Apparently, my printer (Canon i850) has a defective print head. The instructions say to remove the print head, and check it. I cannot figure out how to remove the print head. Can you help me?
  • jacatk Aug 27, 2008
    I successfully removed and cleaned the print head, then reinstalled it. But printer still doesn't work. The yellow lights flashes 7 times, then goes back to green, then yellow flashes 7 again, etc. My manual says that means a defective print head. What to do now?
    Genius:
  • 1,142 Answers
HOW TO REMOVE THE PRINT HEAD
  1. Confirm that the printer is powered on.
  2. Open the paper output tray and top cover.
  3. Gently open the paper output tray while holding it.
  4. Confirm that the print head holder has moved to the center.
  5. Remove all ink tanks.*
  6. Raise the print head lock lever and remove the print head.
  7. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
Posted on Aug 27, 2008
  • 1 more comment
  • Maanita Chadha
    Maanita Chadha Aug 27, 2008
    Follow the instruction B
    Follow the instructions AFollow the instruction C
  • Maanita Chadha
    I hope this will help you
  • Maanita Chadha
    Remove the ink first
    Genius:
  • 1,226 Answers
if this so that print head is damage then, you have to replaced it. However; check the connection from the printer head to the board of the printer. and also the board parts check also.
melnavz
  • 6,487 Answers
First try to take the print head out again , then put it back carefully and make sure is properly connected..then if you still have the same error message you may need to update the driver of the printer , because the problem is already software related and updating the driver of the printer should fix it...
Hope that helps.......
  • 282 Answers
Go here http://tinyurl.com/27hyzf
    Genius:
  • 3,422 Answers
HI,
Note: Gently open the paper output tray while holding it.
3. After confirming that the print head holder has moved to the center, open the inner cover.
4. Remove all ink tanks.
5. Raise the print head lock lever and remove the print head.
6. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
7. Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
8. Close the inner cover and top cover.
Please don't forget to accept the solution as fixya.
  • 19,396 Answers
Other support website canon i850
  • 89 Answers
Follow the instructions in this website:
http://www.fixyourownprinter.com/forums/inkjet/53369
How to fix a defective print head on canon i850
Purchase the print head from ebay approx $35.00, install[simple drop in installation], then you will be up and running.
Aug 13, 2012 | Canon i850 InkJet Photo Printer
Printing, but not full words Canon i850
Sounds more like the actual print head has become dried out and simply needs to be cleaned. This is a common problem with Canon Bubble and Ink Jet printers.
You should be able to remove the cartridge and then the print head shuttle that moves across the page. Once you have it removed, you will need to get a couple of Q-tip swabs and some DENATURED ALCOHOL, NOT RUBBING ALCOHOL as the water in rubbing alcohol will damage the printer head. Wipe the face of the printer head GENTLY with a moistened swab, you should see the dried ink dissolve, do this a few times until you see no further ink on the swabs.
Allow it to dry for a few minutes and then reinstall it into the printer. You will need to run the alignment function of the printer to ensure that the print is aligned properly. That should do it.
Cheers,
Keith
Sep 19, 2009 | Canon i850 InkJet Photo Printer
I have a Canon Bubble Jet i850. It is approximately 7 years old with no problems until now. I am getting 7 orange flashes, which according to the manual indicates possible defective printer head. I removed...
The problem does indeed seem to be a print head fault. Remove it and take it to your local printer re-inking firm. Get them to do a thorough clean of the print head (they have the equipment that us mere mortals don't) and test it (should cost you nothing or very little). If it works, great! If not then get a new printer. The cost of replacing the print head would be the same or more than replacing the entire unit.
Sep 14, 2009 | Canon Office Equipment & Supplies
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
Printer wont print in color and i just replaced with all new ink cart.
new cartridges can be defective also.
Remove and re-insert the cartridge, double check them,
( leave printer on )
Check printer's Advanced properties are not set for black only,
switch off at mains, reboot,
Run maintainance on it, head cleaner, nozzles etc...
if the same, swap out, the color cartridge it is faulty.
Hope this helps
Regards.
Apr 16, 2009 | Canon i850 InkJet Photo Printer
How to put a ink cartridge in a Canon i850?
LIFT THE FRONT COVER UP , GIVE THE PRINTER SOME TIME AND THE PRINT HEADS SHOULD GO TO THE CENTER OR RIGHT OR LEFT MARGIN PUSH IN AND DOWN.
----------------------VERY IMPOTANT-----------------------------
I THINK NEW CARTRADGES INSIDE THE PACKAGING HAS INSTALL INSTRUCTIONS INSIDE THE BOX WHEN YOU BUY IT FROM CANON INK CARTRADGE, OTHER BRANDS MAY DO THAT, IF NOT SURE OPEN BOX LOOK INSIDE AND SEE IF THERE IS INSTRUCTION ON HOW TO INSTALL NEW PRINT CARTRADGE
ROD
Jan 06, 2009 | Canon i850 InkJet Photo Printer
No color printing on my i850
ONLINE AND TYPE
CANON 850i WILL NOT PRINT IN COLOR
ROD
Aug 14, 2008 | Canon i850 InkJet Photo Printer
Every 4th or 5th line does not print
try running your maintenance program.
go to your printer settings
right click on canon i850
left click on properties
run cleaning or deep cleaning,
then print head alignment and/or nozzle check
Dec 19, 2007 | Canon i850 InkJet Photo Printer
Will not print
Remove and re-seat the print head. If need be the print head can be cleaned with hot water. YMMV but I've submerged my i850 print head for minutes at a time. Dry it off, blow it out, and it goes right back to work. Common problem if you're using non-Canon inks.
Nov 07, 2007 | Canon i850 InkJet Photo Printer
438 people viewed this question
k24674
