Question about GE Dishwashers
I have a new dishwasher and it won't start. it is set for normal wash and heated dry. when i close the door and push start, it doesn't start.
  • 1,543 Answers
You don't say if it does anything at all or is just dead. I'll guess just dead.
First, make sure you have power to the dishwasher. Breakers all on? Some homes have the dishwashers plugged into an outlet under the sink. Usually one of these outlets is switched (for disposer) and the other half of the outlet is live, for a dishwasher. If you have the outlet connection, plug a lamp into the recepticle to make sure you have power. Some outlets may even be "downstream" from a GFI recepticle which may be tripped. Second, you may have to check to make sure the twist wire nut connectors are all good and tight on the white, black, and ground wires at the connection to the dishwasher. Hold the wire nut and tug on the wires to make sure they stay in the wire nut.
Posted on Aug 27, 2008
How to reset wirlpool quiet dishwasher
To reset it, you will have to have the door open. It can not be latched. Press "Heated Dry," "Normal," "Heated Dry," "Normal" within three seconds of the first pressed button. Now close the door, this should reset your dishwasher.17 Dec 2012
SOLVED: Dishwasher whirlpool quiet partner I push start button - iFixit
https://www.ifixit.com/.../Dishwasher+whirlpool+quiet+partner+I+push+start+button+not...
or try this link.
How to reset wirlpool quiet dishwasher Google Search
Oct 28, 2017 | Dishwashers
Why are lights flashing on my dishwasher's control panel?
There is a button configuration that you can press to make the unit reset on some you would close the door and push normal wash heated dry then normal wash then heated dry on others it would the econo wash button then heated dry then the econo/ heated dry this pattern starts the unit and then puts it into the drain cycle and resets the control which allows you to start washing again. If you can name off all the buttons you have I can tell you exactly which ones to perform this reset in the unit. I await your reply
Rick
p.s this also happens on whirlpool models as well right after the warranty runs out so you end up paying the high service charge for a tech to walk in you door push a few buttons then collect a fee over 169.00 which is ridiculous.
Nov 17, 2011 | Maytag Dishwashers
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
Normal light blinks
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Daniel
Apr 17, 2011 | Whirlpool Dishwashers
Clean light flashes
I have found 2 possible solutions for you to try on your washer. It looks like there are good results on each of the sequences listed so you may try both to see what one works for you.
1) Press normal wash and heated dry one after the other about 5 times.All lights on panel will light.Wait until all lights go out and it resets itself.It will go into a mode on it's own.Then press cancel and set your options as you normally would and press start
On the hidden button models this seems to work, push these buttons in this order:
Heated Dry, Hi Temp Wash, Heated Dry, Hi Temp Wash, close the door, Start, open the door, Cancel 2x
Mar 08, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
The clean light is blinking and the dishwasher does not run???
Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.Try out his and see what happens.It must reset the memory and your dishwasher must work.
Jul 06, 2010 | Kenmore 24 in. 16352 / 16354 / 16359...
"Clean light" keeps blinking; dishwasher won't start new cycle
close the door and to cancel that just press hi temp and hetaer dry again hi temp and heater dry and all the lights is gonna light up, it getting into test mode.
After that press cancel
Now get somebody to replace the thermistor of your machine
Feb 19, 2007 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
75 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
