Question about SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive
Harddrive simply not alive!
In a nutshell, my external hard drive is not working. I haven't had it plugged up to my laptop in a few days and when I went to plug it in I noticed that nothing happened. I tried simply turning the hard drive off and the back on and that's when I realized it was the hard drive itself and not the computer. It used to light up and you could hear the soft hum of the motor but now it makes a couple morse-code sounding bleeps and then...nothing. The red light is on indicating that it is turned but nothing seems to be happening inside. It's plugged into a surge protector strip but I'm wondering if having it on too long has damaged it or if some sort electrical surge screwed it up. Arrghh!! my external hard drive is not working. . It used to light up and you could hear the soft hum of the motor but now it makes a couple morse-code sounding bleeps and then...nothing. The red light is on indicating that it is turned but nothing seems to be happening inside. but when i turn on from another pc it is working....!
  • xion555 Sep 18, 2008
    I have the same thing happen to me i accidentally dropped it but nothing happened to it on the outside and now it makes a weird noise like beeping and the lights flash for a few seconds and then the red light stays on but the blue one does nothing please help all my music and video files are on this.
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
The clicks you descibe normally points to the drive itself being beyond repiar , but follow these steps anyway to eliminate other possibilies.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
I have a problem with my external harddrive. when plugged in it takes too long too read and when I transfer files from or too the harddrive it takes up to one day. sometimes the files is not even as b
Are you plugging directly into the computer or using a USB Hub. Cheaper USB hubs have awful data throughput. I have one that I tried to plug a sd card reader into and it would take ten minutes for a 60 megabyte file. Connect directly to a port. Or download Samsung diagnostics and make sure that the drive is in proper working order. Verifying The Hard Disk Drive Is Working Normally
Jan 10, 2015 | Samsung G2 Portable External HX-MU064DC/...
Seagate st90000u2 160gb no longer recognized by home laptops
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
hope this helps
Aug 10, 2012 | Computers & Internet
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
http://www.xbitlabs.com/misc/picture/?src=/images/storage/wd-passport-250gb/p3.jpg&1=1
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
http://www.xbitlabs.com/articles/storage/display/wd-passport-250gb_2.html
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
Solution?
Simple.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
Trying to find the operators manual for prestige desktop hard drive super speed usb 3.0 ,2 tb
The general directions is to plug the USB cable from the IOmega Prestige into any available (Open) USB port.
To open, (Access) the contents on the harddrive, double-click on the drive letter that corresponds with the IOmega.
In WinXP left-click on Start, then on My Computer.
In Win Vista and Win7 left-click on the Windows logo button, then on Computer.
You will see there are different drive letters;
Drive A: is reserved for a Floppy Drive. Older computers
Drive C: is for the Harddrive. (Hard Disk)
Drive D: is reserved for a recovery drive, or an optical drive (CD/DVD drive)
Drive E: is reserved for an optical drive, usually.
Drive letters beyond these are usually under the heading, Devices with Removable Storage
One of these drive letters should correspond with the IOmega.
Suggest, IOmega not plugged in, go to My Computer, or Computer, and look at the devices connected to the various drive letters.
Now plug the IOmega in, and see if it shows up next to a drive letter.
(Give the computer BIOS a few seconds)
Where there was NO device shown BEFORE, there should now be a device shown.
{No device shown before, but now there is. May not state IOmega, just external storage, or similar}
DOUBLE-click on the device shown.
For example:
I have drive letters C: D: E: F: G: H: I: J: and K:
Drive letter C: is for my harddrive.
Drive letter D: is for a recovery drive. (Partition in harddrive reserved for recovery)
Drive letter E: is for an optical drive (CD/DVD drive)
Drive letters F through K are reserved for an external storage device.
Whether it be an external harddrive, or flashdrive, or what have you.
IF you find the drive letter that corresponds with the IOmega DOUBLE-click right on it.
If nothing happens, or if there is no device shown when the IOmega is plugged in, there is a problem with the IOmega.
Hard to believe IOmega is still having problems with their external harddrives.
In the past they were having problems with a small circuit board located inside the IOmega's case.
[ A circuit board is a PCB.
Printed Circuit Board
For example a computer mouse has a small PCB in it,
http://en.wikipedia.org/wiki/File:Mouse_printed_circuit_board_both_sides_IMG_0959a.JPG ]
The small circuit board is an Interface Board.
It connects the harddrive inside the IOmega's plastic case, to a USB cable, and this allows the harddrive inside to be plugged into a USB port on a computer.
As mentioned inside the plastic outer case (External enclosure) of the IOmega is a harddrive.
(Hard Disk drive; proper speak)
Harddrives are measure across their Width. There are two current types used;
A laptop size harddrive, and a desktop size harddrive.
A Laptop size harddrive is 2.5 inches across in width. (2 and a half inches, or 6.4cm)
A Desktop size harddrive is 3.5 inches across in width. (Or 8.9cm)
There are two technologies used;
IDE (PATA) or SATA
I'm sure the harddrive inside susanbrenton is a SATA unit.
I BELIEVE, it is a laptop size harddrive (2.5)
Point?
If there is data (Information) on the IOmega that you must have, you may wish to buy an inexpensive external enclosure, remove the harddrive from the IOmega, and install it into the external enclosure.
The external enclosure has a plastic case (Enclosure), and a small circuit board inside. It has a USB cable, or connector, just like the IOmega does.
Once you install the IOmega harddrive inside the case, the case is closed, and it's USB cable is plugged into a computer.
(Just like the IOmega. You are just replacing the small circuit board essentially)
Once you have the IOmega's case open, and can view the internal harddrive, measure the width of the harddrive.
Buy the appropriate external enclosure.
This is one example of an external enclosure for a 2.5 SATA harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
This is one example of a external enclosure for a 3.5 SATA harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Basic instructions on how to open an IOmega Prestige external enclosure (Case):
1) There are two Philips head screws on the Back of the case.
These are removed.
Once removed a the oblong panel on the end comes off.
2) You can now see the harddrive inside. Pull from the Front, and remove the harddrive out of the case.
3) The harddrive is attached with screws to a metal carrier. (Bracket, essentially)
Remove the screws, remove the harddrive.
Basic example, the harddrive will look like this,
http://www.geeks.com/details.asp?invtid=0A26923-NDW-R&cat=HDD
For additional questions please post in a Comment, (Believe upper right of your page)
Regards,
joecoolvette
Oct 15, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
My lacie drive fell off desktop and is not recognized as readable by my Mac. What chance do I have of recovering the data?
Inside that LaCie external harddrive's enclosure is a regular SATA harddrive.
The kind that fits in a desktop computer (3.5 inches in width), or laptop. (2.5 inches across in width)
Open the external enclosure (Case) of the LaCie, remove the harddrive, and install it into a suitable external enclosure.
(Laptop size, or desktop size)
The external enclosure has a USB cable also. Just plug it into any available USB port on your desktop computer.
Do I know for a fact that the harddrive is okay, and this will fix the problem?
No sir/maam I do not.
But IMHO this is the first diagnostic method to use.
IF the harddrive is a desktop sized harddrive, it could be installed in your desktop computer as a Slave drive.
However the above method is so much easier, and it allows your harddrive to be an external harddrive once more.
Inside the external enclosure of the LaCie external harddrive, is a small circuit board that the Harddrive plugs into.
It is this small circuit board that receives the damage in most cases.
If the problem is the Harddrive itself, a professional data recovery shop will;
A) Try a new, or good used harddrive circuit board.
Check to see if the harddrive's circuit board received the damage.
B) If the circuit board proves to be good then the next step is to remove the Platters inside.
The room used is a Clean Room.
A room that is 99.9 percent dust free. (In most cases)
The Platters are installed into the case of a compatible harddrive, that has the Platters removed.
Then as much information as possible is copied off.
There are other methods data recovery specialists use also.
[A Harddrive is built in a Clean Room. 99.9 percent dust free. The technicians wear a Clean Suit, that resembles what a doctor would wear in an operating room.
They enter the work area after going through a corridor, fitted with air jets at various levels.
If a harddrive is opened up in a room that is not a Clean Room, the harddrive's 'life expectency' drops to a day, or a few hours. The dust 'kills' them ]
http://computer.howstuffworks.com/hard-disk.htm
http://www.youtube.com/watch?v=gpY8c7lT_7k&feature=related
http://www.youtube.com/watch?v=ax390l2A-AY
Observe the other videos also.
Examples of both a SATA 2.5 external enclosure, and a SATA 3.5 SATA enclosure,
(The Harddrive's width is measured in inches. (2-1/2 inches for a laptop drive, 3-1/2 inches for a desktop drive)
SATA 3.5 external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4421576&CatId=2780
Regards,
joecoolvette
Jul 02, 2011 | LaCie Hard Disk design by Neil Poulton...
I need a new internal power supply for my 2tb external its an Iomega prestige. I just want the part number for it so i can order a new one.
There is no internal power supply. The unit gets it's power from the computer. A USB port has 5 Volts DC.
Inside that external enclosure of the IOmega external harddrive is just an ordinary harddrive as used in a desktop computer. A SATA harddrive.
The harddrive plugs into a small circuit board with an interface on it, or there are cables, (wires), which come from the circuit board, and plug into the back of the harddrive.
It is this small circuit board that is usually the problem.
The solution to this problem is to simply just buy an economical external enclosure, and install the harddrive out of the IOmega into it.
Just one example from a quick search for an economical SATA 3.5 external enclosure,
(Note*
A laptop harddrive is 2.5 inches across in width. 2 and 1/2 inches.
A desktop harddrive is 3.5),
Have additional questions or need clarification to what I have stated, please post in a Comment.
Regards,
joecoolvette
May 29, 2011 | Iomega 2TB Prestige External Hard Drive
My laptop isn't picking up my external harddrive anymore? There is nothing wrong with it's power supply and usually it comes up immediately. How do I test whether the harddrive is still working?
you have to try it out on another pc, plug it in the USB port and watch if there is any autoplay or so. If so, then it has most probably to do with the registry keys.
Please specify your operating system (XP, Vista, Windows 7,...)
Jan 13, 2011 | Western Digital Passport WDXML800UE...
Does the toshiba satellite a135 s2276 accomodate a second hard drive?
You won't find internal room to place a second hard drive, if that's what you're asking. Most laptops simply do not have the internal space, especially thin-line units.
What you could do for extra storage space is purchase an external drive.
Sep 01, 2009 | Toshiba Satellite A135-S2276 Notebook
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Kind Regards
Andrea
Aug 02, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
SimpleTech SimpleDrive 160 GB External USB 2.0 Hard Drive Logo
67 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
