Question about Planar PDP-42BK 42 in. Plasma HDTV
Planar pdp42bk problem
Hello, i have a planar pdp42bk with problems.  When i push the main power switch, the standby light comes on red (never green) and then just turns off 1 second later.  The green light on the power supply board also comes on and shuts off at the same time.  Any idea what the solution may be?
Also, are C95 and C96 supposed to have caps installed because there are none in those two places on my board and it seems as if they were removed.
Thanks in advance, my email address is alexa9k6@yahoo.com
~Alex
    Problem Solver:
  • 16 Answers
Change the c97,c19 and c16 caps below is where I got mines.
Got it from a site called digi-key.com their phone # is 1800-344-4539. The part #s are EF6225-ND you need 1of these, and E6105-ND you need 2 of these, the cost is $16 for all. Let me know how it went.
Posted on Oct 26, 2008
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
On Planar PL1700 monitor, screen stays black after power failure
this is a common problem with the capacitor, try opening your monitor and see if there is a capacitor swalow like gonna blow... the capacitor has a form like a AA battery... if changing the capacitor the problem persist maybe is a problem with the board and you need to search if the board have continous power....
Jul 30, 2010 | Planar PL1700 17" Flat Panel LCD Monitor
Tv turns off will turn on then off right away
the internal overload sensor is engaging to protect the system. The parts cost to replace the faulty board is about $70 But you need the skills to open the tv and change it I recommend you get a professional to do it More expensive of course but a lot safer.
Sep 19, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
Planar PE191M monitor display will not stay on
iv come across this before sometimes people can see that the monitor is actually working but the light has gone out id say bad capacitors that are breaking down. if you want to DIY it take it apart and find the light pcb usually built on the power supply pcb and look for bulging or swolen capacitors this happens alot in my opinion. if you can DIY it get the same caps or same value but better ones. I might be wrong but worth a look
Apr 01, 2009 | Planar PE191M 19" Flat Panel LCD Monitor
Planar PDP42BK no picture
Check the 15v line that runs through all the boards, left, right and top.. If that has no power, then look on the ysus board (left one) there is a flyback reg (5pin) standard to-220 case surrouded by caps, it does dc to ac conversion, if you dont have the 15v output then the chip is bad. I just did 2 of these that had the same problem.
Oct 27, 2008 | Planar PDP-42BK 42 in. Plasma HDTV
PLANAR PDP-42BK NO VIDEO SIGNAL
who changed the caps and what caps did they change, also there are two switches on the board one should be normal and the other on 30v
May 12, 2008 | Planar PDP-42BK 42 in. Plasma HDTV
Green Light on no picture
More than likely, the planar LCD sets have a set of 5 1000uf 16volt caps that fail. There could be other problems, but to check, unplug, pop off the cover, and look at the brown cannisters. They will mostl likely be bulging, or you may see blackish goo coming out of them. They're fairly easy to replace if you have experience with a soldering iron.
Oct 17, 2007 | Planar XP17W 17 in. LCD Television
Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Jul 10, 2007 | Planar PDP-42BK 42 in. Plasma HDTV
Planar PDP-42BK 42 in. Plasma HDTV Logo
331 people viewed this question
Top Planar Televison & Video Experts
JonSnell Electronic
JonSnell Electronic
Greg Hull
Are you a Planar Televison and Video Expert? Answer questions, earn points and help others
