Dvd to table top tv
Is it possible to hook up a dvd player with a table top tv that only has a single cable input and no other input jacks?
  • Peggyinfl Jan 07, 2009
    I want to add a DVD player and still keep my cable hook up.
    Problem Solver:
  • 22 Answers
Try, A/V converter.
Posted on Aug 27, 2008
How to connect samsung ps50c55og to sony dav s500 home theatre system
You need a set of normal rca cables (red.yellow,white) and another single rca cable..
OPTION 1 :If you have a digital satellite receiver, Connect the 3 colour cables to the corresponding colour jacks on VIDEO 2 of your dvd player to corresponding colour jacks on the VIDEO OUT Of your digital satellite receiver...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 2 STRAIGHT TO TV: connect the 3 colour cables directly to the corresponding colour jacks on the SIDE of the tv...Connect the single stand alone rca cable to MONITOR OUT on your player to the VIDEO IN input of your tv..
OPTION 3 IF YOUR PLAYER HAS AN OPTICAL INPUT: if this is the case you can just connect a single optical cable to the optical ports on your player and tv and this will enable the sound from your tv to play through your dvd player as well
Feb 12, 2013 | Audio Players & Recorders
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
Whehe do plugs go on back of unit? have direct tv
First off, you need to hook up audio and video by using an A/V cable to connect the DVD player to the TV, yellow, white and red jacks are coded, match the jacks up, put one end of A/V cable to DVD player OUTPUT jacks and the other end to INPUT jacks in back of TV. Also same with Direct TV receiver, hook top set of jacks to TV, with A/V cable, also connect coaxial cable from satelite to matching satelite input jack. Connect power cables, and then you're set. Good luck to you!
Dec 12, 2009 | Televison & Video
How do i connect a vcr to a dvd player that is already connected to the tv
First you hook vcr up to tv,
then
On back of dvd player, take your 3 cables, red, white, yellow, and match them up to the input jacks with same color on vcr.
Then turn vcr on to input channel
turn on dvd player
turn on tv to channel 3 or 4
Aug 15, 2009 | Sony HVR-1500 HDV VCR
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Sony CD/DVD Player DVP-NS501P
There are several ways to connect the TV to the DVD player but you can only take advantage of the progressive scan option on your player if you use component cable. Component cable has three input jacks on it and they are colored Green, Blue, and Red. Your TV/amplifer must have component input jacks on the back of it to use this cable. If it does, then the input jacks on the back of the TV are usually labled Y, Pa, and Pr. The Y input is for the Green input jack, the Pa input is for the Blue input jack and the Pr is for the Red input jack. Once you have these plugged in you will next need to hookup the audio/vidoe cable that came with your DVD player that has a Yellow, White, and Red input jacks on it. The Yellow input jack is for Video and the White and Red are for audio. Both your TV and DVD player will have inputs for these so just match them up. If you do not have component inputs on your TV then just hook up the audio/video cable and it will work.
Nov 07, 2008 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
Televison & Video Logo
Top Televison & Video Experts
