Question about Yamaha HTR-5440 Receiver
RCA Pin Broken in jack
I have a male RCA pin that is broken off inside my av reciever...
It's too deep to get out with needle nose plyers.
I was thinking of taking the case off to get it out that way but don't want to go to the trouble if there is an easier way.
  • 142 Answers
There is no easier way. Sorry! Good luck!
Posted on Oct 03, 2008
Broken pin stuck in S-Video port
1.) Find a needle 2.) On a hard surface, bend the very tip of the needle slightly so that it forms a tiny barb. 3.) heat the tip of the needle with a lighter until it glows red hot. 4.) stick the needle into the plastic core of the broken RCA pin 5.) wait a few seconds for it to cool 6.) pull the needle out, and the broken tip should follow!
Nov 16, 2013 | Daewoo DTQ-20U4SC 20" TV
My emachine monitor keep saying no singale
May be a bad pin (bent over or missing) on your monitor cable to the video jack on your computer. If a bent pin, you can straighten it with small needle nose pliers; VERY SLOWLY--fast moves can fracture the pin and break it. If a pin is missing (broken off), the connector must be replaced. If connector looks good, and is not a molded, but a soldered type, a broken solder joint can be repaired, If it is a molded cable, the entire cable must be replaced.
I focused on the cable because this is the most common cause of "no signal", and further troubleshooting would be 'involved', to say the least.
Mar 01, 2013 | Computers & Internet
The reciever plug brock inside the AUDIO component/ AV in
remove the jack pannel by unsoldering it. their might be a small hole on back side of jack push broken lead outward by using paper pin if no hole then complete pannel must be changed
Nov 15, 2012 | Televison & Video
My AV IN cable broke off in the tv, what can I do to get it out?
You can remove a piece of broken (AV)hdmi cable with a little heat, a steady hand and patience. Pins can break due to mishandling of the equipment, a stressed and failed jack, or aggressive RCA removal techniques. Most methods for removing an RCA center pin will result in damage to the jack. However, one key method almost never fails.
Aug 14, 2012 | Video Game Consoles & Games
The rca jacks for my sonance the sub subwoofer are apparently broken or loose inside. How do I get the back off to repair?
Please check this link for your problem:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Apr 18, 2011 | Sonance The Sub Subwoofer
How do i pop open my hood when the hood latch is broken in the interior, 2001 mitsubishi eclipse
get a needle nose plyer and get down under the dash by gripping firmly using needle nose plyer you should be able to pull on the cable while another person try to open the hood at the same time
Nov 06, 2009 | 2001 Mitsubishi Eclipse Spyder
To connect Asus Notebook to Yamaha RV-502 Av Reciever to play music
Hi, Most notebooks have a 1/8 female plugin from your audio card. (headphone Jack)
Now, you need a cord with a 1/8 male plugin on one end and two RCA Jacks on the other.
All you need to do is connect the cord to (AMP) RCA in and the 1/8 Jack to you notebook.
This will work fine. Good luck
Oct 12, 2008 | Computers & Internet
Cable connector broken
You can buy replacement antenna jacks for this. What you have to do is remove the tuner and it's shields, then unsolder the little tab off the board of the tuner which is what remains when they break off. Then you can resolder the new jack in place and the center pin back to the board of the tuner.
Mar 28, 2008 | RCA HD52W59 HDTV Projection Television
Yamaha HTR-5440 Receiver Logo
154 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
