Question about Kenmore 98702 Stacked Washer/Dryer
Low water in 98702
Needs water added to the washer like 2-3 gals.
  • 30 Answers
Check the water-inlet valve for cleanliness, and functionability then replace if necessary.
Posted on Aug 27, 2008
Maytag Neptune TL washer doesn't stop adding water
it sounds like your drain hose is to low it needs to be 3 feet high if its to low this will cause the water to syphon out and keep refilling
Nov 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Water will drain durring spin cycle
This is normal on some machines. Run it through a complete cycle it should fill, agitate, drain, some will drain down so low then start spinning as it is draining but should stop draining before it fills or stops. Check if water is coming in at the same time it is draining. If not it may be ok.
Dec 23, 2010 | Kenmore 98702 Stacked Washer/Dryer
What would cause a washer not to fill?
a bad water valve.take off the two water lines,stick them in the washer where the clothes go and open the water valve,hold the hoses when you do this,see if any water is coming out the hoses,if not you have a bad house water valve and the washer is ok.if water comes out then you need to check the water valve on the back of the washer.if you need more help you need to send the model number,hope this helps you.
Jul 15, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water will not stat in tub
Your drain hose is too low to the ground. Somehow raise to hose up higher.
Jan 11, 2010 | Kenmore 98702 Stacked Washer/Dryer
The washer leaked water out the bottom after the wash was finished. It took 4-5 towels to soak up the water. What is wrong with the washer?
you will need to open the machine (front panel - most times its 2 screws on the bottom)
and turn the machine on & look with a flash light where the water come from...is it busted pip , or pump is bad...
good luck
911servicetoday . com
Oct 16, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer won't hold water
sounds like your drain pump is bad. They are relatively cheap to repair. You can find them on www.Repairclinic.com . Remember to unplug all appliances before servicing. Good luck. You will need your model number to find the correct part.
Apr 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Cooling system capacity
2 gals. sounds about right for fill up after a water pump job there is coolant left in radiator,heater core &engine block and of couse the reservoir. thanks from schleck.
Aug 11, 2008 | 1998 GMC Sierra
Kenmore 98702 Stacked Washer/Dryer Logo
26 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
