FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
After inserting a new Maxell DVD+RW and when I hit record or enter a timer and then hit standby it reports "Recording error Cannot record on this disk E454037380"
After inserting a new Memorex DVD+RW and when I hit record or enter a timer and then hit standby it reports "Recording error Cannot record on this disk E454040990"
Did not have many errors when first using but now getting only 3 usable disks (recordable without error) out of a 15 disk pack. I have cleaned the recorder repeatedly after each time I've gotten an error message. I have turned the recorder off, waited a few hours, tried recording again, still got error code. Have unplugged, waited hour or more, plugged back in, tried to record again, still got "...cannot record on this disk" with error code respective to the brand of DVD Disk. Help! ? @B>) Please!
  • 5 more comments
  • dandm_cooley Aug 27, 2008
    There is no software to reinstall. It's a hardwired DVD Recording box that connects to my DVD/VCR player that is connected to my Television to record movies from TV and DVDs/VHSs.
    I have cleaned the recorder repeatedly after each time I've gotten an error message with RCA discwasher CD/DVD laser lens cleaner disc.
    Yes, thank you, I realize the problem is with the SV2000 DVD recorder, is there any workaround for this problem? Is there anything that can be done to get the DVD recorder to format the new discs without the error?
    Hi again, cleaned the inside with air and the laser lens with isopropyl alcohol w/ que-tip. Still getting same error messages as before when try to record on new unused RW DVDs. The Recorder can play, it just can't record, for some reason it is unable to format the new disks to record.
    Hi, I tried that in the past, had used DVD-RW to record and got the same error code on all the DVD-RW that I had gotten on some of the DVD+RW so took them back in exchange for more DVD+RW since it had recorded with some of them, while other brand new DVD+RW had also gotten the same error codes when attemptd to record.
    Have already cleaned lens and inside of DVD with no improvement.
    Thank you all for all your help. Can anybody recommend a dependable cheap DVD recorder?
    Genius:
  • 3,422 Answers
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Posted on Aug 27, 2008
  • Priya darshan Aug 27, 2008
    If you need anymore help let me know.
    President:
  • 1,952 Answers
Try to clean ur lens and try it
  • 1,879 Answers
Doesn't matter if another type of DVD disk works or not. Lens die too.
  • monk3ybidzness
    monk3ybidzness Aug 27, 2008
    The reason you purchased that DVD recorder is to use a DVD+RW. Now if it does not perform what it's supposed to do (can't work with DVD+RW), the lens needs repair / replacement.
    But if it works with other type of DVD discs & you can live with it, that'll be good. But keep in mind that eventually the lens unit will reach it's end of life.
  • 19,396 Answers
Often DVD units develop problems in writing either DVD+R or DVD-R, this regardless of the fact that they are supposed to work with both.
Use DVD-R, this should do the job.
  • 4,234 Answers
These units don't have a lot of error correction capability. ou will ned to open this up to clean the lens yourself using a cotton swab and alcohol. The commercially available "cleaners" do nothing but move dust around.
If the cleaning does not resolve it, update this ad we'll try a few experiments to determine where the problem lies.
Dan
  • 6,487 Answers
Provided they are brand new "blank" disks of the DVD-R/RW type, and its a case of after you insert the disc and it attempts to load the message is then seen to come on before it goes through the automatic formatting procedure, (spinning circle on LCD) then it would strongly suggest that its a recorder problem.
Hope that helps.........
  • Mark Gil
    Mark Gil Aug 27, 2008
    This can be a problem with the lesn already of your DVD player ,it may need to be replace so better take it to a repair center near you and have it replace..
    Good luck.........
  • Mark Gil
    Sorry to say but there is no workaround for this problem, the best thing that you can do is to have the lens of the DVD player replace of the whole DVD player if its still under warranty replace it from them....
    Guru:
  • 1,894 Answers
Reinstall your burning software
and try a different power and data cable
  • dewan nafees ahmed Aug 27, 2008
    i would suggest you to try a different power and data cable.
    also use a different burning software.
    also use the inbuilt software of windows to burn the disk.
    thank you
Help quetion
Which brand of DVD-R disc did you use? What error did you get? What is your video source? Most TVs don't give video output. The tuner on the WV20V6 is an NTSC (analog) tuner. Thus you need to use a set-top box (OTA digital-to-analog converter, cable or satellite box) with the recording "channel" set to video input 1 for most channels or analog cable input to the recorder.
Verbatim DVD-R 8x, Maxell DVD-R 8X/16X and JVC DVD-R 2X have been tested and proven to work by the manufacturer. A number of DVD+R and DVD+RW or DVD-RW have been tested as well.
I've found that you have to test each batch of DVDs. Different manufacturing plants can lead to bad discs from a previously good brand.
The manual for the WV20V6 is available from Funai Corp (who manufacture the recorder for SV2000). The direct link is http://www.funai-corp.com/support/om/WV20V6.pdf . See page 25 of the PDF for tested optical discs. No CD-Rs will work.
I hope this helps. Please add a comment with more information about your situation for additional support.
Jun 22, 2013 | Funai WV20V6 SV2000 DVD Recorder and VCR...
I need a manual for my sv2000 dvd recorder, it was not in the box.
The manual for the SV2000 dvd recorder can be found at
http://www.funai-corp.com/6pdf/om/WV10D6.pdf
You can view the manual online or download to your computer for future reference.
Feb 05, 2011 | Funai FDR90E DVD Recorder
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Need manual for Funai SV2000 Model#WV20V6
Visit www.funai-corp.com and under manual type your model to download pdf.
Jan 06, 2009 | Funai TruTech DVDVCR Dual Recorder
Py90vg recording error
look for what format the dvd records on [ dvd-r, dvd-rw, dvd+r, dvd+rw. the manual showed tell you
wg
Feb 04, 2008 | Funai PY90VG DVD Player/VCR
Emerson EWR10D4 DVD Recorder
try mr dvd-r discs from poundland.
They work with the funai machine.
Its worth a try.
Dec 24, 2007 | Emerson EWR10D4 DVD Recorder
Computers & Internet Logo
1,948 people viewed this question
David Payne
David Payne
