd alongwith the player and then use the repair tab to repair the device
Aug 27, 2009 | Philips GoGear Flash MP3 Player
I turn on my Philips MP3 player GoGear and it goes off!
are yaar.....there is a hold or keylock button just unlock that....
Aug 27, 2009 | Philips GoGear SA178 MP3 Player
Error message File System Error
Whenever I go to turn on my Philips Gogear audio video mp3 player, it shows the welcome screen but it doesn't go to the GoGear or the updating screens. Also, whenever I plug it into my computer through the USB cord, the charging screen doesn't show and it does not show that it is connected on 'My Computer'
Aug 20, 2009 | Philips GoGear SA3125/37 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
438 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
