Televison & Video Logo
Posted on Aug 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just quit my samsung hc-p5241w projection tv just shut off the other day and when i try to turn it back on the red led on the just flashes then goes to solid.the led flashes twice short break then flash twice again then goes solid or turn off
Anonymous
Level 3:
  • Master 5,138 Answers
  • Posted on Aug 27, 2008
Anonymous
Master
Level 3:
Answers
5138
Questions
5
Helped
1004370
Points
13534
Bad STKs 392-110s 2) also two 3.9 ohms resistor are open replace STKs with 180s.
Problems with color on 2005 Samsung 52 inch HDTV
Quite normal in many situations as signal is compressed with most cable and satellite systems, a fact of life.
Tv went of when we watching it i did disconnect it and a red light came on where the power button is does tv have a lamp
Tv "LAMP" LED light indication flashes or light up?Yes,the tv projection lamp life is over.Replaced the tv projection lamp.
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
How much would it cost to get a blue tube replacement for a rear projection tv
Depends on where you go could cost as much as $400.00 just for Tube, are you sure your Tube is Bad?
Samsung hc-p4241w - No picture
samsung tv model hc-p4241w good picture no sound
2answers
Samsung 52" tv
you could possibly have damaged the deflection power supply that part is not to expensive if you can find a reputable shop they should be able fix you up pretty cheap as opposed to a new. if the set had a good picture get it fixed its a good set
Vertical red line, tv turns off
If your looking to service this set yourself you need to open the back cover and look down on the main pcboard with a flash light if you see any liquid damage it's more then likely your CRT's are leaking coolent fluid on to the main PC board, Common problem with most CRT projection TV's manufatured today, main board needs to be cleaned and the CRT's need to be sealed,
No picture on screen, chirping noise every second from back
again a good set the deflection modules on these sets are pretty reasonable you need to have a tech swap it but i highly suggest that than a new one the chirping is the set trying to start up but going into shut down
1helpful
Screen Turns Red and then TV shuts off
you red crt is shorting out.tap the neck of the red crt lightly to try to remove the short.if no go also inspect the neck board.
Picture turned pink
This all of the sudden happened if so you may have lost the green alot of times yoiu can fix the CRT drive Brd there is a video amp ic and a resistor that can be replaced or yo can replace the whole Brd a little harder to do than just replacing the parts on the Brd
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
