Memorycardin alocked condition,the data canbe saved.There are twowaysyou can do: 1.Use thedatarecovery software(must besoftwarefullversion).How:insertmemory card, run thedatarecoveryprocess,selectthe drivememorycard,etc.Savethe fileto your harddriverecovery.After the datasaved,memory cardformat(quickformat),thenrestorethe data into thememorycard.
2.Quickformatmemory card,anddothe datarecoveryprocess.So thatdata can besaved, do notdo a fullformat,butdoa quickformat.Toolssuch as harddrives, flashdrives,memory cards,when donequick format,data can besaved.
1. To save files received from bluetooth on sd card: Open messaging. Go to settings. Scroll to the end and select other settings.
Change the default memory to Memory card. It will ask to copy or move the messages and file from phone memory to sd card. Select move to memory card.
Now all files will go to sd memory card.
2. To save all applications to sd card, open ovi store, go to settings, change installation preference from phone memory to sd card
It's in the settings of your camera. Depending on your options, it may be under save settings, memory, or storage. May be that you just have it set to "save to memory card" and not "save to internal memory".
Understand how a Memory Stick Pro works. The small card saves information from a portable device. You can save, delete and rewrite to the card as many times as you want. You can also remove the card and insert it into another device. For example, you can save photos from a camera, then insert the memory card into your laptop to view or download the images.
Step 2
Make sure you buy a memory card that matches the demands of your electronic device. The cards have different saving speeds and data-holding capacities. Generally speaking, the more data the card can hold and the faster its speed, the more expensive the memory card. Check your electronic device's product information for recommendations on the best type and size of memory card.
Step 3
Insert the Memory Stick Pro into the electronic device. Most devices have a small flap or cover on its side that holds the card. The memory card slides into a slot under the flap. Gently push in the card and close the flap.
Step 4
Save to the memory card. Once the card is installed, many devices know to save new data to the card. In some cases, however, you may need to specify where to save files, either to a built-in hard drive or to the memory card.
Step 5
To remove the card, open the flap and gently press the card in. The card should then pop out of the slot for easy removal. The card can now be inserted into another device.
First check whether the phone is configured for saving the photos to memory card or phone memory. In case it is configured for saving the photos on memory card, change it to save in phone memory and then try saving the photos. In case you are still not able to save the photos, you will have to reset the phone to factory defaults. In case you are able to save the photos in phone memory, try the memory card in another phone, if no go then you will have to format the memory card.
a memory card is a memory card at the end of the day and mad catz is virtually just as good as the offical sony stuff. it is the memory card being faulty as it is not actually saving or showing up. try buying a new memory card
Hi
Firstly have you a memory card inserted?
If yes, is there any problems reading files from it?
If yes, remove memory card and re insert, it may just be connections dirty?
If no memory card inserted chances are your camera settings are set to save to memory card.
To change this start the camera and go to settings/options.
Look for default save location. If it is set to save to memory card and you dont have one, that would be the reason why it is not saving images. Either install a Pro Duo memory card or change default save location to 'Phone'.
Hope that helps?
Your question is somewhat confusing, using a playstation 2 memory card, will have PS2 game saves on it, how would you play PS2 games on a PS1 from the save, you can't.
If you just mean you are using a PS2 card for a PS1, the way a PS2 card saves data is different to a PS1 card, so it probably won't work
You can use your PS1 memory cards in the PS2. You can only use the PS1 memory cards to save PS1 games that you are playing in your PS2. You can't save any PS2 game data to a PS1 memory card
