Question about Panasonic AG-185 Camcorder
Can the camcorder be used as a webcam?
Can I use my camcorder as a web cam?
    Master:
  • 473 Answers
Yes, on selected Panasonic Camcorders. Please refer to the specification page in the owners manual.
Posted on Sep 06, 2005
SOURCE:
I have an inbuilt web cam but i have failed to be able to use it
Plz Try to again re-install web Driver......
Find driver for Acer Aspire Webcam Driver from following link...
http://drivers.freesoftz.com/scanner-digital-camera-webcam-camcorder/acer
Jan 20, 2011 | Acer Aspire One PC Notebook
How to use a sony handycam dcr-sr80 hd as a web cam?
It is not possible to use the Camcorder as webcam using USB interface as the Camcorder does not have the USB Streaming feature.
You may connect the Camcorder to the A/V input of the Computer to use it as webcam.. However, it is required to use a software which is compatible for capturing videos from A/V interface to use it as webcam.
Dec 30, 2010 | Sony Handycam DCR-SR80 HD Camcorder
Sony cam as webcam?
As the Camcorder is a Hard Disk Drive Camcorder and it does not support USB streaming feature so it is not possible to use this Camcorder as Webcam.
Good Luck!!!!!!!!!!!
Sep 30, 2009 | Sony Handycam DCR-SR85E HDD Camcorder
Myvcamnow2.0 wont work as a webcam
go here
http://answers.yahoo.com/question/index?qid=20080312162903AA1iwLJ
Jul 23, 2009 | Tiger Electronics VCamNow Flash Media...
I have a jvc gz-mg330hu and I want to use it as a webcam.
load the usb driver, connect to usb port, power on in record mode and set your webcam app to use it.
Jun 17, 2009 | JVC GZ-MG330 HDD Camcorder
PUEDO UTILIZAR MI CAMARA DE VIDEO SONY DCR-SR 30 COMO WEB CAM PARA MI ORDENADOR PORTATIL, ASUS?
Si puedo utilizar su camara por eso. pero, la directiones estan en engles.
Primero es para S- Video
La orta mas pavajo estan directiones para USB Streaming
How to use a Sony® camcorder as a Web cam with a composite video or S-video connection.
Solution
sp.gif sp.gif IMPORTANT: The computer must have a composite Video or S-Video input jack [FIG. 1]and compatible webcam software installed. Some computers may require a video capture card and/or sound board.
NOTE: This procedure cannot be performed when using the battery of the camcorder as a power source. If the camcorder is turned on, but not recording or playing a tape, it will automatically turn off after 5 minutes to conserve battery power. In addition, please be advised that this procedure may not work for all Sony camcorder models even when using the AC power adapter. Some models have an automatic demonstration mode that will activate after 5 minutes if the camera is turned on but not recording or playing a tape.
  1. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  2. Connect a composite video cable or S-Video cable to the VIDEO or S-VIDEO jack on the camcorder. NOTES:
    • Sony camcorders usually come packaged with composite Audio/Video cables; S-Video cables are sold separately.
    • To purchase either of these cables, check with your local electronics dealer or visit the Sony® Parts and Accessories Sales Web site or by call (800) 488-7669.
  3. Connect the other end of the composite video cable or S-Video cable to the VIDEO IN or S-VIDEO IN jack on the computer.
  4. Turn on the camera by moving the POWER switch to the CAMERA position.
  5. Remove the cassette tape from the camcorder.
  6. Turn on the computer.
  7. Start the webcam application to be used. NOTE: Contact the software manufacturer for assistance with setting up or using the webcam software.
[[Direct Accessories and Parts Center, DAPC]] How to use a Sony® camcorder as a webcam using USB Streaming. Solution
  • Not all Sony® camcorders are equipped with a USB Streaming port. For compatibility information, or if you require further assistance with any of the steps below, consult the instruction manual of your camcorder. A copy of the camcorder instruction manual is available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site
  • The USB Streaming driver is not compatible with the Apple® Mac OS® operating system.
  • The computer should have a factory installed USB port and compatible webcam software, such as Microsoft® NetMeeting®.
  1. Install the USB Streaming driver on the computer from the CD provided with the camcorder.
  2. Restart the computer.
  3. Plug the AC power adapter for the camcorder into a working electrical outlet and then connect it to the camcorder.
  4. Connect the supplied USB cable to the camcorder and computer.
  5. Turn on the camcorder by moving the POWER switch to the CAMERA position.
  6. In the camcorder menu, set the USB STREAMING option to ON .
  7. On the computer, start the webcam software.
Apr 06, 2009 | Sony DCR-SR30E Camcorder
I need drivers for my web cam Ezonics Cam IV I can not find it on the web.
http://www.video-camcorders.com/ezonics-usb-cam-driver.html>>Your cam drivers and all you need for your cam can be found here.RICHARDM69
Dec 05, 2008 | Ezonics EZCam Webcam
Camera JVC EVERIO GZ-MG33OHU
see if your camera has a USB. if it has then install the driver to your computer that camed with your camcorder. the drivers function is to allow the camcorder to use on your computer. insert the USB from your camcorder to your PC and now you can use it as a webcam. hope that helps!
CHARCOIS
Aug 14, 2008 | JVC Everio GZ-MG30 Camcorder
How to make a camcorder with a webcam
You will need:
A Camcorder (Firewire or Analog)
A Firewire Card (For Firewire Camcorder)
A Video Capture Card or TV Tuner (For an Analog Camcorder)
A way to connect the Camcorder to the corresponding cards.
The Eagletron TrackerCam Software.
Go to trackerCamhttp://www.trackercam.com/TCamWeb/download.htm
to download it, it is a free download. You need additional hardware to get full use of the software, but for a basic webcam this software is enough.Active WebCam captures images up to 30 frames per second from any video device including USB, analog cameras, TV-boards, camcorders, and from network IP cameras.
The program performs simultaneous recording and broadcasting from unlimited number of cameras.
WebcamDV allows you to have "the best quality webcam in the world:"
If you own a DV camcorder, or are about to buy one, wouldn't it be cool if you could use all its features by making it the world's best web cam? WebCamDV is a utility which runs in conjunction with your webcam software application. It lets your digital video camera with all its expensive features, act like a webcam! Imagine, a webcam with 600X zoom, auto focus, stereo sound, auto stabilizing, night vision, high quality optics, and more, depending on your camcorder.
DVDriver lets you iuse your camcorder as if it were a regular webcam:
DVdriver is a software tool that lets you use your camcorder with any software that works with webcams. It works by fooling Windows into thinking that your camcorder is just an ordinary USB webcam.
Use your camcorder with the full range of webcam software available today. Just plug your camcorder into your PC's Firewire port, run DVdriver and start the software you want to use.
What software do you use to turn your camcorder into a webcam?
Jul 24, 2008 | Cameras
Web cam
how use webcam in this camera
Jul 13, 2008 | DigiLife DDV-C330/C340 Camcorder
Panasonic AG-185 Camcorder Logo
211 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
