50" rear Projection TV (1993) Model 50UX14BC. Red color was washed out, but then TV quit altogether. If unplugged a few minutes, it will come on briefly (red pilot light shows) then goes off. Power switch then does nothing, unless you unplug it again, then same thing, power light shows briefly. Obviously a power supply problem, but I can't find my service manual. I know this is difficult to guess at. What do new color tubes cost, is it worth fixing? Very nice set otherwise
    Scholar:
  • 167 Answers
Hello. well your right it's a power supply problem. and about the color tube. .you can find one for around $75.00 to $600.00. yes that's right. that much.!!! and i think that you will have to pay to much to fix it.!!! it'se to get a new set. !!! hope this help's you.!!! "GOOD LUCK"
Posted on Aug 27, 2008
Was watching TV, heard a slight "pop" noise then TV went dead - no picture or sound. When I hit the power "on" button on remote, the green light blinks for quite a while (around 40...
Count the number of blinks. Now, Google your make and model with the words blink codes added to the end. This will show you links to sites that will tell you what the blink code means and the problem with your set. The blink code is the sets way of telling the service man what is wrong. From the sound of it, you have a bad capacitor.
Sep 11, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Video is taking on a red tint which is getting worse over time
check the cable connections. look at different inputs. VGA and Component cables have the colors split, so if it's turning red, green, or blue; it's likely a cable or connector.
Dec 29, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
I have a KP65Wv700 Sony Tv it turns red after a few minutes of watching tv. I turn the tv off and on so see a few minutes of normal colors but start gettinmg red again any ideas
I'm afraid, its RED Picture tube problem that will be replaced.
It is qualified tech job to replace picture tube in rear projection TV because there are few adjustments required after replacement.
Please call local tech for fix tv.
Thanks.
Dec 14, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Syntax Olevia 50in Rear Projection Negative?
Sounds like you have projection bulb problems. Not an easy fix as the are 3 color tubes and a complete alignment when replacing even one of the 3 tubes. Takes a lot of work.
Aug 31, 2017 | Syntax Olevia 50" Rear Projection...
Picture looks like a Colored Negative
so, how can i fix this problem with my tv. the tv comes on but the colors look fuzzy..help!!
Oct 27, 2008 | Syntax Olevia 50" Rear Projection...
Color fades
HELLO. it sound's like you have a cold solder problem.!!! what that mean's is that when the set get hot .!!! it lose's it's contack.!!! you might try going over the chassis .!!! soldering the conteck's.!!! with a low watt. solder gun.!!! not over 40 watt's.!!! and use 40/60 rosin core solder.!!! hope this help's you .!!! "GOOD LUCK"
Mar 14, 2008 | Hitachi 50UX58B 50" Rear Projection...
50" rear projection zenith television
does it look like this:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Jul 31, 2007 | Zenith IQC50H95W 50" Rear Projection...
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
